DCB Audio System change - Comments?
Discussion in 'Audio & Video' started by lbridges, Mar 23, 2011.
  1. Mar 23, 2011 at 4:54 PM
    lbridges
    lbridges [OP] Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    First let me offer that a 2011 6 CD changer (non-JBL) works in conjunction with the Blu-Logic Bluetooth daisy chained with the Grom Audio USB-i-MP3 box.
    So, my plans are to use a David Navone LOC driving a Memphis Audio 30-Channel graphic equalizer, into an old school Xtant amp. In turn this drives a Pioneer Premier 720-PRS component set. Also planned is a TBD woofer set up.
    The thing I'm soliciting comments on is if the community thinks there is enough "meat" in the rear doors to mount an 8" woofer on each side. My truck is new enough I've just not had the time to pop a panel and check the metal work for sufficient rigidity.
    I have the woofers, a set of Dayton Audio RS-225s. Not great as a subwoofer substitute, but in my listening I don't need ALL that much bass. I know the two 8"s worked well in my previous car, a MR2 Spyder, but of course the Spyder has a much more enhanced transfer function compared to a DCB.
    I also have a DVC 10" sub in a closet, but I would like to avoid going behind the seat if possible - that, and I also want to try out stereo bass signals. Now before folks jump on me about source location below 100Hz, give this a read (scroll down to the "Two Subwoofers? Naturally" article): http://web.archive.org/web/20011004154957/www.sundial.net/~rogerr/truth.htm
  2. Mar 23, 2011 at 6:55 PM
    TorenApart
    TorenApart Well-Known Member
    06 Double Cab SR5 TRD Sport
    Toytec Ultimate Lift Kit, Total Chaos UCA's, 18'' Black XD Monster, 285/60R18 Cooper Zeon LTZ, OEM Skid Plate, Weather Tech Floor Mats, Lund Tonneau, Custom 2-tone gray leather, Aero Turbine 2525 muffler with AR25 resonator, Aero Turbine Exhaust Tip, Mr. Marv subwoofer enclosure w/ 2 JL 10W3v2's, AFE Pro Dry S, TRAIN HORNS, Eclipse AVN-6620, Pioneer PRS-D2100T, Hybrid Audio Clarus 6.5'' Front Components, Black Headlight Mod, Tinted tail lights, PL5300 with Eclipse BEC-109
    I doubt it. The sheet metal in these doors is not what I would call "meaty".
  3. Mar 23, 2011 at 6:58 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Localization is a much bigger problem due to rattles than acoustics. Doors are very poor substitutes for a proper enclosure, based on the rattles inherent to a "skin" on the panel, and the need for drainage, mounting clips/holes, etc. I would seriously reconsider that option. Also of note, as discussed in the article, phase is an issue. Stereo bass, in doors, pointed at each other, could lead to some serious phase cancellation issues. Never tried it, so dont know for sure. Also, as you state, while good midbass drivers, those are not subs. So you are really talking about running a 3 way with rear mounted midbass, but then trying to use a 6.5" driver for a mid, while having it mounted very low, very off axis, and with very limited ability to extend high enough to cross with a tweeter up top.
    The PRS set mids (I have them, never played with the tweets) are good for midbass, so spend extra special love and care on those front doors.
    I hate to push to much, by why mess with passive (if you are) and why the EQ? Seems like a "more gooder" option may be something like a Audison BitOne, or the soon to be released BitTen. (should be around 400 bones) Eq, time alignment, active controls, (only 5 channels, so you would lose the stereo bass, but my thoughts on that, for a car, are its a complete waste of time and effort)
  4. Mar 23, 2011 at 7:02 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I cant imagine having the depth needed to mount them in the door, much less getting a good sound from them.
  5. Mar 25, 2011 at 2:56 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Mostly 'cause it's all stuff sitting in the closet. Plus I like having an external equalizer, especially with an OEM headunit. I do have a copy of TrueRTA as well as calibrated mics, so it's not as bad as it seems. Still thanks for the considered advice from all. The rear door mount idea was more about trying something a bit different.
