DCLB 885s or 884s?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JSenuk, Aug 7, 2014.
  1. Aug 7, 2014 at 6:38 PM
    JSenuk
    JSenuk [OP] Active Member
    Sherwood Park AB
    2011 Black DCLB small lift with 285s
    2.5" lift, 285 terra grapplers, black mamba wheels, hood scoop light bar
    I'm so ready to ditch the spacer lift that was on my truck when I bought it, I swear I can feel every pebble in the road. Anyways I want to go a full 3" up front. I plan on going 5100s with OME coils. Would a 885 and top plate spacers give me a full 3" and give me good ride quality? The truck has no armour or anything on it. I have already installed LR UCAs so alignment is no issue. Or should I go a different route? I'd only like to spend about $500 to get the front lifted properly and ride good. Thanks
  2. Aug 7, 2014 at 7:17 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Based on your budget.
    885s with 5100s set at .85 and a 1/4 top plate spacer should put you pretty close if not at 3".
  3. Aug 7, 2014 at 7:20 PM
    Large
    Large Red
    :confused:
    885s = 2.5" + 0.85 + 1/4" spacer (gives 1/2" lift) = almost 4" of front lift which I would not do. If you get 885s set 5100s at 0 or use OME shocks.
  4. Aug 7, 2014 at 7:28 PM
    LEX
    Houston, Texas
    100 Series LC
    Hmm. I think you're right. I was running the set up like I mentioned above, but I'm running a plate bumper. :rolleyes:
  5. Aug 7, 2014 at 7:41 PM
    LEX
    Houston, Texas
    100 Series LC
    Now that I thought about it. I was at about 2.5-2.7 with the setup I mentioned. Without the extra weight that I have, wouldn't it put him at around 3"?
  6. Aug 7, 2014 at 7:50 PM
    JSenuk
    Sherwood Park AB
    Based on a few threads I read through the 885s will give you 2.5" with the 5100s at zero. So if I put the top plate spacers too I should be right at 3". I don't want to add preload if possible.
  7. Aug 7, 2014 at 8:11 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Consider going with 887 springs if you want to reach for the full 3" without spacers.
  8. Aug 7, 2014 at 8:25 PM
    JSenuk
    Sherwood Park AB
    ^ just researched the 887s, good to know, I wasn't even aware they existed. I'd much rather run those than a spacer!
  9. Aug 7, 2014 at 8:28 PM
    Yota64
    Yota64 Professional Threadjacker
    LEX, I see you mentioned his budget for his lift, OP keep in mind that a budget 3" lift is kind of hard considering at 3" you may need UCAs.
  10. Aug 7, 2014 at 8:31 PM
    JSenuk
    Sherwood Park AB
    I just installed some LR UCAs from the group buy a while ago. So alignment is no issue :thumbsup:
  11. Aug 7, 2014 at 8:37 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  12. Aug 7, 2014 at 10:54 PM
    LEX
    Houston, Texas
    100 Series LC
    Yup, he already has them.
  13. Aug 8, 2014 at 4:34 AM
    Large
    Large Red
    I think you mean 886s. If you mean 887s send me a link so I can knowledge myself.
  14. Aug 8, 2014 at 5:06 AM
    MagneticTaco79
    MagneticTaco79 COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    885=2.5"
    886=3" (longer than 885 and heavier spring rate) recommended for a lot of weight up front
    887=3" (longer but same spring rate as 885) recommended for a full 3" with out a lot of weight up front
    This should be right, correct me if im wrong OZ.
  15. Aug 8, 2014 at 5:09 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    sounds right to me!
  16. Aug 8, 2014 at 5:37 AM
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    I love it every time you make a post i start to "sing"
    Oh this burning beard. I have come undone. Just as i feared. I HAVE COME UNDONE!
  17. Aug 8, 2014 at 6:05 AM
    JonnyBb
    Arkansas
    Bugger dumb the last of academe
    Occam razor makes the cutting clean
  18. Aug 8, 2014 at 6:09 AM
    Yota64
    My bad :eek:
    Good info right there!! Sounds like I need 885s or 887s in the future
  19. Aug 8, 2014 at 6:20 AM
    Wiggins
    Jacksonville
    887 specs:
    OME 887 (16.5mm bar dia)(400mm 15.75in free height)(9.8 #turns )(4.7kg coil weight)(Rate: 590 lb/in 103 N/mm)
    They were originally specified as 4Runner springs. I was going to run armor and asked for 886's w/ Top Plate Spacers to keep the full 3" w/ armor.
    YotaDan suggested that I avoid spacers, especially with the stiffer 886 springs, and suggested 887's as a solution. I paid for extended top studs on my strut assembly, so if I need to put spacers in as a means of leveling the truck out... I can do that without taking my whole front assembly apart.
  20. Aug 8, 2014 at 6:32 AM
    JSenuk
    Sherwood Park AB
    Mainly because they are a lot cheaper. I also hear the OMEs feel pretty soft compared to 5100s. I see lots of people on here run the OME/5100 combo but if the ride will be considerably better I might consider the 90000 shocks
