DCLB Manual transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vavet, Oct 21, 2015.
  1. Oct 21, 2015 at 4:52 PM
    Vavet
    Vavet [OP] Active Member
    02 BMW 525it (wagon)
    I was eagerly awaiting the 2016 Tacomas, but now that they've arrived, I realized I can't buy the truck I want. I can get close, but don't like to compromise.
    I want a double cab long bed with a manual transmission. I'd prefer 4x4, but I'd compromise on that. Is it possible to get that configuration on a 2nd generation Tacoma?
  2. Oct 21, 2015 at 4:53 PM
    TacOffRoad11
    TacOffRoad11 Well-Known Member
    Josh
    Georgetown, KY
    '18 F150 XLT
    No. The DCLB is auto only.
  3. Oct 21, 2015 at 4:54 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ^ yep
  4. Oct 21, 2015 at 4:58 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Prove to me that it is problematic. I am running urd sc stage 3 set-up and have absolutely zero issues with my transmission. Just do a manual trans swap.
  5. Oct 22, 2015 at 7:02 AM
    TacOffRoad11
    Josh
    Georgetown, KY
    '18 F150 XLT
    There are numerous threads on here with people having issues with the 6-speed. Throw out bearings and shuddering is the main complaints.
  6. Oct 22, 2015 at 7:03 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    2016 is 3rd gen this is 2nd gen thread... just saying..
  7. Oct 22, 2015 at 7:05 AM
    TacOffRoad11
    Josh
    Georgetown, KY
    '18 F150 XLT
    The OP has stated in other threads that since he couldn't get a 16 the way he wanted, a 15 was an option.
  8. Oct 22, 2015 at 7:06 AM
    ManBeast
    Zach
    Orange Park FL
    Oh, sorry. I knew i shoulda just kept it shut.
  9. Oct 22, 2015 at 7:10 AM
    Pigpen
    Dan
    Northwest Montana
    I'm a big fan of the manual trans. That said, I'd compromise on the transmission way before 4x4. The auto trans in these trucks has a great reputation.
  10. Oct 22, 2015 at 7:59 AM
    FreidTaco
    FreidTaco boost
    jeff
    TOB is a wear item, and shutter is just low engine rpm load surge. Sounds like too high of gear, with too low rpm. Operator error. Once again, nothing wrong with trans.
  11. Oct 22, 2015 at 8:10 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    2009 6 speed - ZERO problems at 59,000 miles. Would prefer a little more OD for 6th gear, but at 21/22 mpg interstate, I'm happy.
