DCLB vs DCSB weight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Sep 27, 2015.
  1. Sep 27, 2015 at 8:52 PM
    TacoJonn
    TacoJonn [OP] Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Anyone know this difference in weight between the two? I imagine it is at least a couple hundred pounds. If anyone has driven both configs in the second gen, can you comment as to whether or not there is a significant power difference?
  2. Sep 27, 2015 at 10:31 PM
    tubesock
    tubesock Well-Known Member
    A couple hundred pounds is a bit high. The curb weights in the brochure list it as a 50lb difference: 4180/4230 for the SB/LB 4x2. 4425/4480 for the SB/LB 4x4. It might seem low but the only difference is an extra 12 inches or so of drive shaft, another 12 inches of composite bed and body, and a couple 12 inch sections of c-channel frame where it is most narrow. Then the other random shit like brake lines, wires, and exhaust pipe. There is a lot of ambiguity of what is included in those curb weights. Still, that 50-60lb difference seems reasonable.
    Even if it were 200lbs, that's the difference between riding around alone or with a big passenger. I'm not sure what driving experience you can have that you'd be able to notice the extra weight. The extra length does add about 4 feet to the turning circle, and that is noticeable.
    wachuko and Wireguy like this.
  3. Sep 27, 2015 at 11:23 PM
    TacoJonn
    Jon
    Laramie, Wyoming
    Oh wow, 50 lbs ain't much. Thought it would be much more.
  4. Sep 28, 2015 at 1:08 AM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    For an extra foot of bed, and whatever lengthy components beneath....giggity.
  5. Sep 28, 2015 at 2:16 AM
    Wireguy
    Wireguy Well-Known Member
    Jim
    Jacksonville, Florida
    2000 4x4 Limited
    Stock
    I drove both a DCLB and DCSB (both TRD sport) with a salesman (Ahmir) at Arlington Toyota last Friday. I believe the difference was slightly noticeable on takeoff. However, parking the 2016 long bed seemed easier than the longbed I drove in 2008. The double cab Tundra u turned better which was the deciding factor in why I bought Tundra back then. My initial impression was the third gen longbed turning radius is much better than second gen long bed. Just my impression. Beware, I am wrong a lot.
    Can someone direct me to the turn radius numbers?
  6. Sep 28, 2015 at 2:19 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I did not notice a difference in power on the second gen. The weight isn't that big of a difference. It's mostly how it drives. Same thing in full-size. The long the bed, the wider the turns but the power is the same.
  7. Sep 28, 2015 at 2:56 AM
    tubesock
    For the third gen its 40.6 ft vs 44.1 ft curb-to-curb for the long bed.
    Second gen is 40.7 vs 44.0. They're all listed in the brochure for each year on toyotas website.
    Wireguy[QUOTED] likes this.
  8. Sep 28, 2015 at 6:35 AM
    rohelio
    rohelio Well-Known Member
    2016 Inferno DCSB OR
    Can anyone comment on the ride quality between the two? I've been told that the longer wheelbase in the dclb drives smoother?
  9. Sep 28, 2015 at 7:31 AM
    TacoJonn
    Jon
    Laramie, Wyoming
    I imagine the longer wheelbase drives smoother. Of course it will be less nimble around town and in tight areas. Usually longer vehicles make for more stable towing vehicles as well.
