DCSB 4WD Driveshaft with IEDL Polyurethane Carrier Bearing
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 1MK, May 2, 2017.
  1. May 2, 2017 at 4:43 PM
    1MK
    1MK [OP] Desert Explorer
    Southern California
    | 2005-2015 | V6 4WD | Double Cab Short Bed |
    All 3 u-joints have been replaced and have zerk fittings
    Brand new IEDL polyurethane carrier bearing. The yoke has been modified in order to return it back to it's factory location and the nut to be safely staked.
    This setup didn't work for me since I'm spring under and shimming the axle to the correct angle isn't easy to do (requires cutting and re-welding the spring perch).
    Comes with a stock spare front driveshaft portion so you can return to using a standard carrier bearing if you'd like.
    $350.00
    Located in Murrieta, CA.
    AR15xAR10 and adanfon like this.
  2. May 2, 2017 at 4:54 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  3. May 2, 2017 at 5:01 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Good setup. What ujoints?
  4. May 2, 2017 at 5:03 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    MT or AT? Is that all stock except for the carrier bearing? I recall you had some drive shaft swapping going on, if it's stock except for the carrier bearing I can pick it up anytime this week in the mornings.
    AR15xAR10 likes this.
  5. May 2, 2017 at 5:27 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    fatfurious2[QUOTED] likes this.
  6. May 4, 2017 at 10:44 AM
    1MK
    Southern California
    Sold!
