DCSB Frame CAD file
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, May 20, 2025.
  1. May 20, 2025 at 7:02 AM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
  2. May 20, 2025 at 7:05 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
  3. May 20, 2025 at 7:08 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    I saw in another thread that that was actually a 2016. Although, the rear section may be the same. Either way, I'm not sure the bed mounting points are the same on a longbed, are they?
  4. May 20, 2025 at 7:11 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    They are not, IMO you dont need an exact file to build a bed. I just designed the rear mounts and built them then measured and adjusted for the middle and fronts. I'll be taking the flatbed off today I think so if you need measurements let me know
  5. May 20, 2025 at 7:13 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    MY bed is off, so getting the spread of the bolts is no big deal. The height differences between the mounting faces is the main difference I'm not sure about. I'd like to build a mostly tubular bed. I've always been a bigger fan of round tubing from a cosmetic standpoint.
  6. May 20, 2025 at 7:14 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I can do some math to get you that.
  7. May 20, 2025 at 7:14 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    That would be killer. I'd really appreciate it.
  8. May 20, 2025 at 10:07 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    So if we call the rear most mount the 0 point. The middle mounts are +1.02" higher. Front mounts are 1.27" higher than the rear most mounts. These measurements should be good to 1/8".
    My bed is within 0.2 deg of level with the straight section of framerail underneath the cab.
  9. May 20, 2025 at 10:15 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    That's great info. Thank you! Do you know that it's the same for a short bed? Or just an assumption?
  10. May 20, 2025 at 10:17 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Ok that may have been a little confusing. Those are actual numbers I used to build mounts for my 2011 DCSB.
    fatfurious2 likes this.
  11. May 20, 2025 at 10:42 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Even better. Thanks!
  12. May 20, 2025 at 11:34 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I was going to give you mine, but realized I made a new cross member and designed mine for a 12.5x35 tire to sit on top through the bed. Mine is a bit taller.
  13. May 20, 2025 at 11:55 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    That's killer! Im usually partial to round tubing with bumpers, armor, etc. But that's nice!
  14. May 20, 2025 at 1:09 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    that was when I was building it. This is the look now... well, this is pretty clean, but you get the idea.
