DCSB Ladder Racks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USMC5711, Apr 20, 2011.
  1. Apr 20, 2011 at 10:18 AM
    USMC5711
    USMC5711 [OP] Member
    Tampa, FL
    2010 Double Cab 4x4
    So, I should be starting as a cable contractor again soon and I will need to carry a 28ft ladder on the truck. Just wondering if anyone else is doing this and if so cand I get a pic of the ladder rack you are using and specs (price, name, where you got it ect) Much appreciation.
  2. Apr 20, 2011 at 10:30 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You might want to consider a headache rack , it is much easier to carry long lengths on the rack and tailgate rather than a ladder rack .
    With a 5' bed your rack rails will be about 4'8" apart leaving you 6 ' canteleivering past either end , can you say roof dents .
  3. Apr 20, 2011 at 10:38 AM
    USMC5711
    Tampa, FL
    2010 Double Cab 4x4
    Yeah, I know its gonna be a stretch. Maybe if I ratchet strap the ladder down It might not go anywhere.
  4. Apr 20, 2011 at 10:40 AM
    Xshark
    Xshark Well-Known Member
    Michael
    Rogers, AR
    08 Taco
    Icon progressive leaf, 3-leaf pack. Bilstein 5100's on all corners, front set at 2.5" Spidertrax wheel spacers Satoshi Grille Mod
    Trac-Rac. I purchased used thru this site (about $300).
    I use it mostly to haul around a kayak, which works great.
  5. Apr 20, 2011 at 10:43 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If all you need is a rack for a ladder, a member did this set up
  6. Apr 20, 2011 at 10:45 AM
    OZ-T
    Peter North
    British Columbia
    I have a headache rack on my truck and can haul 20' lumber
    I'll see if I can find a better pic of the rack , but here it is side angle
  7. Apr 20, 2011 at 10:48 AM
    OZ-T
    Peter North
    British Columbia
    Here , ignore the plywood toolbox mock up
  8. Apr 20, 2011 at 10:48 AM
    USMC5711
    Tampa, FL
    2010 Double Cab 4x4
    Thanks for all the quick replies. Any more info on this setup like how he attached to the rails?
  9. Apr 20, 2011 at 11:01 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    look at the related posts below, the last one I believe is where I found this photo- ladders racks? maybe you can contact the member about the install details...
