DCSB - options for hauling a canoe/kayak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PoweredBySoy, Aug 4, 2015.
  1. Aug 4, 2015 at 10:25 PM
    dzcustom
    dzcustom Well-Known Member
    2015 Tacoma PreRunner SR5 V6 BRM
    I do something very similar. Prinsu roof rack with Malone J-cradles that fold down when not in use. (2) 12-foot Old Town kayaks.
    Lumberjackcoma, MadDaddy and jesurfer like this.
  2. Aug 5, 2015 at 4:44 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    You'll be fine with a simple roof rack. I do have a cap, but my bars are only about 4' apart and my 15' canoe stays put with only 2 straps.
    Forestree and FixedGearMike like this.
  3. Aug 5, 2015 at 5:10 AM
    PoweredBySoy
    PoweredBySoy [OP] Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Perfect! That's even the canoe I want lol.
  4. Aug 5, 2015 at 5:19 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    If you're not completely sold on a Prinsu rack I would suggest on looking into FrontRunner Vehicle Outfitters Rack also. I've one on my truck and wouldn't hesitate putting a kayak up there at all.
    I've got one on my truck and have been very pleased with the rack and the amount of options there are out there. Here is the kayak mount
    jesurfer likes this.
  5. Aug 5, 2015 at 5:21 AM
    Sig45
    Mark
    Maine
    Also - I've always had a midrise cap as this prevents the bow of the canoe (I have one with a lot of rocker) from hitting the truck cab roof.
  6. Aug 5, 2015 at 5:32 AM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    I love the Prinsu, but I'm open to suggestions. I'll definitely check them out. I assume no drilling? Any major issues with wind noise? Great looking truck.
    About those kayak/canoe mounts. I've seen those, but, those are meant to mount the canoe upright, correct? I don't understand that. What if rains?
    If I'm mounting on the cab I don't think I'll have an issue - with no cap in the back. Shouldn't be anything to hit....
  7. Aug 5, 2015 at 6:18 AM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    It sounds like you don't like this option but this is what I use... I will likely be going with a prinsu rack in the future and going with J-hooks for the kayaks just because this ties up my trailer hitch and I want to be able to pull a pop-up camper while transporting kayaks eventually.
  8. Aug 5, 2015 at 6:26 AM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Well, I have a tonneau cover - which I need for waterproof storage - so I don't really have access to my bed like that.
  9. Aug 5, 2015 at 6:38 AM
    Sig45
    Mark
    Maine
    Another suggestion (regardless of which rack you go with) is to buy some type of heavy duty tubing/hose to place on the rack/bars for the canoe gunwales to rest on....prevents sliding and absorbs some of the shock from bumps & bouncing.
    On my Yakima bars, I found some 1 1/8" ID hydraulic hose....I have 4 pieces about 6" in length on my bars and place it under the gunwales. I can slide them to accommodate canoes/kayaks of different widths.
    I found that that foam/rubber pipe insulation is good for a short term solution (and may work better on a flat rack as you can cut a piece and flatten it out ), but it eventually tears and needs replacement.
  10. Aug 5, 2015 at 6:46 AM
    RearViewMirror
    Craig Christ
    No drilling involved. They mount to the factory roof mount mounting points. 12 points IIRC? If you're worried about rain (even if your kayaks are on the side rain can still get in) you could always mount them upside-down.
    EDIT: There is absolutely NO wind noise with this rack unloaded. They designed it well.
  11. Aug 5, 2015 at 6:47 AM
    snowmanwithahat
    I normally have a softcover on. Just because I was rushed for time I took it off and went with this solution for this summer. I figured if I need waterproof storage it will only be for luggage (coolers and chairs can get soaked for all I care). To cover my need I just used garbage bags over our luggage or hard plastic totes. Again, I know it's not an ideal setup for you, but with the purchased bed-rack it only cost me $100 total for the aluminum scrap and single bed rack. Took a couple hours though cutting, drilling and then painting the hitch insert.
    I'd seriously look at a prinsu rack and just pad it or use J-hooks for what you're looking to do.
  12. Aug 5, 2015 at 6:54 AM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Yeah, I already found these.
    http://www.amazon.com/dp/B00BPYBG4O...TF8&colid=3VEHPHTLU1315&coliid=I39CD49OR58I81
    Expensive, but.... I also thought of pipe foam too, but figured it wouldn't last very long.
    I'm slowly coming around to that solution as well. Large totes should work for all the camping gear I don't want to get wet. This picture is inspirational:
    Especially since I really want a RTT some day. That setup even provides some level of security for those totes - which is another main reason I wanted a cap.
    But I think I'm set on the canoe. I'm now convinced a cab rack with a couple straps will be good. Thanks for the input, guys.
  13. Aug 5, 2015 at 6:59 AM
    RearViewMirror
    Craig Christ
    Exactly why I went with this set up for a RTT
    MadDaddy likes this.
  14. Aug 5, 2015 at 7:02 AM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    What bars are those?? Are there other size/options for them? That Front Runner bed rack would work great, but gdamn it's half the price of a cap lol.
  15. Aug 5, 2015 at 7:06 AM
    #35
    Sig45
    Mark
    Maine
    Save your money and go buy a couple of feet of radiator hose at NAPA.....you can cut & slice it and it will conform to various shapes.
    If you want to attach it....use some zip ties.
  16. Aug 5, 2015 at 7:08 AM
    #36
    RearViewMirror
    Craig Christ
    Relentless Fab Bars. Mine are the 8" bars (they make a 4" version but those are too short IMO). These will set the height of the RTT level with the back of the cab.
  17. Aug 5, 2015 at 7:13 AM
    #37
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Okay, I see them. So you got the 'tall's. I'm just thinking the shorter ones would provide a semblance of security (assuming I get a Pop-lock for the gate). Those look great though. Thanks. Sorry for hijacking my own thread...
  18. Aug 5, 2015 at 8:37 AM
    #38
    FixedGearMike
    FixedGearMike Well-Known Member
    Hotlanta
    13 TRD Taco OME 3 inch lift
    Leer camper
    Leer topper with factory installed (rail runners?) not sure what they are called
    48 inch Yakima bars, Yakima skybox, Yakima kayak stackers. Skybox lets me put all my wet gear up top and sleep in the bed of the truck. I'm 6 2 so it's tight with my gal but we love it. It's actually the exact opposite of the rooftop tent route....
  19. Aug 5, 2015 at 1:00 PM
    #39
    KCEllwood
    KCEllwood Well-Known Member
    Rural Maine
    2022 Lunar Rock TRD Sport DCSB 6 Sp Auto
    This is what I also use for my Old Town 146 canoe. No pics with canoe on it but canoe would slid under the tonneau.
  20. Aug 5, 2015 at 1:21 PM
    #40
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    What options would I have with this? No roof rack, and don't really want to use the hitch.
