DCSB - options for hauling a canoe/kayak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PoweredBySoy, Aug 4, 2015.
  1. Jun 25, 2018 at 7:03 AM
    #101
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  2. Jun 25, 2018 at 7:15 AM
    #102
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    A few questions, as I have a Softopper on the way and plan to put yaks on my roof:
    I assume you load the kayaks with the Softopper down?
    Are you pleased with the softopper?
    How does it do in drive-thru carwashes; do you keep it up or put down?
    Are those 8' yaks? I have a 6' for the kiddo and am debating between an 8' or a 12' for my own use (6', 220lbs, thinking the 12' will be more stable).
  3. Jun 25, 2018 at 7:17 AM
    #103
    HoulaHauler
    HoulaHauler Well-Known Member
    Andy
    Gwinnett Co., Georgia
    2013 1G3 DCSB
    Thankfully my Discovery 119k fits perfectly on the OEM rack.
  4. Jun 25, 2018 at 1:09 PM
    #104
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    The whole reason I got the J cradles was actually so I could load them with the softopper up. I tried the picture below first and was met with the issue of either needing a step ladder to load the kayaks or I had to load them from the bed with the softopper down.
    I like the softopper, for the price it's hard to beat at $700 brand new. The only thing I'm not thrilled about is how easily the window can scratch if you're not careful and you handle it or roll it when dirty. It comes with the territory, and isn't really a design flaw, its just how that material is.
    I've only ever gone through a car was with it fully up. It definitely bows slightly under heavy winds from the air dryers and I believe the soft-touch cloth is scratching the back window slightly.
    These are 9.5' kayaks. I'm a big guy at 6'1" and 270lbs and these feel plenty stable for my use. I can carry them in the bed with the tailgate down, but i cannot do that while towing or with anything in the bed. This was the only solution i could find that let me do it all.
    I load them from the side by the way... Just like in this video below. It would be tough with a truck any taller than this without some steps or sliders to stand on.
    https://www.youtube.com/watch?v=8bvy1ckjC4E
    MadDaddy[QUOTED] likes this.
  5. Jun 25, 2018 at 2:07 PM
    #105
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    Saltypickle likes this.
  6. Jun 25, 2018 at 7:26 PM
    #106
    snowmanwithahat
    Not overkill, I really need some bow/stern tie-downs as well, but i don't have a great solution just yet. I am not confident the oem rack will hold together in extremely high winds and the way I secure the kayaks to the cradle, it would basically completely come off the roof if the rack were to fail.
  7. Jun 25, 2018 at 7:28 PM
    #107
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    I tie down to the rack, the rear bed tie downs, and the hood straps I linked. I think you can see all my tie downs in the pic.
  8. Jun 25, 2018 at 7:39 PM
    #108
    snowmanwithahat
    What are you using to tie down the rear?
    My kayaks don't extend as far back as your canoe, but I'm hoping to find something that can go down to the bed and avoid interfering with the softopper while folded up.
  9. Jun 25, 2018 at 7:42 PM
    #109
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    The ropes in the back I have tying down to the rearmost tie down brackets in the bed. I just shut my tailgate on the ropes so it's kind of hard to see them in the pic with my tonneau cover. If I (you) had the cover rolled up, the bed rail cleats could be used as well.
  10. Jun 25, 2018 at 7:45 PM
    #110
    snowmanwithahat
    Really hoping to find something like this for a taco... it would circumvent the softopper.
    sioux[QUOTED] likes this.
  11. Jun 26, 2018 at 4:55 AM
    #111
    HoulaHauler
    Andy
    2013 1G3 DCSB
    I've been using the Yakima foam blocks that I had from my previous vehicle, but they don't want to easily fit over the wide cross bars of the OEM rack. Out of curiosity, did you just cut a slit down the length or did you take a length-wise section out so it'd be wide enough to fit over the gunwhales? I may try your idea next time I take the canoe out.
  12. Jun 26, 2018 at 4:58 AM
    #112
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    I just cut a slit down the length. They've worked really well.
    HoulaHauler[QUOTED] likes this.
  13. Jun 26, 2018 at 6:08 AM
    #113
    snowmanwithahat
    ditto
  14. Jun 26, 2018 at 6:48 AM
    #114
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    I should clarify - The pool floaties or "noodles" that I use are not solid, they're hollow core. So cutting the slit lengthwise opens it up to a larger gap that fits snug around the gunwales.
  15. Jun 26, 2018 at 9:29 AM
    #115
    rschoob
    rschoob Member
    Robert
    Michigan
    2015 Sport DCSB MGM
    Bilstein 6112 / 5160 OME Dakar Leaf replacement 265-70-16 General Grabber AT2 Cali Raised Ditch Lights Bed Mat Soft Tonneau Cover Weather Tech Floor Liners Fumoto Valve
    I use a bed extender into the bed of the truck. However I would really like to get the kayaks up out of the bed so I can fill it with other gear. Im debating on going roof rack with bed extender or bed extender to bed rack/bars. It would be great to have all the gear under the tonneau cover and the kayaks elevated but below the roof line.
  16. Jun 30, 2018 at 3:12 PM
    #116
    Tbell18
    Tbell18 Well-Known Member
    iowa
    2009 Tacoma Trd Sport dclb
    see build...but not a whole lot
    has anybody put two kayaks on a roofrack with a rtt on a bed rackand still been able to open the tent without moving the kayaks? Ive been looking at prinsu and frontrunner. I use Yakima jaylow kayak carrier, anybody know if these will fit on either rack?
  17. Jun 30, 2018 at 4:20 PM
    #117
    MadDaddy
    Many & varied
    Micatom33 and Blue Canary like this.
  18. Jun 30, 2018 at 4:43 PM
    #118
    Blue Canary
    Blue Canary Not responsible for any earthquakes
    Larry
    Stockton
    2015 MGM DCSB
    Pinstripes, dings, and dust.
    I have Thule roof racks for two 14' kayaks. I'm a firm believer in front and rear tie downs, so I can't have the Softopper up when running with the yaks on top. The only drawback is the Dolphin is f'in heavy and is difficult to load by yourself. I've run this setup at Courtright from the dam to Voyager Rock. It changes the center of gravity a bit having the boats so high up and on the way out last time, my wife paddled to the dam and we met her there. Turns out it takes just as long by boat or by truck.
    IMG_9313.jpg [​IMG]
    The Softopper has taken everything I've thrown at it. Drove from Stockton to Durant, OK and back no problem. It goes through the car wash up or down inside the optional sleeve. I would expect as the fabric ages I'll have to start folding it up when I wash the truck. Anyone use 303 or other UV protectant on their tops?
    MadDaddy likes this.
  19. Jul 27, 2018 at 6:48 AM
    #119
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Yakima control tower 11 bolts right on to factory hardpoint. They even include the hardware lol.
    Coupled with a standard hitch extender I can safely haul long shit now :)
    Just can’t grt into the bed while it’s on there. I plan on installing Yakima tracksnracks on the topper someday but damn those things are expensive
  20. May 27, 2019 at 10:02 AM
    #120
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    For anyone interested, I just switched to Kayaks. Now I just have to figure out how to carry a third with the tailgate up and still allow for my camper to be towed. The kayaks are 10'.
