DD SL2 Pro LED headlight bulbs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco dv, Feb 7, 2025.
  1. Feb 10, 2025 at 4:17 AM
    MrMolotov
    MrMolotov Well-Known Member
    Ples
    2022 Tacoma SR5 4x4
    None
    I just put mine in last month and they are a GAME CHANGER! Best bulbs I've had in any car so far.
    That's why DD continues to be my favorite company!
    Mad German and VaToy like this.
  2. Feb 10, 2025 at 5:27 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Congrats, you found a great way to waste $200. Almost as good as buying chewing tobacco or vapes.
    K9tacoma and wayne0 like this.
  3. Feb 10, 2025 at 5:51 AM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    How is this a waste if they work VERY well? I like these better than my old POS Alpharex lights.
  4. Feb 10, 2025 at 6:04 AM
    Barsoom
    NW GA OTP
    They work VERY well to light up things right in front of your truck and leave things further away in the dark.
    Post # 3 in THIS very thread.
    This is Crash's mega thread where he tested and MEASURED output of every imaginable light source for a 3rd Gen Taco:
    https://www.tacomaworld.com/threads/3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlights.589465/
    K9tacoma likes this.
  5. Feb 10, 2025 at 6:29 AM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    I see his post, but I'm gauging my results off of the SL2, like the OP. I notice a HUGE improvement over OEM, so that's all I'm going off of. Are they the best lights, probably not, but there is a massive difference, so to say they are a waste is a bit of a stretch. Overpriced yes, but definitely a lot better.
  6. Feb 10, 2025 at 7:22 AM
    Taco dv
    Taco dv [OP] Well-Known Member
    2020 Tacoma TRD off-road
    Compared to the older SL1’s, the SL2 pros are a huge improvement. Also, down road lighting is not a problem. I was skeptical too, knowing that the older version was very unimpressive. When I read the DD marketing for the new SL2 pros, stating that they are designed to work in a halogen projector, I said, ok, probably marketing BS, but I had to do something about the poor performance of the SL1’s I had. I was quite surprised that they actually exceeded my expectations.
    Finally someone who has actually tried them chimed in.
  7. Feb 15, 2025 at 5:53 AM
    BillyE
    BillyE Well-Known Member
    I’ll answer why I did. I’m vain and think that from outside the truck, LEDs look cooler. That’s the honest answer.
  8. Feb 15, 2025 at 6:23 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Have you noticed a lot of oncoming cars flashing their headlights at you?
  9. Feb 15, 2025 at 6:51 AM
    Taco dv
    Not one.
    t0p_d0g[QUOTED] likes this.
  10. Feb 15, 2025 at 8:42 AM
    wayne0
    wayne0 Well-Known Member
    Because they can't see the stalk thru the glare.:facepalm:
    At 70 yrs old I don't see that well at night and if I had a rocket launcher on board there would be a lot less non OEM LEDs out there. :bananadance:
    K9tacoma, Barsoom, Squirt and 2 others like this.
  11. Feb 15, 2025 at 9:37 AM
    BillyE
    the projectors still give a strong cutoff. It’s not like the cars with reflectors.
    Taco dv[OP] and t0p_d0g[QUOTED] like this.
  12. Feb 15, 2025 at 9:55 AM
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Pro
    I was in front of some dude on the freeway the other day who must have had after market lights straight out of hell. The lights were misaligned and/or the brights with a refresh rate of no more than 30 Hzeeeees, it was like a techno rave party (strobe affect) in my rear and side view mirrors ….and this was in broad day light. If there was ever a time I wanted to get rear ended…
    Barsoom likes this.
  13. Feb 15, 2025 at 11:48 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    OEM projectors are designed to have reduced light above the cut off so you can see things beyond the low beam horizon without blinding other drivers, this is called uplight and all OEM lights have it. This is yet another area where PnP LEDs perform worse. Since the direction in the projector shield for uplight is directly in front of the bulb, it requires bouncing light off the back of the projector bowl directly behind bulb (at 6 o’clock) to reflect it forward out the uplight slot in the cut off shield. PnP LEDs do not omit omnidirectional light like halogens, they emit bi-directional light at 3 and 9 o’clock, very noticeably lacking the worst at 6 o’clock. Because of this, almost no light is reflected off the back of the projector bowl (at 6 o’clock) and therefore uplight is nearly eliminated. This means less “glare” than stock but it also means much less visibility beyond the low beam cut off, very much going against all OEM lighting designs for improved visibility and safety. Instead the OEM projector performs similar to a poor cheap Chinese aftermarket projector that doesn’t supply any uplight at all.
    In short PnP LEDs do not cause increased glare in projectors, they significantly reduce it at great detriment to the OEM optics design and driver visibility. All the more reason to use the correct bulb type for the housing.
    K9tacoma and Barsoom like this.
  14. Feb 15, 2025 at 12:40 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Thanks for that tutorial ... not being sarcastic. I did not know the designed-perfomance and how that funky tiny rectangle was created with my H9s.
    crashnburn80[QUOTED] and t0p_d0g like this.
  15. Feb 15, 2025 at 1:06 PM
    #35
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Im glad I have OEM LED.
    Barsoom likes this.
  16. Feb 15, 2025 at 1:29 PM
    #36
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The rectangular uplight box was there with your stock bulbs too. With a halogen bulb upgrade the output intensity is increased in all areas of the pattern including the uplight, making the uplight box more noticeable.
    Definitely superior to any PnP upgrade on the halogen assemblies, including even the best performance bulb halogens.
    Barsoom and t0p_d0g[QUOTED] like this.
  17. Mar 6, 2025 at 12:39 AM
    #37
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    Not one
    VaToy likes this.
  18. Apr 15, 2025 at 6:21 AM
    #38
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    The SL2 Pro is a fantastic LED unit. They are head and shoulders above anything else out there, especially the "Amazon specials" that some guys use.
    Diode Dynamics puts solid engineering behind their products. I've toured their facility and it's impressive.
