ddm help...headlights
Discussion in 'Lighting' started by brutalguyracing, Jun 22, 2010.
  1. Jun 22, 2010 at 2:36 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    ok i just installed my headlight hi/lo ddm hid kit
    i could not get the bulb lined up so the deflector is on top....
    the way i have it in right now is the deflector is on bottom with the open face of bulb pointing up...
    this is not correct is it???
    the wire comes out on the top not the bottom as per the slim cubby install
  2. Jun 22, 2010 at 3:10 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    come on guys bump.....you all cant be eating dinner....
  3. Jun 22, 2010 at 3:44 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    the large opening should be facing up. allows light to reflect off the top of the reflector and down at the road.
  4. Jun 22, 2010 at 3:47 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    so i do have them installed correctly then......
  5. Jun 22, 2010 at 3:55 PM
    GEENYUSS
    GEENYUSS Well-Known Member
    Colfax, CA
    1998 TRD Off-Road 3.4V6
    Icons, SPC UCAs, Solo Motorsports Mid Travel LCA, Fox 2.0, All-Pro Exp Leafs, 285/75/17 BFG KO2s
    i just installed my h4 hi/lo kit from ddm. mine has a little static in the fm radio. do you notice any static on any of your fm channels when your lights are on?
  6. Jun 22, 2010 at 4:35 PM
    Tdup
    Tdup Well-Known Member
    Trey
    Columbia, SC
    2021 TRD Off-Road 4x4 DCSB 6MT
    Redarc brake controller, CamLocker tool box, OEM Bed lights.
    yes you installed correctly. what happens when you flip the high beam switch the bulb actually moves up out of the hole in the middle of the shield throwing light further...or at least thats how my ddm kit works
  7. Jun 22, 2010 at 4:50 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    check your grounds. Mine didnt put off any static and i am running 3 kits and dont have a problem at all with them all on.
  8. Jun 22, 2010 at 5:00 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yeah, mine has a bit of interference when its on too... And I have slims kit
