DDM HID Need Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paczowski123, Nov 29, 2011.
  1. Nov 29, 2011 at 8:24 AM
    Paczowski123
    Paczowski123 [OP] Well-Known Member
    David
    Kennesaw
    05 prerunner trd off road
    OME 3" Lift, Kennesaw Mountain Off Road Wincher Front Bumper w/ 5" Integrated off road lights, Kennesaw Mountain Off Road Multi Carrier Rear Bumper w/ swingout tire carrier, Jerry can, and hi-lift mount, Sof-topper rear cargo cover. Galaxy DX44V CB Radio W/ 4' FireStikII, Rock Sliders
    Im ordering my DDM HID kit and i do not know what the "HID harness" is "Error Eliminator" and "Adaptor Cables" are do i need any of this?
  2. Nov 29, 2011 at 8:32 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If you are getting the bi-xenon hi-lows, it comes with everything you need, including the harness, without adding anything else to your cart.
  3. Nov 29, 2011 at 8:32 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    Which kit are you ordering?
    HID Harness: (I would purchase this if you're gonna use the HID kit on an ATV. If you get a Hi/Low kit, it comes with the HID harness)
    Use this relay harness to connect HIDs to cars with very small gauge wiring that cannot supply the initial surge current required to light the bulbs reliably. Symptoms indicating the harness is required would be intermittent starting or lights going out after being turned on for several minutes and requiring you to turn the lights off and back on for them to turn back on again.
    Recommended for all 55W HID installations but most American and European cars work at 35W/55W without the harness. The harness is definitely recommended for Quad's and other ATVs or when running multiple HID installations. This harness is a fused relay isolation harness capable of supplying 20A at 12vdc.
    Error Code Eliminator: (Not needed on out trucks b/c we don't have a headlight out indicator light)
    Some cars will generate a bulb out warning message or even turn the headlight/foglights off when connecting HID to them. Our cancellation modules fool the computer in the car and allow the HIDs to work flawlessly
    Adaptor Cables: (Our trucks run H4 headlight bulbs, and H10 fogs. Tacoma's don't have a DS2 bulb).
    Accessory cables to connect general purpose HID ballasts to D2S Bulbs
  4. Nov 29, 2011 at 8:33 AM
    tacoapw
    tacoapw Member
    Northeast
    2011 TRD Sport Access Cab
    35 Watt 6000K HID's, Westin Bull Bar, Westin Step Bars, PIAA 540 Driving Lights, Uniden PRO520XL CB
    Short answer: No.
    Everything you need for the install is included, at least it was when i put them in about 4 month ago
  5. Nov 29, 2011 at 8:34 AM
    Paczowski123
    David
    Kennesaw
    Ok thanks guys i figured so, they should really explain what that stuff is in order to make check out a little easier
  6. Nov 29, 2011 at 8:35 AM
    Bishop2Queens6
    SoCal
    2009 DCSB MGM
    DDM tuning does explain what it is in the product description. That's where I got all the info.
  7. Dec 24, 2011 at 10:49 AM
    Cajun1
    Cajun1 Well-Known Member
    Brooks
    Abbeville, LA
    Brush Gaurd 265 Destinations 5100's @ 1.75 LED Lighting Center console Home made Saatchi DDM 5K HID
    MY DDM kit that i installed the other day has not impressed me...my lights all work when i turn my truck on but shortly after at least two of them will stop working...buncha bullshit
  8. Dec 25, 2011 at 7:19 AM
    Cajun1
    Brooks
    Abbeville, LA
    H4 Hi/lo 35watt 5000k and h10 35watt 5000k for fogs
