DDM Kit who has one ?
Discussion in 'Lighting' started by bellassaiw10, Aug 11, 2011.
  1. Aug 11, 2011 at 6:43 PM
    bellassaiw10
    bellassaiw10 [OP] Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Whos got a hid kit from ddm ive got another cheap hid kit that cost a ton and they just crapped out so im about to order some ddm's and was wondering what everyone thinks of them :confused:
    Yes I know a retrofit from trs is the best choice but I dont have the cash right now for the full retro haha
  2. Aug 11, 2011 at 6:51 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    I have a few sets. Their customer service is lacking though. Skip the plug and play kits and just save for a retrofit. HID glare sucks
  3. Aug 11, 2011 at 11:30 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    had them on my Jeep. never had any problems with them
  4. Aug 11, 2011 at 11:35 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    i have them also in 4500k they are very bright i mean REALLY bright. they produce alot of glare. i am saving the money to do a retrofit now so keep that in mind retro fit is top line
  5. Aug 12, 2011 at 4:16 AM
    bellassaiw10
    Currituck NC
    Yeah I've been talkin to matt at trs and im deff doing retrofit after the next pay check but for now ddms will work
  6. Aug 12, 2011 at 4:21 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i have had ddm's for 2 years about 2 months agao i had a ballast blow out called them and within a week a brand new one sitting at my door
    ddm rocks
  7. Aug 12, 2011 at 12:27 PM
    bellassaiw10
    Currituck NC
    just ordered mine
  8. Aug 12, 2011 at 1:02 PM
    bellassaiw10
    Currituck NC
    how long does ddm usually take ? realized there was only one shipping option on there
  9. Aug 12, 2011 at 3:42 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
  10. Aug 12, 2011 at 3:43 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    mine took 3 days
  11. Aug 12, 2011 at 3:46 PM
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    i have, theyre alright...
  12. Aug 15, 2011 at 10:40 AM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Sleepy Hollow
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    Ive got a 55W 6000k set. Not bad only issue is the drivers side dosent aways turn on the first time, needs to have the headlights switched off then on again and that usually does it. Ive also found them hard to adjust, but that could just be from the reflective housings. Def getting projectors though and i wont go above 5000K
  13. Aug 15, 2011 at 1:45 PM
    bellassaiw10
    Currituck NC
    My old ones had that problem and a relay fixed it but I think the ballast may have been bad the whole time
  14. Aug 15, 2011 at 1:49 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    What exactly is the difference between a regular HID kit and a retrofit?
  15. Aug 15, 2011 at 2:11 PM
    PcBuilder14
    Brent
    Nor Cal
    I guess I'm just being stupid, but how would you do this and what would be the reason for it? Sorry for threadjacking...
  16. Aug 15, 2011 at 2:53 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    this is a retro fit
    and the reason why is to get a cut off line like this, my driver side one needs a little more work.
  17. Aug 15, 2011 at 2:54 PM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Sleepy Hollow
    ^Some dont need that much cutting if any, like the minis, but you wont get the same effect if you did the TSXs or something similar.
    My passenger side makes a buzz/hum sound but never had problems with that side....could that be causing my driver side issues?
  18. Aug 15, 2011 at 3:30 PM
    bellassaiw10
    Currituck NC
    Retro fit is the 100 legal and safe way to go and is much more expensive but deff a better option like stated above a normal hid kit is just bulbs and ballasts the fit into your current housing and uses the refelctive bowl instead of a projector, retro fits can be simple ones that require no cutting or more precise ones that require cutting
  19. Aug 15, 2011 at 3:31 PM
    bellassaiw10
    Currituck NC
    Mine made a buzz noise through my tweeters in the cab and it could be the problem I would sometime have to turn them on and off to get both to fire but now one of mine are blew so I dunno if it was the ballast the whole time or not
