DDM Tuning- Can I use a 55W ballast on my 35W Hi/Low HIDs?
Discussion in 'Lighting' started by LeadFootCaliKid, Feb 27, 2010.
  1. Feb 27, 2010 at 9:28 AM
    LeadFootCaliKid
    LeadFootCaliKid [OP] It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    So I bought a 35W 5000k H4 High/low not long ago for my truck. I now want the 35W 3000k H10 kit for my fog lights. I also wish I had ordered a 55W kit of my headlights.
    Can I order a 55W H10 kit and use those ballasts for my headlights? And use the 35W ballasts for the new fog lights?
    It's pretty obvious that DDM's customer service sucks. I tried calling them before I bought the H4's about a question I had and they never answered. I tried calling them a lot recently for this question. There online support is never online. And I even tried to e-mail them but I still have not gotten a response.
  2. Feb 27, 2010 at 10:29 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    some people say no, technically it will work and it is referred to as "overpushing" a 35w bulb, and supposeably there isn't much difference in doing that and going to a true 55w bulb. Again im not sure of the longevity of the bulb either if you overpush it.
  3. Feb 27, 2010 at 10:30 AM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    BTW...when you ordered your headlight hid's from them, did it come with the harness to hook it to the battery?
  4. Feb 27, 2010 at 10:32 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    just to clear things up, ALL OF DDM TUNING'S BULBS ARE RATED FOR 55W BALLASTS. So yes you can use the 55w ballast on your bulb. That info is somewhere on their website.
  5. Mar 3, 2010 at 7:10 AM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    I ordered the hi/low kit and it came with it's own harness. I had to also order the relay harness.
    Thanks. I searched their site again and found that info. Their bulbs are rated at 60watts. Thanks for the help.
  6. Mar 3, 2010 at 7:22 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Well i'm not too sure about HID but for HQI bulbs which is very similar its ok to use a larger ballast on a smaller wattage bulb but it is not ok to use a lower rated ballast on a higher wattage bulb. So if it is the same you can user the new 55watt ballast on your 35watt bulb but you can not use the old 35watt ballast on the newer 55watt bulb. Also for HQI bulb, if you use a larger ballast the bulb will not overdrive to burn brighter it will still burn at the same wattage it did before.
  7. Mar 3, 2010 at 8:33 AM
    jusmac
    jusmac Well-Known Member
    HID bulbs have no wattage rating (even though i know it says on most bulbs), the ballast and igniter combo regulates that wattage, so the same bulbs can be used for a 1w ballast or a 100w ballast.
  8. Mar 3, 2010 at 3:26 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Intresting....not that i don't believe you because it makes perfect sense...but where did you figure this out from?
  9. Nov 29, 2010 at 12:37 AM
    devil
    devil Member
    Sunnyvale, CA
    technically, 55w hid also can work, and the hid color is more brighter than 35w hid.... anyhow, cuz of its high wattage and more heat generated ...some melting issue happened once....no one can give a correct number about the longevity of 55w hid bulbs....
    so you'd better stick with vvme 35w HIDs and stay away from ddm sucks customer service...not easy to get through with them... that is why one of my friends threw away his ddm hid after he got defective ballasts and no answer from them...their cheating lifetime warranty...
