DDM Tuning HID
Discussion in 'Lighting' started by macftw85, Nov 15, 2009.
  1. Nov 17, 2009 at 1:26 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    This is not completely true. The closer to true white the higher the light output. The 4500K is very close to true white and therefor will have the highest light output given the wattage. 3000k is a lower color temp and has no where near the light output of the 4500K. The key here is to adjust your headlights after installing the kit.
  2. Nov 17, 2009 at 6:32 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I made 2 L shaped brackets to hang them off existing bolts for AC line bracket on one side & off one of the fuse box mounting brackets on the other side in my car. They had the plastic clip-ins for each ballast.
  3. Nov 18, 2009 at 11:15 PM
    macftw85
    macftw85 [OP] Member
    Houston, TX
    2008 Tacoma (Base Model)
    after much debate, i think ima go with the retrofit projectors for my HIDs. can anyone point me in the right direction to get this started. i know i dont want the ones sold on ebay because they look kinda ricey, in my opinion. if i could use my stock housing and retrofit the projectors in those would be great. thanks.
  4. Nov 19, 2009 at 8:43 AM
    macftw85
    Houston, TX
  5. Nov 19, 2009 at 8:53 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Interesting, might have to scoop up a pair at this price!
  6. Nov 19, 2009 at 1:32 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
  7. Nov 30, 2009 at 3:26 PM
    MWilliamson
    MWilliamson Well-Known Member
    GA
    09 PreRunner SR5
    Pioneer AVIC X710BT
    Installed my set tonight, but it started raining so I didn't get any pics. It looks like I'll need to adjust them tomorrow. Anyone able to get weather seals on with these?
  8. Nov 30, 2009 at 3:36 PM
    PreRunnerSeth
    Apex, NC
    Weather seals on with what? if you're talking about the Hi/lo kit then you need to separate the bulb from the shield part. mount the shield in the housing then install the rubber covers. then put the bulb in the shield and twist to lock it in place.
  9. Nov 30, 2009 at 3:49 PM
    MWilliamson
    GA
    09 PreRunner SR5
    Pioneer AVIC X710BT
    yea that's what i'm referring to. It didn't look like the bulb would go through the opening on the rubber cover, i'll try it again tomorrow.
  10. Nov 30, 2009 at 4:00 PM
    PreRunnerSeth
    Apex, NC
    It helps to take the time to take the headlights out.
  11. Dec 1, 2009 at 7:30 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    I was wondering about this question as well. Anyone else get the wiring harness?
  12. Dec 1, 2009 at 8:58 PM
    PreRunnerSeth
    Apex, NC
    Wiring harness is included in the Hi'Lo Kits. but, not in the regular kits. they are made to plug directly and run off your factory wiring. So i suppose you could say they come with the harness to plug them into the factory wiring. but not an additional harness like the hi/lo to connect it to the battery with a relay.
  13. Dec 2, 2009 at 4:11 AM
    tim920
    Tim
    Boston, MA
    Thanks for clearing things up! :)
  14. Dec 2, 2009 at 6:10 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I'm thinkin the reason the battery harness comes with hi/los is the same as the reason you should use it with the 55w single beam kits....the 55w startup voltage most likely is what melts wiring without the battery relay harness. IIRC, the hi's in the double kits = 55w, right? 35w lo only kits aren't as bad in that respect & the relay harness is mostly safeguard extra protection. That being said, I did opt for the relay battery harness on the 35w kit on my car due to somewhat known weak wiring...just in case
  15. Dec 2, 2009 at 8:10 AM
    #35
    PreRunnerSeth
    Apex, NC
    It comes with a harness because the relays and such are necessary to run the solenoids that switch between high and low beams. HIDs only draw excess current on initial spark where they draw a significant amount of current. But, the stock wiring can handle this spike in current quite well. its only about 300mS and doesn't even blow the fuse. The fuse will go before the wiring melts its specifically designed to do this. people who are experiencing melting wires are most likely doing something wrong or have a direct short happen where wiring can burn instant before the fuse blows. I have a HID flashlight design I've been working on for a few months sitting on my desk with plenty of scope shots to show what happens on start up.
  16. Dec 2, 2009 at 8:29 AM
    #36
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    How about adjusting your dam lights so you don’t blind everyone in front of you?
  17. Dec 2, 2009 at 9:10 AM
    #37
    tim920
    Tim
    Boston, MA
    Yeah.....how do you aim/adjust headlights?
  18. Dec 2, 2009 at 9:12 AM
    #38
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I just ordered a set to retro fit into my hella 500s!
  19. Dec 16, 2009 at 12:10 PM
    #39
    tim920
    Tim
    Boston, MA
    Just to be on the safe side. If I buy the regular kit that's NOT Hi/Lo, I can still use my Hi beam and it'll just be the same thing as if I never bought HID, right? Then when I switch back to Low it'll be using the HID again, right?
  20. Dec 16, 2009 at 12:40 PM
    #40
    tim920
    Tim
    Boston, MA
    Thank you much, sir. Why would they even sell just the low so you would have no HI? :confused:
