De-badged & painted them
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Infra, Jun 18, 2010.
  1. Jun 18, 2010 at 7:15 PM
    Infra
    Infra [OP] Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I'm sure most ppl know how to do this and there are tutorials somewheres...but figured I would document my little mod anyways. I de-badged the taco and used some krylon fusion flat black to paint the badges. I cleaned the badges with alcohol and then wiped them down again and sprayed them up. I used an entire can and I was able to apply 4 coats with 10 - 12 minutes in between each coat. I also decided not to re-use the sr5 and v6 badges and in their place I would mount a 4x4 badge from the tail of a tundra.
    Took about 2 hours overall to remove the badges with a heat gun and remove all the glue.
    After 4 coats of krylon fusion flat black
    Put 3m double sided exterior tape on the back sides of the badges and then re-applied the badges
    What do ya think?
  2. Jun 18, 2010 at 7:16 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    looks good!! :thumbsup:
  3. Jun 18, 2010 at 7:17 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    I like the 4x4 looks sick!
  4. Jun 18, 2010 at 7:23 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Very nice! I plan on doing this eventually.
