Deactivating the Atkinson cycle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doggman, Dec 23, 2015.
  1. Dec 23, 2015 at 2:48 PM
    highwhey
    highwhey Well-Known Member
    Alan
    Phoenix
    2016 Tacoma OR m/t
    Someone with deep pockets should do a 2jz swap.
  2. Dec 23, 2015 at 2:55 PM
    highwhey
    Alan
    Phoenix
    2016 Tacoma OR m/t
    A 3rd gen tho
  3. Dec 23, 2015 at 5:23 PM
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    to less horse power why its a dinosaur
  4. Dec 23, 2015 at 9:28 PM
    RD52
    RD52 Well-Known Member
    Rich
    2016 MGM TRDOR DCSB 4x4
    Yeah, the motor is fine. The tranny though...that could use a little re-mapping.
  5. Dec 23, 2015 at 11:29 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    LS SWAP
  6. Dec 23, 2015 at 11:37 PM
    mxwrench
    mxwrench Well-Known Member
    Brian
    Hi Desert, So Cal
    2016 DCSB TRDOR 4X4 JBL SW
    Doggman, here is an interesting bit of information. May help to clarify things a bit. I'd be inclined to look into the ACIS (Acoustic Controlled Intake System) and its timing before I'd try and disable the quasi Atkinson cycle. Although I really don't think its doing us any favors in the power dept. Typically the energy that the Atkinson cycle is utilizing for efficiency we would normally use to aid in performance by way of valve overlap and scavenging, but sadly that is not a green concept. Have a look at the bore and stroke of this engine and see how immensely oversquare it is, there is no doubt that it want to perform best in the higher rpms. This engine is really just a big motorcycle engine. However, there is nothing wrong with that once that fact is accepted and we treat it as such, I'm sure there is plenty of untapped power hidden in this engine. I say, lower the compression to 9:1 and boost it 25psi and let her eat!
    muddytacos and Doggman[OP] like this.
  7. Dec 24, 2015 at 3:21 AM
    .28
    .28 TacoRunnerCamry
    miguel
    Texas
    2016 TRD Offroad DC 4x4
    :headbang:
  8. Dec 24, 2015 at 3:52 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If low end power is your goal go diesel.
  9. Dec 24, 2015 at 7:13 AM
    lamia2super
    lamia2super Well-Known Member
    Frank
    Miami Beach, FL
    2016 Tacoma TRD Off-Road, (sold) 07 Tacoma xRunner
    not sure why you want to disable it but maybe a piggyback unit can help with that....something like how the ucon works
    12TRDTacoma likes this.
  10. Dec 24, 2015 at 7:38 AM
    ToyFXR88
    ToyFXR88 Well-Known Member
    WI
    2016 MGM DCSB TRD Sport 6MT
    I admire your dreams, however as stated previously, you cannot tune Toyota computers like that, not even with the software we have here at the dealerships.
    Doggman[QUOTED][OP] likes this.
  11. Dec 24, 2015 at 7:54 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Your 550+ HP G8 is also much lower to the ground than your TRD OR and has a different aerodynamic profile than the truck as well. Hence the awesome MPG for a V8.
    I do miss the additional MPG my GTO used to get at 450 HP.
  12. Dec 24, 2015 at 8:56 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    you don't say? My lowered G8 and lifted Taco don't have the same aero; news to me.
    12TRDTacoma[QUOTED] likes this.
  13. Dec 24, 2015 at 12:18 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The more you know..
    Aussiek2000[QUOTED] likes this.
  14. Dec 9, 2022 at 2:04 PM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    zero benefit? hardly. this cycle is probably to blame for every single engine failure as a result of burnt valves. atkinson cycle is not all it's cracked up to be and really only reduces power, thankfully it's not really an atkinson cycle engine, all it really does is overlap intake/exhaust valves, a true atkinson cycle engine would have some super complex (and unreliable) crankshaft...oh toyota's design of overlapping valves is supposed to be like an egr valve except it doesn't do that for some reason...sure it's mostly only during cruise or idle...not heavy throttle...but it's not good tech and is best turned off. I think ovatune disables it or at least alters its functionality to basically make it disabled...don't quote me, I couldn't find anything on that officially. either way, atkinson cycle 3.5's are best with that cycle disabled
    bulalo likes this.
  15. Dec 9, 2022 at 2:44 PM
    #35
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    I never ceased to be f*-#ing amazed with some of the things I read on this forum.
    :bowdown:
