Dead 3rd gen engine while off roading.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreshMexicanTaco, Jul 4, 2019.
  1. Jul 4, 2019 at 6:35 PM
    #141
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    They were not perfect I agree but most of what you mentioned was after some time/mileage and not delivered pre-sh!tty with hoods not glued (problem since 2016) and the same people who can't figure out how to glue a hood together are filling your AC system and transmission with oil. Toyota is trying to be General Motors of the 90's and live on reputation alone, lets see how that works out for them.
  2. Jul 4, 2019 at 6:55 PM
    #142
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    How much angle are we talking about here?
  3. Jul 4, 2019 at 7:13 PM
    #143
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    Wow that thing smoked on that slope in a mere 47 seconds!!
    :eek:
    What's interesting is that Ford accounted for this in the Global Ranger which is a diesel. Check out the 1:00 mark in this video where they explain the oil pressure precautions for steep inclines.
    https://youtu.be/57TlaWZ-8U0
    Hopefully they accounted for this in the NA Ranger's 2.3 Ecoboost.
    Bus007G likes this.
  4. Jul 4, 2019 at 7:13 PM
    #144
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Hella
  5. Jul 4, 2019 at 7:25 PM
    #145
    Taco47
    Norcal
    2016 2TR 5-Speed
    And you wonder why no one listens when you open your mouth.
    SandyTaco4x4 and suaveflooder like this.
  6. Jul 4, 2019 at 7:48 PM
    #146
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Oh no you didnt...
    oconnor[QUOTED] likes this.
  7. Jul 4, 2019 at 7:49 PM
    #147
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    You must be deaf dumb and blind. Read a little and you'll learn something.
    Taco47[QUOTED] likes this.
  8. Jul 4, 2019 at 8:04 PM
    #148
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Some of us have rear air lockers, some even front lockers.
  9. Jul 4, 2019 at 8:07 PM
    #149
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I've never heard of oil starvation issues with any vehicles on incline's until I saw this. But it does make sense. I've only ever had one other off-roader which was a 93 xj... Going through some local trails we have some pretty decent inclines which of course you have to pose for some sweet photo ops for a couple minutes at a time, never had any issues or oil pressure warning lights come on with the Toyota or Jeep. This is good to keep in mind for the future though.
    Dryfly24 likes this.
  10. Jul 4, 2019 at 8:34 PM
    #150
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Going legal unfortunately will not net the desired results. In their legal speak they only want you to remain on the road. There are some scenarios where on the road you might encounter extreme angles but most likely not for a long duration of time. But im not a lawyer. Sadly we will continue to see events like this as (please don't take this the wrong way) Toyota put a car engine in a truck. There are some ways to work around this. 1st and cheapest is that a catch can could work, to a point, depending on the volume it can contain however a catch can was mostly designed to handle low volumes of vapor. So a large volume catch could work then one problem to overcome is how to return the oil back into the pan to avoid an low oil situation. 2nd and most preferred solution would be a oil drain back from the cylinder heads. I would expect the rear most cylinders to be the first smokers when going up hill. So I would tap the back of the heads with drains with a dedicated line to the oil pan. This However would be expensive and labor intensive and would void any warranty from Toyota. A 3rd option is a engine swap, be it a 1gr, 3ur, is, diesel etc. Or have a @Torspd engine that runs forever on jb weld.
    Torspd likes this.
  11. Jul 4, 2019 at 9:23 PM
    #151
    Taco47
    Norcal
    2016 2TR 5-Speed
    aww there you go keep it up
  12. Jul 4, 2019 at 9:27 PM
    #152
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    :anonymous:
    Junkhead[QUOTED] likes this.
  13. Jul 4, 2019 at 9:56 PM
    #153
    FlamingTacoBro
    FlamingTacoBro Taco Junkie
    So CA
    2012 TRD Sport 2wd DCSB Pyrite Mica
    Here's a short street near me with a 30% grade......I've gotten stuck behind a bike and had to drive VERY slow up this thing......but no problems with my 2019 TRD OR 4x4....thank goodness!
    https://www.youtube.com/watch?v=o1VxJMrh0_Q
    SandyTaco4x4 and shakerhood like this.
  14. Jul 4, 2019 at 10:20 PM
    #154
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  15. Jul 4, 2019 at 11:44 PM
    #155
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    Wouldn't honestly surprise me. Corporations don't get by by doing people favours, and not fucking people around.
  16. Jul 4, 2019 at 11:59 PM
    #156
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Annoying to watch, but good info to consider. Maybe something similar would also work on the Tacoma? It would be cool if the same vendor took on the task as the Jeep kit looks great.
    https://m.youtube.com/watch?v=pzlP-ezGAMo
    shakerhood and GillyLink like this.
  17. Jul 5, 2019 at 12:14 AM
    #157
    Thaitoy
    Thaitoy 2003 3.0 turbo diesel. 6in lift w 33's
    2003 taco 3.0 turbo diesel
    6 inch lift. 33in tires 10000lb winch and shocks
    Just like the subaru wrx marketed for road racing. Subaru would market it in the different racing magazines and associations get pics of people racing and void the warranty.
    Grossomotto[QUOTED] likes this.
  18. Jul 5, 2019 at 6:11 AM
    #158
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Theres a reason theres an inclinometer in the truck that maxes at 30 degrees. 30 isn't even that steep. Ive had my jeeps damn near standing upright without issues. My truck has done it on my buddies driveway to his cabin, has a small steep section that goes around a bend and was a little slick due to snow. Probs 30-32 degrees, not bad but truck will start to kick white smoke after a lil time. I have had no issues with it, but would have no faith in it to offroad for an afternoon since most trail heads here are 30+ to enter trailhead or the areas midway have some steep hills that it should just walk up but will take a bit to get up due to the IFS and lack of real flex.. Hence creating longer periods at those angles. Supposed to be nice so Ill see if it still does it headed up there tomorrow. Challenge accepted
  19. Jul 5, 2019 at 6:23 AM
    #159
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    I’ve seen their vids before. That chick is hot but annoying as fuck.
  20. Jul 5, 2019 at 6:25 AM
    #160
    Stocklocker
    17TRDORDCSBAT
    Here I am trying to be civil. :rofl::thumbsup:
