Dead animal smell from vents
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vrbas, Mar 15, 2015.
  1. Mar 15, 2015 at 11:18 AM
    Vrbas
    Vrbas [OP] Well-Known Member
    2013 4x4 DCSB 6speed
    Just noticed the smell yesterday. It only happens when the recycle air is off and AC is off. Can't tell if turning AC on just lessens the noticeability of the smell or fixes it.
    Anyways, I checked cabin air filter, blower motor, and under the hood. It's not super strong but it's starting to stink. Any thoughts?
  2. Mar 15, 2015 at 11:28 AM
    Lv4Tacos
    Lv4Tacos Well-Known Member
    Mn
    2015 Base AC 4x4
    None
    Hmmmmm..... Just a few suggestions:
    1). Check for mice under the hood. It happened to me several years ago when I had the Colorado.
    2) Check to make sure the AC drain line is not clogged.
    3) Check to make sure the carpet is not wet and molding ( I know several people have talked about the passenger area being wet after a rain storm.)
    Good Luck
  3. Mar 15, 2015 at 11:37 AM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Did you remove the front cowling, the black plastic piece that runs the width of the truck at the base of the wiper blades and check under it?
  4. Mar 15, 2015 at 11:38 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    this
  5. Mar 15, 2015 at 11:41 AM
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
    Cabin air filter is another spot to check. Few people here have had mice there.
  6. Mar 15, 2015 at 12:51 PM
    Vrbas
    I did, didn't find anything in there, clean as a whistle.
    It's definitely coming from the vents and it ONLY happens when recycle is off.
    To reiterate, I've already checked cabin air filter and as far down in the blower as I could reach. Didn't see anything under the hood, still need to check AC drain.
  7. Mar 15, 2015 at 1:49 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    You have mildew in your vents and condensate tray.
    The dead animal smell is different from the stink of a mildew tray. If it smells like a wet sneaker, you have mildew.
    There is a spray for that to spray in your vents ... it foams up and kills off all the stinky funk smell.
  8. Mar 15, 2015 at 4:21 PM
    Vrbas
    How come I don't smell it when recycle is on? The smell starts and stops outright with that.
  9. Mar 15, 2015 at 9:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This. You got something dead under the hood. Maybe the neighbors cat.
  10. Mar 15, 2015 at 9:33 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Idk. Anyone hate you?
    There had or has to be something in the fresh air side of the
    vents. Anyway to trace the where the plastic tubes for the fresh air are or going
  11. Mar 15, 2015 at 10:50 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I'm voting for Rodents.
  12. Mar 16, 2015 at 8:26 AM
    Vrbas
    Under the passenger side windshield wiper is the duct that goes straight into the cabin air filter (can even see the filter). Are there any other intake areas under the hood?
  13. Mar 16, 2015 at 9:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is it. Pull that plastic cover off and take a look.
  14. Mar 16, 2015 at 9:56 AM
    mikevee
    mikevee Well-Known Member
    Socal
    14 prerunner trd offroad
    Whats it called?
  15. Mar 16, 2015 at 9:58 AM
    Mongo1958
    Mongo1958 Well-Known Member
    Van
    Newnan, GA
    2015 Bright White Access Cab w/convenience pkg.
    Carbon filter removal. Intermittent Wiper Stalk. Cruise Control. Fog Lights.
    I think you got your wish. There is a rat in the white house.:D
  16. Mar 16, 2015 at 11:04 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is no rodent. That is an @sshole in the white house.
    I would prefer a Rodent.
  17. Mar 16, 2015 at 11:05 PM
    OZ-T
    Peter North
    British Columbia
    Enjoy your short stay on TW
    winkel likes this.
  18. Mar 17, 2015 at 2:18 AM
    Mongo1958
    Van
    Newnan, GA
    Ive heard of small critters getting into the air filter to the engine. :cool:
    Just a thought:burnrubber:
  19. Oct 10, 2018 at 5:40 PM
    Samc
    Samc New Member
    TForce Package
    I have the same problem. Found this thread and was hoping to find the answer. What did you find and where?
  20. Oct 10, 2018 at 5:53 PM
    R490
    R490 Well-Known Member
    Upgrayedd
    VA
    This thread is super old, I'm not even sure if that guy is active anymore.
    Remove your cabin air filter and inspect it, then remove the wiper cowl to inspect that. Once both of those are done, remove the A/C Evap core (access under dash, you don't need to remove anything.)
    Then, if you don't find any gross shit where it doesn't belong, spray a can of Lysol into the wiper cowl with the AC running in the truck.
    Good luck! Let us know if you have any questions, I've had/do have the same issue.
