Dead battery after 1yr/10K Miles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mryellow66, Sep 7, 2015.
  1. Sep 7, 2015 at 11:23 PM
    mryellow66
    mryellow66 [OP] Member
    Hey Everyone,
    I just want to see if anyone heard of this problem or experienced it.
    I have a 2015 TRD Sports with 10k on it. My truck had problems cold cranking and so I brought it into the dealership for service. Dealership said the battery was dead, and something about semi-conductor on the battery is defective, and they replaced the battery.
    My understanding is that battery last 5-6 yrs. My truck is one year old. I am hoping it not something else down the line when my warranty has expired.
    Anyone experienced the same or know why battery would died in one year?
    Any input would be appreciated.
    Thanks.
    T
  2. Sep 7, 2015 at 11:31 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    probably just a defective battery. i wouldnt worry too much about it. it happens
  3. Sep 7, 2015 at 11:40 PM
    mryellow66
    Yup, with is semi-conductor on battery? Thats what is stated on work order sheet.
  4. Sep 8, 2015 at 1:06 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Doesn't matter.
    If they tested the battery and found it defective, it doesn't matter if the tech incorrectly used a nine-cent word to describe the problem.
    However, if it's actually a different problem and they misdiagnosed, you still have plenty of warranty time left for the problem to show itself and the dealer to be able to correct it.
    It's either fixed or it's not. No need to worry that it's lurking silently, waiting to reappear years later.
  5. Sep 8, 2015 at 1:13 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Call a local alternator shop and see if they do free charging test; many will. They'll test your alternator and battery to see if it's in working order. Take your work order and see what they say about that semi-conductor.
  6. Sep 8, 2015 at 3:33 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    "semi-conductor on the battery". What kind of BS is that. Probably just a bad cell in the battery.
    DustStorm4x4 and DoorDing like this.
  7. Sep 8, 2015 at 3:34 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Yep, had one die on a Ford in 9 months. Lucky that I had boat with me and was able to pull one from it to get me home. On a Sunday so I had to replace on my dime.
  8. Sep 8, 2015 at 3:53 AM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    My factory battery died pretty quick as well, I have read on here of people with 12's and up having there batteries go out. Good thing I was under warranty but sucks when a truck so new leaves you stranded.
  9. Sep 8, 2015 at 3:58 AM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    The dealer "Should" have to do a complete charging system diagnosis when condemning a battery. At least they required it when I was a Lexus tech.
    It load tests the battery, checks cranking draw, alternator output, and diodes. He should be good if it condemned the battery.
  10. Sep 8, 2015 at 6:52 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You can submit the reciept for that battery purchase to Ford and you will be reimbursed
  11. Sep 8, 2015 at 6:56 AM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    My 2013 battery died also really quickly. I think the Toyota batteries are just garbage and are basically designed to just get you out of the warranty period.
    I replaced it and moved on.
  12. Sep 8, 2015 at 7:07 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I'm not sure how long, but the battery in my dad's 09 exploded just a couple of years after he bought it.
  13. Sep 8, 2015 at 7:40 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OEM battery are not really sealed, so living in warm climates the fluid level in the battery will often drop. You can top it off with some distilled water rather easily.
    DoorDing likes this.
  14. Sep 8, 2015 at 9:52 AM
    mryellow66
    Thanks.
  15. Sep 10, 2015 at 5:03 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    I bet the "semi-conductor" that failed were diodes in the alternator that caused the battery to be undercharged. If this was the case, the actual battery failure was caused by an accumulation of lead sulfate on the plates gradually reducing the battery's CCA performance and capacity to the point it would no longer start the engine. As an aside, battery explosions do occur when the electrolytes levels drop below the plates in wet car batteries. A spark can be generated in a "tree" between the positive and negative plates while starting the engine that ignites the residual hydrogen gas as a by product of normal charging. It is important not to allow the levels drop below the top of the plates, especially in hot climates.
