Dead battery or more serious??? Taco wont crank.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by guitars&tacos, Sep 4, 2011.
  1. Sep 4, 2011 at 6:51 PM
    guitars&tacos
    guitars&tacos [OP] Well-Known Member
    North Metro Atlanta
    Black 08 Prerunner TRD
    Minimal- iPod adapter and window tint.
    I drove my Taco over 100 miles yesterday and parked it and didnt crank it for a full 24 hours until just now. I turned the key and the video is what you see. I didnt think much of it until I went to jump it off with my wife's car and absolutely nothing.
    I did notice that one time I opened the door and barely got any interior lights and the next time I did. I thought it to be strange that jumping it off didnt help.
    The battery terminals are all clean and have never had one minutes trouble from the truck. All the auto parts stores are closed so there is no way for me to have the battery tested tonight. I'm all worried there might be some weird electrical problem. I sure hope not!!! Hopefully someone else here has experienced this to be a dead battery. If not I fear bad news.
    Any other pointers to check this?
    http://www.youtube.com/watch?v=aHmbRp9dkFo
  2. Sep 4, 2011 at 6:55 PM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    Check grounds. Don't think a dead battery would flicker like that.
  3. Sep 4, 2011 at 6:57 PM
    guitars&tacos
    North Metro Atlanta
    After checking the blacks on the battery where would I start?
  4. Sep 4, 2011 at 6:59 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    remove wires from battery then follow them...both of them....clean accordingly
  5. Sep 4, 2011 at 6:59 PM
    RCBS
    Appalachia
    06 Main Runner OR
    Follow ground wire off battery. Maybe loose? Did you ground battery cable to terminal or frame when jumping? Check underhood fuse panel for loose or burnt relays or fuses.
  6. Sep 4, 2011 at 6:59 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    Check the ground. To the right of the battery, on the side beneath the hood. Mine was lose and it caused my truck to die and not want to jump. Tightened it up and never had another issue.
  7. Sep 4, 2011 at 7:19 PM
    guitars&tacos
    North Metro Atlanta
    UPDATE JUST NOW:
    I removed the wires from the battery, cleaned and tightened. I was excited when I got in and turned the key and got all lights like normal. I then turned it over and click, clunk and nothing!
    I wonder if my starter is dead and causing this?! CRAP! I measured my battery with my DMM and it read 12v.
    I dont even know where the starter is for the ol' tap "fix".
    Any more help fellas?
    http://www.youtube.com/watch?v=XmmIOmdnk8I
  8. Sep 4, 2011 at 7:25 PM
    RCBS
    Appalachia
    06 Main Runner OR
    Try jumper cables again. Ground off on oil catch lip around filter.
    If you get it running, check alternator output.
  9. Sep 4, 2011 at 7:32 PM
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
    I'm 99% sure the battery is toast. Can you remove the battery from your wifes car and try it in your truck or is it a different post setup? If your battery is toast it won't make a difference if you use jumper cables.
  10. Sep 4, 2011 at 7:36 PM
    guitars&tacos
    North Metro Atlanta
    This is my hope. Her battery is weird so I will unfortunately have to wait until tomorrow.
    Wonder why it freaks out electrical when I try to crank and then seems to reset until I crank again after removing the terminals and retighten?
  11. Sep 4, 2011 at 7:36 PM
    RCBS
    Appalachia
    06 Main Runner OR
    This is what I'm getting at, but easier to use cables than changing battery. 3 years? Not very good longevity for a True Start...especially a 27F.
  12. Sep 4, 2011 at 7:37 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Yea I got airborne in my truck and it did the same thing. Ended up having a bad cell in my battery. Would read good volts but would not take a load. Dash showed same symptoms
  13. Sep 4, 2011 at 7:39 PM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    if the batt reads 12v just sitting there, measure the voltage when you try to start it. If it drops to single digits when cranking, you may have a dead cell in the batt. Sometimes they just randomly short out across the plates inside the batt. Happened to me twice.
  14. Sep 4, 2011 at 7:51 PM
    guitars&tacos
    North Metro Atlanta
    GREAT idea! I just had my wife help me w/ this experiment. The battery read a constant 12.70 when idle. I had my wife try to crank as I was still measuring DC voltage and the voltage dropped to 2.xx then stayed at 3.xx while she was trying to crank.
    I really hope its a dead battery still. I just spent all my spare cash on a new home HVAC system- $4,000!!! :-(
  15. Sep 4, 2011 at 7:57 PM
    pootermobile
    Florida
    No problem. Always happy to help someone out. Replace battery, continue fun:)
  16. Sep 5, 2011 at 8:06 AM
    guitars&tacos
    North Metro Atlanta
    Well fealls....it was just the battery as I had hoped. I was thrown because I have never had a dead battery act this way in a Tacoma. I have owned 3 of these trucks and have replaced 3 batteries. Again, never acted this way!
    I knew nothing would break on a Tacoma with only 54,000 miles. :)
  17. Sep 7, 2011 at 6:18 PM
    Bens MBL TACO
    Bens MBL TACO Well-Known Member
    San Diego, CA
    07 Prerunner Rumbler
    AFE Air Intake, Billy 5100's up front set at .85 with top plate and lean spacer, Eibach coils, Bilstein 5160's rear shocks, Toytec AAL, TRD Exhaust, Flowmaster Super 44 Muffler, JBA Headers, 5k 35 Watt HID, 3K 35 Watt HID fogs, Anytime fog mod Fierce 265, 70, r17.
    This is why this forum and thread are great. I got stranded at Chilis last night, after I enjoyed my dinner reservations of course. When I came back to my truck this EXACT same thing happened! Dude my reaction was just like yours, never had a car do this..WTF?! Thanks for the help OP and fellow TW'ers. Guess ill be replacing my batt. now to pick a new one.
    OP what did you go with?
