Dead battery - Will Toyota warranty given my mods?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mike402, Aug 17, 2022.
  1. Aug 17, 2022 at 10:29 AM
    Mike402
    Mike402 [OP] Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Battery crapped out on my 20 Tacoma. According to dealership, warranty on the batteries are 3/36, and I'm under both as of now.
    I do have a bunch of mods to my rig including 2 light bars, a 10k winch, and an aftermarket amp for the stereo, with everything connected via a Bantam Spod.
    I wanted to just bring the battery in and swap it out, but dealer says they need the truck there in order to run their diagnostics and fulfill the warranty. I know its a judgement call, but do you think they will deny warranty based on the mods? Was hoping a service writer or previous Toyota tech might chime in.
    My plan was to eventually put in an AGM, but the allure of squeeking out an extra two years on a free battery is there. Part of me says don't cheap out and do the right thing and put in an appropriate battery for my needs, especially since I wheel and have dealt with leakage.
    AmateurTaco1313 likes this.
  2. Aug 17, 2022 at 10:32 AM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    I believe you would be fine. I think they would have to prove that your mods caused the battery to die, which they won't be able too. Stock batteries suck, and I doubt the dealer is going to care about replacing it.
  3. Aug 17, 2022 at 10:33 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    They should warranty it, but you never know if your service advisor is a stickler/dickhead/having a bad day.
    You got 2 years out of it, which is awfully short for a battery, but also not the end of the world if they make you eat it. Just make it clear that their goodwill today determines your choice of service visits tomorrow. (I mean, don't lead with that statement for cryin out loud, just have that one in your back pocket. I shouldn't even have to say this out loud, but you never know with some people.:cookiemonster:)
  4. Aug 17, 2022 at 10:35 AM
    MK212MX
    MK212MX Well-Known Member
    2022 Tacoma TRD Sport
    I'm of the other opinion. They are going to see all of those mods pulling on that battery and deny whatever prorated warranty you have left. This is why they want to see the truck. It is not the dealer that has to prove your mods caused the failure, but the other way around and you will not win that one I don't believe.
    Sharpish likes this.
  5. Aug 17, 2022 at 10:36 AM
    Mike402
    Palm Springs, CA
    Actually I purchased in Dec 19, so roughly 2.5 years, which is actually fairly common in our insane desert heat. I've dealt with this the entire time I've lived here
    Gunshot-6A likes this.
  6. Aug 17, 2022 at 10:40 AM
    Mike402
    Palm Springs, CA
    This is what I'm worried about. I mean its clear I am vastly exceeding the draw that the factory system/battery is designed around. Not the end of the world if they do deny, just go and buy an aftermarket AGM
  7. Aug 17, 2022 at 10:44 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    respectfully:
    is it even worth your time? I mean if you don't have the right battery for your demand, why not just finish the job? I'd rather buy my own and have more confidence my investment in doodads is going to work and my truck will most likely start more reliably.
  8. Aug 17, 2022 at 10:45 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Still worth a shot to see I think. A battery is cheap and its 5 minutes of labor. I'd wager that the average service guy wouldnt have a problem with it for a friendly customer. Unless they're a dick.
  9. Aug 17, 2022 at 10:54 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Ok like everything in life, your attitude and behavior can make an enormous difference. Just be pleasant and polite, if they are reasonable people and able you will drive out with a new battery. I was a service advisor. Easy going people always got the benefit of any doubt, and jerks just didn't. Any clear call is the same for everyone, but where I had wiggle room on each side of the line, well I am just like everyone else.
    BuddyS, RustyGreen and Gunshot-6A like this.
  10. Aug 17, 2022 at 10:54 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I would give it a shot but it would be easy for them to prove that the mod's could cause premature damage to the battery. They could simply add up all of the draw from every accessory and say that if you were to run every single thing at the same time it would be over the rated output of the battery. Also, they could run an ammeter in line with a new battery and say that your mods could have a parasitic draw on the system also causing the battery to go bad early. I suggest going in preparing to not have it covered in which case you can buy a new Odyssey and be happy for many, many years...and if they do warranty it out, you save a couple hundred bucks for the time being.
  11. Aug 17, 2022 at 10:57 AM
    Mister Grey
    Mister Grey The Viking of disapproval looks in your direction
    Hayward Ca
    2017 Tacoma DCLB Sport 4x4
    The Works.
    There is a thread on here about stock batteries dying at the 2 year mark. Mine included. Toyota would not warranty mine btw.
  12. Aug 17, 2022 at 11:06 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Buy a replacement battery yourself and send the bill to Toyota for reimbursement
    Tocamo and 2021SR5V64WD like this.
  13. Aug 17, 2022 at 11:16 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I don't agree. The dealer (or any shop) isn't going to diagnose a vehicle over the phone. They need you to bring it in to verify it's indeed just a failed battery, and not for example a bad alternator or excess parasitic draw.
    perterra and stftaco like this.
  14. Aug 17, 2022 at 11:22 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I swapped my OEM battery for an AGM the second week of ownership.
    Why wait in this case, really?
  15. Aug 17, 2022 at 11:28 AM
    Mike402
    Palm Springs, CA
    You guys are 100% right, I guess I just needed to hear it. Silly to have spent a small fortune on mods and then cheap out on the battery. Calling Batteries Plus on their X2 models. Now I I need to decide on the 24 vs 27 and if the latter is worth the extra weight.
    Weights:
    OEM 24 - 42lbs
    X2 24 - 57lbs
    X2 27 - 70 lbs
    seang and Chew[QUOTED] like this.
  16. Aug 17, 2022 at 11:34 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    May as well invest in that dual battery set up you have been wanting.
  17. Aug 17, 2022 at 11:38 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I had mods on my 2017 and didn't have any issues doing a warranty claim on my battery. YMMV due to the level of "give-a-shit" your dealership has. I was instructed by Toyota corporate to have the truck checked out by the dealership before they'd refund me the cost for my new battery (emergency warranty repair, battery died on a weekend and I had to go to work. Dealership was closed at the time). The dealership didn't even know what to do so they checked that the alternator was outputting the correct voltage to the battery and sent me on my way. Easy day.
  18. Aug 17, 2022 at 11:42 AM
    Mike402
    Palm Springs, CA
    Naw I haven't really seen the need. I don't camp for extended periods of time where I need to power accessories for days at a time. Truck is always running when I've used the winch or the light bars.
  19. Aug 17, 2022 at 11:45 AM
    GoodDogRUGER
    GoodDogRUGER 2021 SR ACCESS V6 4x4
    Heath
    SOCAL
    2021 SR Access Cab V6 4x4
    6112/5160, 285/75/17 BFG KO2 , SPC, Method 703s, BMC/CMC, ARE DCU,
    My stock battery was too small (and junk) for keeping up with my little mods. Adding a fridge made it worthless. I have also had issues with Toyota wanting to warranty ANYTHING since I have modded my truck. I knew I was overloading my stock battery with a winch and fridge and other small items. It was cost of business for what I needed. I got an Odyssey AGM and had them up the voltage on the alt when I had my tune. Works awesome! I am going to get a PLB40 or something else to keep the cycles off my Odyssey and save it for winching and normal stuff...
  20. Aug 17, 2022 at 11:47 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Just buy a better quality battery better suited for your needs. Or look into a dual battery setup. If you are off roading, definitely go the AGM route to prevent the leaking.
    TS4x4 and Mike402[OP] like this.
