Dead battery - Will Toyota warranty given my mods?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mike402, Aug 17, 2022.
  1. Aug 18, 2022 at 9:21 AM
    #41
    Mike402
    Mike402 [OP] Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Agree about the risk, but December would have been three years on an oem 24F. Given the average life span of batteries out here in this godforsaken desert heat, I'm actually impressed it lasted this long. Winch and light bars are used very infrequently, and always when the truck is running. I'm comfortable going with a single AGM at this point.
    davidstacoma and blu92in99 like this.
  2. Aug 18, 2022 at 9:26 AM
    #42
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    This. Stock battery is garbage. Get a yellowtop. It always cracks me up that people spend thousands on lighting mods but won't upgrade the battery to support them.
    stftaco likes this.
  3. Aug 18, 2022 at 9:42 AM
    #43
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Thousands on lighting mods? Those must be some nice fucking lights!
  4. Aug 18, 2022 at 9:49 AM
    #44
    Mike402
    Palm Springs, CA
    Guilty as charged on the battery, but finally getting around to it now.
    Looked at the Yellowtop but here are the specs
    So the 24F X2 is smaller, cheaper, and has higher CCA & capacity than the 27F Yellow Top. Only advantage is that the Optima is 4lbs lighter. And that doesn't even get into the quality concerns that Optima has ever since moving production to Mexico. Although the auto parts guy I spoke to said he's seen more issues with Red Tops than Yellow.
  5. Aug 18, 2022 at 9:50 AM
    #45
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I made a basic battery shelf out of heavy duty angle brackets and moved my 2017 stock battery to the back corner of my engine compartment for running the accessories and used a Blue Seas charging relay to keep it topped off. I put in a large Bosch AGM up front a little over three years ago. Was out camping earlier this summer near Anza Borrego and the Bosch died, so I had to jump the truck using my 5-year old OEM battery…. That little thing was good to me- it just died recently too so I replaced it with a deep cycle AGM as well.
    Mike402[QUOTED][OP] likes this.
  6. Aug 18, 2022 at 9:56 AM
    #46
    OnHartung'sRoad
    Mike- at least get one of those small lithium quick starters- they’re pretty good when in a pinch.
    StayinStock and stftaco like this.
  7. Aug 18, 2022 at 10:10 AM
    #47
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    While I agree you're probably better off just buying yourself a better battery anyway, won't the dealer be fairly OK with just replacing it under warranty? I mean, I suspect it's easy money for them... you bring it in, they test it, they swap it out, and then presumably send a warranty claim to Toyota – which I presume sends them a check or credit for time spent on warranty work.
    Go in, be polite and upfront (without offering any negative input about why you think your lights helped contribute to the death of the battery), and see what happens. Worst they can do is say no.
  8. Aug 18, 2022 at 10:12 AM
    #48
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I believe the OP said they already said no.
    shakerhood likes this.
  9. Aug 18, 2022 at 10:32 AM
    #49
    Mike402
    Palm Springs, CA
  10. Aug 18, 2022 at 10:35 AM
    #50
    Mike402
    Palm Springs, CA
    Yea as FL_TRD Sport pointed out, dealer said no due to presence of non oem electrical components attached to battery. I probably could have tried another dealership or gone through Toyota corporate, but with the help of other peeps in this thread, came to my senses and am putting in an appropriate battery for my needs
    BuddyS[QUOTED] likes this.
  11. Aug 18, 2022 at 10:49 AM
    #51
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    We are always happy to help other people spend their money :) :spending:
  12. Aug 18, 2022 at 12:25 PM
    #52
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    What happened to having to prove your mods were the cause?
  13. Aug 18, 2022 at 12:29 PM
    #53
    Buck Henry
    Since when??? The dealership can deny warranty claims all day long due to customer mods. The owner has to prove it did not. And OP was wise not to waste his time trying to do so for a cheap ass battery.
  14. Aug 18, 2022 at 12:34 PM
    #54
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    In my understanding, the alternator is driven by the serpentine belt, and there's a clutch that regulates the speed of the alternator so that it changes the output level according to the demand.
    I imagine that clutch is electronically controlled by the ECU.
    So if you upgrade the stock alternator to a higher output one, do you have to retune the ECU to let it know and compensate the new rating?
  15. Aug 18, 2022 at 12:38 PM
    #55
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Magnuson Moss Warranty Act
  16. Aug 18, 2022 at 12:43 PM
    #56
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    https://www.tacomaworld.com/threads/ffs-lets-all-stop-referencing-the-magnussen-moss-act.609911/
    All well and good, and technically you are correct. The reality of it is the dealer will refuse to cover because of your mods and say they contributed to the failure. Once you exhaust the dealer management chain, you can go to Toyota. If they refuse then your alternative is to retain an attorney and file suit in Federal court for Mag/Moss violation. Most likely the first retainer check you wrote to a lawyer would exceed the cost of any repair, and in this case we're talking a $300 battery.
  17. Aug 18, 2022 at 12:48 PM
    #57
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Damn
  18. Aug 18, 2022 at 1:19 PM
    #58
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Yes, putting an AGM battery in these trucks requires a tune to up the output from the alternator...otherwise you are wasting money.
    malatx[QUOTED] and FL_TRD Sport like this.
  19. Aug 18, 2022 at 1:20 PM
    #59
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    Not positive but I think some vehicle manufacturers play tricks and can command the alternator via the ECU to vary output in a way to increase mileage.
    One thing I like to do is monitor the battery voltage via a cigarette lighter USB charger in another car. However, I think there are panel alternatives, and I'll probably resort to one on the truck.
    malatx[QUOTED] likes this.
  20. Aug 18, 2022 at 1:20 PM
    #60
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    The KDMax tune offers the AGM alternator output option. If you have been considering it this may give you another reason :)
