Dead/ Low Battery issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vitistop, Oct 23, 2019.
  1. Oct 24, 2019 at 10:20 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Checking and maintaning your battery is quite simple.
    VB25 and vitistop[OP] like this.
  2. Oct 24, 2019 at 6:50 PM
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    This is hilarious! Thanks for the laughs.
    VB25, 44-16 Taco, over60 and 2 others like this.
  3. Oct 25, 2019 at 1:47 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    It's extremely easy.... even you could do it. Pry those caps off.....Look in the 6 cells….. if water is not right up to the bottom of the hole you look in, then add 100% distilled water (like the shit you dump down the drain from yer de-humidifier)...bring it up to the bottom of that hole.
    If you have not done this in 4 years...you battery will need about 1 cup per cell....you have done damage to your battery at this point.
    "maintenance free" is stupidest thing I've ever heard, Regarding batteries that use water. (It result in a F'd battery prematurely)
    Like our Mtce free Tranny that comes LOW from the factory.... I had to add 1 1/2 liters to mine.
    By the way... how does Toyota get those caps off if they do not "pry". Special tool..?
    Good luck...:fingerscrossed:
    cwdog likes this.
  4. Oct 25, 2019 at 4:52 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    high five, i also had a 59 chevy..348 w/3 2's
    over60[QUOTED] likes this.
  5. Oct 25, 2019 at 6:32 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    This kind of mentality is why we have no transmission dipstick, Less grease fittings, and dishonest “Lifetime/maintainence free” marketing wank. You can bet those battery cap/vents would be glued in place if they didn’t expect top-ups. I check mine whenever I do my oil.
    over60 and cwdog like this.
