Dead Mouse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skipper124, Nov 2, 2014.
  1. Nov 2, 2014 at 7:52 PM
    el tardo
    el tardo Well-Known Member
    mice are magic, i had a locking metal file cabinet at work with no holes or any open spots and bottom was metal and i had mice get to my cliff bars.
    so some how one of those fuckers got thru a space the size of paper :eek:
  2. Nov 3, 2014 at 5:08 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Look in the cowl that's where the air comes from to the inside
  3. Nov 3, 2014 at 7:07 AM
    VenturaSuperMagna
    VenturaSuperMagna Loving Life!
    Jared
    Spring, TX
    2015 TRD Sport DCSB 4X4
    Go Rhino D2 Stainless Steel steps, Gator FX3 Tonneau Cover, in bed battery powered Led light, Pop and lock power tailgate lock, keyed locks for all 5 storage compartments, in window channel rain deflectors, front hood bug deflector, weather tech floor mats. More to come...
    Probably isn't part of the warranty however proper operation of the installed systems is and I would complain the the installed heating and A/C were not functioning properly. Let them find the problem and resolution then show me a written exclusion for the the solution in the warranty. After all the OP does not know what the cause is as he has not found and solved the problem.
  4. Nov 3, 2014 at 12:14 PM
    1 Bored Clerk
    1 Bored Clerk Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    If it's not in the blower motor (had one die in there on my first gen) then it might be on/behind/near the heater radiator?. Usually that's behind/under the radio. The heat from that radiator or the fan in your blower are the only things I can think of that would kill a mouse in the system.
  5. Nov 3, 2014 at 4:49 PM
    skipper124
    skipper124 [OP] Member
    Ohio
    SR5 2.7
    Took it into a shop today.He said in all his years there he has seen a lot of these situations and they are all Toyotas:mad: Said they would probably have to take the cowling off by the wipers and hopefully find it in that area and then epoxy a screen around the inlet to prevent future invasions.He said it would cost around 150 dollars.
