Dead Rat inside blower motor, 2001 Access cab Tacoma, 315K miles
Discussion in '1st Gen. Tacomas (1995-2004)' started by gshephard, May 28, 2018.
  1. May 28, 2018 at 9:31 PM
    gshephard
    gshephard [OP] Member
    Glen
    San Diego County
    01 Tacoma 2.7L 4WD
    K&N Intake
    After returning from a three week vacation and leaving my truck sitting neglected , the AC blower in my 2001 access cab 4x4 2.7L, made a crazy sound and the entire cab smelled horribly and the odors came from the blower. I checked under the hood and found 2 separate rat nests. Cleaned those out and then turned my attention to the blower.
    I removed the blower and discovered a dead rat inside the squirrel cage. My wife screamed and made me throw out the entire blower and the entombed rat. I obtained a new one from RockAuto.com and installed it. A/C and blower now work like new, however the entire truck is permeated with odors of dead rat, rat pee and rat feces.
    My question is: other than the engine compartment and the blower cage, where might these odors be coming from? There is no evidence that a rat or any other creature actually got into the cab of the truck.
    Looking for guidance as to what I need to clean.
  2. May 28, 2018 at 9:46 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    The smell is probably all up in the air ways behind the dash, maybe get a bore scope and try to go through all the vents and see if anything else is inside
    Area51Runner and wilcam47 like this.
  3. May 28, 2018 at 9:59 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    need to get an enzyme cleaner. where ever the "liquid" portion of the dead rat was or basically the whole area...you may not see it but it did leak some stinky fluid at some point. then dried so until its cleaned up it will be there. Febreeze the rest of the truck and run the outside air etc get as much air circulating through.
    https://www.amazon.com/Professional-Strength-Stain-Odor-Eliminator/dp/B00CKFL93K
    Area51Runner likes this.
  4. May 28, 2018 at 11:19 PM
    Glamisman
    Glamisman Well-Known Member
    and you didnt take any pictures....
    cruxofthebisquit likes this.
  5. May 29, 2018 at 6:56 PM
    ChrisTRD1
    ChrisTRD1 Member
    Oregon
    99 4x4 SR5 TRD
    Bilstein 5100s OME 551 Alcan 5-leaf
    I'd start with taking the dash apart and washing the ducting with a bleach solution. I would not want to be breathing that crap even if the smell goes away.
    It isn't as daunting as it sounds, you can have it done in a few hours
  6. May 29, 2018 at 9:11 PM
    gshephard
    Glen
    San Diego County
    01 Tacoma 2.7L 4WD
    K&N Intake
    Thanks for the responses, all were useful. I should have taken a picture of the entombed rat at least. Also, I was trying to avoid taking the dash apart but for reasons of safety I will and will bleach everything.
    Glen
    Sperrunner likes this.
  7. May 29, 2018 at 11:51 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Seems to happen all the time I get mice though not rats
    Clean the blower motor out I am good to go.
    The Skunks are more of a pain then dead rodents
  8. May 29, 2018 at 11:53 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Atleast they arnt eating your wires... that would really suck
