Dead truck after 1600 miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MSOEME2009, Oct 2, 2016.
  1. Oct 3, 2016 at 8:18 AM
    #161
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    TL;DR.
    So what's the outcome of OP's truck?
    scottalot likes this.
  2. Oct 3, 2016 at 8:22 AM
    #162
    Tacoma_Watcher
    Tacoma_Watcher Taco 4 ever!
    South
    I heard 2016 Taco have some bugs.
    I guess I have to wait for 2017 taco.
    :confused:
  3. Oct 3, 2016 at 8:26 AM
    #163
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    2017's are out, they have a lot of the same bugs.
    Kilokato, ZachMX and scottalot like this.
  4. Oct 3, 2016 at 8:46 AM
    #164
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Welcome: From under your rock.
    Kilokato, Silver02Taco and scottalot like this.
  5. Oct 3, 2016 at 8:54 AM
    #165
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    I wouldn't get a diesel that isn't from Japan, Germany, USA, or Sweden.
    Although a work truck model 4x4 extended cab Colorado diesel does sound tempting though.
  6. Oct 3, 2016 at 9:30 AM
    #166
    TejasTaco
    TejasTaco Grab a taco
    In a 4Runner, far far away...
  7. Oct 3, 2016 at 10:13 AM
    #167
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    sub'd 'cause I am really curious if it is the truly the lights that are causing this. I have HID's from ddm tuning in my headlights and fogs on my '17 OR and I have driven in rain and have had them installed for a couple weeks now with no issues (knock on wood). I want to follow to see if this is truly an issue or if this is just a real rare occasion with some owners. I also have led bulbs in my reverse & license plate bulbs too with no issues.
    scottalot and ZachMX like this.
  8. Oct 3, 2016 at 10:43 AM
    #168
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Are interior LEDS causing issues as well as well with reverse and tag lights?
  9. Oct 3, 2016 at 10:45 AM
    #169
    ratcityrain
    Seattle, WA
    I'm also wondering if it is because the OP was cleaning under the hood with a pressure washer that was causing some of the possible issues where as if it is raining you're fine 'cause water isn't getting to any of the connection points.
    When I installed mine, I put e-tape around all the connection points just as a little extra assistance lol
  10. Oct 3, 2016 at 10:56 AM
    #170
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    Craaaaazy that a shorted ballast can disable the whole truck.
    I've had plenty of HIDs and retrofits and my share of faulty cheap and expensive ballasts, but never did they stop the vehicle from running. good luck OP!
  11. Oct 3, 2016 at 10:57 AM
    #171
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    :annoyed:
  12. Oct 3, 2016 at 11:14 AM
    #172
    MSOEME2009
    MSOEME2009 [OP] Well-Known Member
    Knoxville TN
    2016 White Tacoma TRD Sport Double Cab 4x4
    Custom Grill; XB Fogs; Katzkin Custom Leather Interior (the way it should have came)!
    Yea who knows. I drove it for about two hours today to Lowes, Best Buy, Sams, ect. and it worked just fine. It's 80F and sunny, sat in traffic, heat loaded the engine as someone recommended.
    I hate intermittent problems, they're a bitch to diagnose. If I had an ODBII scanner I would have read the code before clearing it with the battery disconnect method.
    If there was a wiring diagram I'd be curious to see how the low beams are tied into the system. I'd assume just relays, which would provide the ECU a separate circuit and protection which would make the headlight ballast theory incorrect.
    It's hard to argue however that removing the LED kit and resetting the ECU worked. Maybe just resetting the ECU would have worked.
    I know of an expert witness whom testified in the Toyota acceleration case who said their programming is a bunch of garbage in their ECU. Too many wrong subroutines with not enough checks. The ECU could just have gotten stuck into a bad loop.
    Surprised I didn't see the blue screen of death on the console LOL.
    Either way, no more HIDs or LEDs for this truck. I picked up some silverstar ultra's at wally world. One less piece of the puzzle if something happens again.
    Lawfarin, ratcityrain and scottalot like this.
  13. Oct 3, 2016 at 11:18 AM
    #173
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    FTFY
    Jester243 and scottalot like this.
  14. Oct 3, 2016 at 11:19 AM
    #174
    MSOEME2009
    Knoxville TN
    I did not say 2nd gen :rofl:
  15. Oct 3, 2016 at 11:20 AM
    #175
    MSOEME2009
    Knoxville TN
    Can't fight with results though :amen:
  16. Oct 3, 2016 at 11:27 AM
    #176
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
    FWIW I have the stock high beams, Morimotos from TRS in the low beams, Phillips XtremeVision LEDs in the fogs, LEDs in all interior lights except for the visor lights, and LED reverse and license plate lights and so far no issues.
    I realize it's just anecdotal and I might be the "odd one out", but it is a data point. I also have not gone under the hood with a pressure washer...
  17. Oct 3, 2016 at 11:52 AM
    #177
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Free popcorn in Canada... I'm in... and beer!
    How's the OP and his new truck?? Did he get the CPS thing all squared away....
    Oh Canada... home of free popcorn....
    Oh Canada... you're not the best either!
    At least weed is not a crime there, they have that going and beer!
  18. Oct 3, 2016 at 11:54 AM
    #178
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    https://www.tacomaworld.com/threads/morimoto-hids-from-trs-culprit-for-engine-failure.428765/
    OP. There's my 45 page long failure. I updated the front post so you get a synopsis.
    We're having essentially the same issues. Toyota came back the second time as said it was the lights. I had the XC LEDs. (2strokes replaced them) and now currently have the 2 strokes... Haven't got them wet yet. I also have Morimoto HIDs. I sealed the HIDs up and soaked it with a hose. No issues. But j did find a bad led driver.
    Resetting the codes doesn't usually work for this issue (I have a code reader and tried a million things)
    Unplugging the lights and drying it out are the only things that work. I bet you that it is throwing injector circuit codes. That's what killed my truck.
  19. Oct 3, 2016 at 12:05 PM
    #179
    MSOEME2009
    Knoxville TN
    FYI I don't use a pressure washer. Only sprayed the hose to pre-wash/soak, then use a wash mit with a wash & rinse bucket, rinse, dry.
  20. Oct 3, 2016 at 12:06 PM
    #180
    AFMurse2014
    Devin
    San Antonio
    I used both and had an issue with both.
    CusterFan likes this.
