Dealer AC repair?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scrapla, Mar 2, 2019.
  1. Mar 5, 2019 at 7:23 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I never had much luck with dye on very small leaks. Probably operator error. :oops:
  2. Mar 5, 2019 at 7:29 AM
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    Soapy water test? Are inspecting a tire for a flat repair? Ha
  3. Mar 5, 2019 at 11:50 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Evaporator been a known problem too. My 2010 had to be replaced a month before my extended warranty expired .
    Yea seems like symptoms of low on charge is colder on drivers side and warmer on pass side .That threw me off lol
  4. Mar 5, 2019 at 1:06 PM
    pleetrd
    pleetrd Active Member
    Sacramento, CA
    05 DCLB
    I remember my truck having this issue before. Blowing cold on driver side and warm on passenger side. Took it to the dealership and tests showed a leak in the line. Known TSB. Failed o-ring in the line. Replaced o-ring and recharged the system. Blowing cold ever since. Hope this helps. Good Luck!
  5. Mar 7, 2019 at 5:08 PM
    Scrapla
    Scrapla [OP] Rebel Without a Clue
    South Florida
    2007 Tacoma PreRunner 4.0 V6
    1.5" lift, ARB bumper
    How do I find out if mine is a TSB maybe they will replace it? Do you remember which line and which o ring?
  6. Mar 7, 2019 at 5:34 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    I highly doubt your ac will be warranted on an 07 when it’s 2019. Follow the instructions given, check pressures, and so forth. If you have or buy manifolds to do the actual pressure checks you will be way better off.
