Dealer Can't Diagnose This Vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bman291317, Jul 11, 2023.
  1. Jul 11, 2023 at 10:29 AM
    bman291317
    bman291317 [OP] Active Member
    Hello all, this is my first post in the forum as I just joined today to get some insight from you all. I have used the search bar lol, but haven't found any definitive answer yet. I have looked at the post that discusses the 30-10 vibration, along with the needle bearing. Here is my situation:
    I have a 2023 TRD Sport. Truck has about 9k miles on it. 0-6k miles truck road smooth, but I could tell it needed an alignment. Took in for first service around 6k miles. Alignment was performed, tires were rotated. After this service I noticed a vibration in the truck. It is primarily felt in the steering wheel (but sometimes in the floor and pedals) at the following times: coming to a stop between 25mph down to 20mph, highway speeds between 60-68 is the worst and most consistent, sporadic at 70mph. It is most prevalent when the truck is driving up a slight incline or going down a slight decline in the road/highway.
    I mentioned this to the dealership and they told me to bring the truck back in. When I did, They told me that they found that some of the lug nuts (that they put back in during my tire rotation) were not torqued to spec. So they torqued these to spec and said that would fix the issue.
    Well as you may have guessed this didn't fix the issue. Arranged to take the truck back in to the dealership to have a tech ride with me so he could feel the vibration. He did feel the vibration in the steering wheel. Made an appointment for a few days later. They said that they would start by doing a road force balance and if that did not get rid of the vibration they would open a ticket with Toyota to discuss the problem to see if they had any solutions. Road force did not fix the issue, and their conversation with Toyota wasn't too helpful. Toyota told the dealership that this vibration was normal because I have a TRD Sport with Sport Tuned suspension and a more aggressive tire. I completely disagree with this. If it was the sport tuned suspension I would have felt this from day one, and my tires are not aggressive whatsoever. They are the factory Toyo tires that come on the TRD Sport. Dealership told me to bring it back if it got worse but I don't think they are able to pinpoint the issue.
    This is not a jarring vibration, just a vibration that is there enough for myself (and the tech) to notice it, and something that definitely wasn't there before my 1st service.
    Anyone gone through these issues and did you find a fix? I've thought maybe it was a tire issue, maybe uneven wear due to the truck being out of alignment before the first service.
    Thanks
    HondaGM likes this.
  2. Jul 11, 2023 at 10:31 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Just curious, what made you think the truck needed an alignment?
    mattm55 and HondaGM like this.
  3. Jul 11, 2023 at 10:32 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Mine has a small vibration when coming to a stop..coasting or braking doesnt matter..
  4. Jul 11, 2023 at 10:33 AM
    bman291317
    Truck pulled, and steering wheel was not completely centered when parked and wheels straight.
  5. Jul 11, 2023 at 10:37 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Are all the wheels balanced properly? Maybe you lost a balancing weight along the way on a wheel
  6. Jul 11, 2023 at 10:38 AM
    bman291317
    Properly, I'm hoping so. Dealership balanced the wheels the last time it was there and the problem has persisted.
  7. Jul 11, 2023 at 10:44 AM
    amitchr
    amitchr Well-Known Member
    2023 Tacoma TRD Off Road
    2023 trd off-road bought in June has 800 miles on it. I notice a vibration as well when I am braking from 30-10mph and it disappears. Not sure if it breaks in overtime or if it is rear drums? Dealer said they hadn’t heard of this before lol.
    t2c likes this.
  8. Jul 11, 2023 at 10:49 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this sounds like warped rotors (?)
  9. Jul 11, 2023 at 10:51 AM
    BustedKnuckles7
    BustedKnuckles7 Member
    2022 Electric Lime TRD
    My 2022 trd pro has a lateral vibration at speed. I dont know that I've noticed it on braking or inclines, but it js annoying to have the seat rattle on the center console at 75mph
  10. Jul 11, 2023 at 10:53 AM
    bman291317
    :mad:
  11. Jul 11, 2023 at 10:56 AM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2018 TRD Sport 4X4 DCSB
    it's caused by driveline angle. Can be corrected with shims if you're OCD about it, but its really a non-issue. Put some weight in the bed, or hook up to a loaded trailer, and i bet it goes away
    turbosnail and willtill like this.
  12. Jul 11, 2023 at 10:57 AM
    bman291317
    You think that would fix my issue as well? Mine is a little different that amitchr's scenario.
  13. Jul 11, 2023 at 11:00 AM
    Rambofirstblood
    Rambofirstblood Active Member
    2015 TRD Sport
    If it were mine, I would swap the tires.
    Put the fronts on the back, and the backs on the front.
    See if anything changes.
    bulalo, wayupnort, joba27n and 2 others like this.
  14. Jul 11, 2023 at 11:00 AM
    clownkillerloaf
    Logan
    Probably. Im guessing it didnt do it new, but does it now bc suspension has settled a little bit. There can be (rare) issues with taco's, but this really isnt one of them. Enjoy your truck, you chose wisely.
    bman291317[OP] likes this.
  15. Jul 11, 2023 at 11:01 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Keep taking the truck to them over and over to document this. My coworker just dealt with a lemon law case with his wife's car for a vibration issue they could not remedy.
  16. Jul 11, 2023 at 11:05 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    This fixed my significant deceleration vibration. my driveline angles were ok but the leaf springs that come with all but the TRD OR are weak and cause axle wrap, pulling driveline angles out of spec.
    i have essentially no deceleration vibration now. my high speed has always been fine - no vibration.
    Toyota updates the TSB to include the latest model year rather than fix the problem in the factory. I don't know if this is the latest incaarnation. Dealer SHOULD know about this.
    Apparently some don't have this problem or don't care.
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10187246-9999.pdf
    EDIT: this is a common problem and MANY threads about it.
  17. Jul 11, 2023 at 11:10 AM
    bman291317
    Appreciate the info!
    HondaGM likes this.
  18. Jul 11, 2023 at 11:12 AM
    JakeJob
    JakeJob Well-Known Member
    Jacob
    NW Indiana
    '22 LR Tacoma TRD ORP MT
    Mine has done it since new. 26000 miles and still the same. According to some its an issue with driveline angles being out of spec. You can test it by adding weight in the bed and see if it goes away.
    HondaGM likes this.
  19. Jul 11, 2023 at 11:12 AM
    bman291317
    Would you recommend bringing that information to the dealers attention?
    wayupnort and HondaGM like this.
  20. Jul 11, 2023 at 11:16 AM
    RubyTaco21
    RubyTaco21 Almost Known Member
    NY
    Barca Red SR-5 with some mods.
    I had the same problem with a dealership. I switched dealerships, they did another road force balance and guess what: it went away. The first dealership I went to was ill-equipped mentally when it came to balancing and rotating the tires. Second dealership too care of it. No issues since with three rotations and about 6k miles.
    Honestly, I'd have cancelled them once they admitted the lugs weren't tight. If you want to go at them, that's where I'd start.
