Dealer cant figure out whats wrong.
Discussion in 'Off-Topic Discussion' started by Who Dat Popcorn, Dec 17, 2010.
  1. Dec 17, 2010 at 9:24 AM
    Who Dat Popcorn
    Who Dat Popcorn [OP] Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Our 2001 Camry has started to leak coolant, and we've taken it to the dealership 3 times now. They pressure tested it and couldn't find a leak. I know I wasn't crazy, so I had to physically take them out there and move the car for them to show them that a puddle had formed. So they take it back in and call me later and tell me that the radiator needs to be replaced.
    They replace it, I take it home, and put it in the garage. 3 Days later, I open the hood and coolant levels are low again (1/4 tank left). They had fill it to the top when I took it home. Now they want me to bring it back in, but I don't have time to keep doing this. Anyone have any ideas?
  2. Dec 17, 2010 at 9:27 AM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    They might have had some air in the system when they filled and as you drove it home it worked it's way out. Also sometimes on the plastic tank / aluminum core radiators teh seal between the tank and the core will seep when the car is cold (or more noticeable in real cold weather) and seal up when the radiator gets warmed up.
    That's a tough one to crack.
  3. Dec 17, 2010 at 9:30 AM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2018 AC 4X4 2.7
    Check for a leak in the coolant recovery tank,or
    the hose connecting the radiator to the recovery tank.
    A leak in the tank or hose won't show up in a radiator pressure
    test.
  4. Dec 17, 2010 at 9:34 AM
    kws129
    PA
    Good thinking Warped - I should have thought of that too...:)
  5. Dec 17, 2010 at 10:40 AM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    sounds like a simple case of whoever is looking at the car doesn't know what they're doing. Tell the dealership you want a different tech to look at it.
  6. Dec 17, 2010 at 11:13 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Ask to speak to the service mgr. KILL THEM WITH KINDNESS. They are not used to this. Ask him/her that you would like the master tech to take a look at it. Sometimes simple jobs are given to simple people. "Someone has to make the fries" :popcorn:
  7. Dec 17, 2010 at 11:23 AM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    Kind of what warped said, how do the hoses look? Look for the connection to the engine as a starting spot. Check for bulges or hardening hoses. I had a similar issue on my Honda - touched the hose and it disintegrated.
    Feel the rest of the hose for softness, bulging, weatherization - it might be sweating off your coolant.
  8. Dec 17, 2010 at 11:49 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    I had one of the original HOSE CLAMPS give way. Looked fine-was rusted thru on the bottom-only leaked when warmed up. Radiator hose clamp--would be my first look. see if you can move the hoses or pull them loose.
    OF COURSE NOT WHILE THEY ARE HOT!!!!!!
  9. Dec 17, 2010 at 12:14 PM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Reads like some of the trapped air pockets bled out, which is usually the case when you change a radiator. Coolant level should be left at about 1-2 inches below the radiator cap for fluid expansion,,but no inside core showing/exposed.
  10. Dec 17, 2010 at 12:19 PM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2018 AC 4X4 2.7
    That is true of older vehicles that don't have a coolant recovery tank.
    Vehicles with a recovery tank(most all newer vehicles)should have the radiator completely filled.
    The recovery tank provides the expansion space.
  11. Dec 17, 2010 at 1:10 PM
    Chickenmunga
    Hillsboro, Oregon
    lol careful, there's another trick to some vehicles as well.
    My honda had an air bleeder bolt. Whenever you opened the radiator cap, you had to remember to run the vehicle, turn the bolt to bleed out the air, and tighten the bolt. Otherwise recovery tank does nothing. I seized an engine once because I didn't know about it.
  12. Dec 17, 2010 at 1:37 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    check your oil. head gasket?
  13. Dec 17, 2010 at 6:30 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Fill it back up yourself with the car completely cold. Fill the radiator, then the overflow bottle. Once you've done that, check it after a couple days. Make sure you check it when the car is completely cold. If it still drops, then either buy a pressure tester and check it yourself for leaks or take it back to the dealer.
    I have always had to top off the coolant the day after I have worked on a cooling system. There is always some air in the system and the first time the car heats all the way up, then cools, the radiator will draw coolant out of the overflow bottle.
    Don't get excited just yet. I think you're going to be okay. You did not mention seeing coolant on the ground, so it sounds like they have fixed it to me.
  14. Dec 17, 2010 at 9:49 PM
    Who Dat Popcorn
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    There is coolant on the ground though. :(
  15. Dec 18, 2010 at 10:18 AM
    Mod
    CR, WA
    stock
    Well, all bets are off then.
    Tough situation.
    Maybe give the service manager a call at the dealership and tell him of the money you spent there to try to fix a problem.
    Or,,
    Get a 2nd opinion and let that shop know what has transpired with the dealership and see if they can sort it out.
  16. Dec 18, 2010 at 10:22 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Whoops! Never mind.
    In the past when I've had leaks sometimes they only leak as the car is warming up. Hot enough to build pressure, but not fully warmed up yet.
    Maybe drive around the block a few times, then check it.
    I have seen leaks found very quickly with a pressure checker that otherwise I could not have found myself.
    Of course, the dealer should be using a pressure checker. :rolleyes:
    Maybe someone knows a good independent mechanic?
  17. Dec 18, 2010 at 10:26 AM
    joes06tacoma
    Joe
    Central Coast, CA
    It's not rocket science either. If you get yourself a nice bright flashlight you should be able to follow the coolant from the puddle on the ground back to where it came from.
    Good luck man. I hate when dealerships (sometimes others) seem to lack any interest in actually fixing things.
  18. Dec 18, 2010 at 10:28 AM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    I say take it back. You have already spent the money to have them fix it...like others have said talk to the service manager tell him you have been there 3 times for the same issue and you need to get it resolved. Maybe he will give you a discount... You get more flies with honey then you do vinegar so make sure you are nice. It should be a straight forward diagnosis and repair
  19. Dec 18, 2010 at 10:32 AM
    cc350
    cc350 Retired Member
    Best clue would be to go straight up from leak on ground, see where it's coming from. Front of engine? Radiator? Recovery tank? Overflow line? Heater core? Hoses? Block? Freeze plug? Investigate yourself...
  20. Dec 18, 2010 at 10:59 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Heat and cold can cause the seams and seals to expand and contract. The older Volvo's would leak out of the o-rings when it was cold. As soon as it warmed up the leak would stop. Come out the next morning to a puddle of coolant. The plastic radiator on my Ranger did the same when it was cold outside.
