Dealer can't fix... what should I do
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joe54tacoma, Sep 26, 2013.
  1. Sep 26, 2013 at 2:57 PM
    joe54tacoma
    joe54tacoma [OP] Joe in Indiana
    Joe
    New Albany Indiana
    2012 DOUBLE CAB TRD Sport
    Long story short.
    Bought a 2012 new in Dec 2011.
    Since 500 miles it has a bad popping noise in the cab.
    The dealer has tried to fix it four times starting in 2012.
    Things they say they fixed
    Visit 1 - said it was an accessory behind the seat that they removed
    Visit 2 - said it was Loose wires that were fixed
    visit 3 - said it was a cab mounting bushing that they replaced
    Visit 4 (They had to call in a Toyota factor guy) - said it was a broken weld on the cab. They removed the bed to get access and fixed something. The pop is still there according to the body man.
    Currently the truck is still sitting at the dealer... been there for a week now.
    Any suggestions how to handle this?
  2. Sep 26, 2013 at 2:59 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Well just drive it and take all loose items out of truck. Check all the panels, bolts, and even go underneath and check everything.
  3. Sep 26, 2013 at 3:05 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    possible lemon law?
  4. Sep 26, 2013 at 3:07 PM
    BamaToy1997
    Bill
    Navarre, FL
    X2 there. I am usually the first to throw the glove when I challenge peoples "This thing is a lemon law", but this time it does sound like you have a potential claim there. Do you have all the repair orders documented and copies?
  5. Sep 26, 2013 at 3:07 PM
    joe54tacoma
    Joe
    New Albany Indiana
    It's just depressing to pay 33K for a new truck and it sounds worse than my 1997 jeep.
  6. Sep 26, 2013 at 3:09 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Ya that kinda sucks hope you get it fixed
  7. Sep 26, 2013 at 3:10 PM
    joe54tacoma
    Joe
    New Albany Indiana
    The dealer that it was purchased from has done all the work.
    It's all in their system
  8. Sep 26, 2013 at 3:11 PM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    im x3 with t he lemon law. Time for a 2014 tacoma
  9. Sep 26, 2013 at 3:13 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    What was the accessory they removed during visit #1?
  10. Sep 26, 2013 at 3:18 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I agree. This why this law exists in Wisconsin.Even Toyota produces an occasional lemon:eek:
  11. Sep 26, 2013 at 3:29 PM
    joe54tacoma
    Joe
    New Albany Indiana
    It was like a rack to hold some sort of tool.
  12. Sep 26, 2013 at 8:38 PM
    BamaToy1997
    Bill
    Navarre, FL
    The most they will do is get him an identical year/model or give him fair market value. They are not going to give him a brand new 2014.
    The bad part is deciding what warrants "a defect that substantially impairs the use, value, or safety of a vehicle." To some people, a noise like that would fall into that definition. To others it wouldn't, but your research does show that he may be out of luck on time.
  13. Sep 26, 2013 at 9:07 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    Seeing as how well Tacomas hold their resale value, fair market value isn't a bad option at all. I'd be leaning towards the lemon option if they can't solve the issue.
  14. Sep 26, 2013 at 9:12 PM
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    What type of popping are you hearing? I know some double cabs (mine included ) doors have a lite pop. Specifically when any cab flex occurs and the radio is off. Its the sound of the weather stripping breaking seal.
  15. Sep 27, 2013 at 12:26 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    I don't have the popping noise, but for what it's worth:
    1) If the door seals and door frame are really clean the seals stick to the door frame better, then when the truck twists a bit they can make a small popping sound. This happens from time to time on one of my cars. Try armor all or something similar on the seals.
    2) If the spring shackle bolts are over tightened they can make a noise that sounds like a pop. Search TW for threads on that for more info.
    These ideas might not work, but at least they're cheap to do. Another thought is to have someone else drive while you ride in back, or close to wherever the popping sound seems to come from. It's almost impossible to track where the sound is coming from when you are driving. Good luck.
  16. Sep 27, 2013 at 5:24 PM
    joe54tacoma
    Joe
    New Albany Indiana
    The popping / cracking seems to be coming from the member that the cab mounting bushing is attached to. It is really noisy and irritating. I can even hear it over my radio. Even the dealer had to finally recognize that something isn't right. The mechanic said that it would drive him crazy.
    The problem is that they can't isolate the problem. To show the extreme, it has been at the dealer for 6 days in the body shop. Very frustrating.
    I'm going to run the wheels off the loaner Toyota. I said I'll keep your car until you fix mine. Don't call till it's fixed.
  17. Sep 27, 2013 at 5:32 PM
    joe54tacoma
    Joe
    New Albany Indiana
    [/quote] but your research does show that he may be out of luck on time.[/QUOTE]
    This has been going on since the very first oil change at the dealer
  18. Sep 27, 2013 at 5:33 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +3
  19. Sep 27, 2013 at 5:34 PM
    joe54tacoma
    Joe
    New Albany Indiana
    The factory Toyota rep. said that it is a broken weld somewhere.
  20. Sep 28, 2013 at 10:31 AM
    2ndchancetoyotas
    2ndchancetoyotas Well-Known Member
    Greg
    AZ
    Rebuilt
    Yeah, when I worked at Lexus, NVH can be a real bitch. Especially on those cars whom people think should be built like the Space Shuttle. One of the typical problems is that as a flat rate mechanic, you're trying to make time and you've this noise problem. They should put a shop foreman on it who is hourly.
    I would assume they stripped the interior and had a second person ride so they could listen as the other drives.
    Hope it works out for you.
