Dealer can't install OEM Alarm System???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by K Williams, Oct 4, 2010.
  1. Oct 4, 2010 at 10:27 AM
    K Williams
    K Williams [OP] Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Does anyone here have a 2010 or 2011 Tacoma that has the Toyota VIP RS3200 Plus system installed? My truck is at the delaership now, and they are saying that there's a compatability issue with the alarm system and the engine immobilizer system. Is this true or are they bullshitting me. The offered to install a Code Alarm Pro 200 alarm(which they claim is more expensive). I just checked online...the Pro 200 is no where near the cost of the VIP system.
    What are some good aftermarket alarm systems that I can get installed at an alarm/stereo shop? 'Cause I can see I'm going to have problems with the service dept if they keep playing games. :mad:
  2. Oct 4, 2010 at 11:55 AM
    Shaggy
    Shaggy Well-Known Member
    Woodbridge, VA
    2010 Pyrite Mica DC TRD Off Road
    I just had installed the Python autostart w/alarm (model 991), window modules and the Viper SmartStart system. So far I love it.
    Dealer had no problems at all installing it in my 10 TRD. The entire system is pricey but the alarm system would of only been a few hundred bucks had I of just done that.
  3. Mar 26, 2013 at 7:14 PM
    hpd5705
    hpd5705 New Member
    Rich
    Houston
    2010 Red PreRunner
    Bull bar, tannoue cover, Pioneer AVIC 930BT, OEM alarm
    I installed the RS3200 Plus OEM alarm in my 2010 Tacoma PreRunner on 03/25/13. It is a lot of work requiring removal of numerous dash parts, pulling and exchanging electrical pins in one electrical connector and routing the long V5 wires/connectors from the drivers side, through the center dash and into the passenger electrical connections. The fit is tight. On the passenger side it states to plug in the V5 grey connector with the truck grey connector but the picture in the manual does not match up and the location where the manual states to do this is an empty spot. It was obvious a change was made by the manufacturer. I found a white 11P connector higher up that did the trick and installed the V5 grey connector to this 11P white connector. After it was all done it worked fine. Nothing had to spliced or cut. It was all plug-in-play. Installing the RS3200 Plus in the Tacoma requires time and lots of patience.
    The most useful tool I found that helped me was a 10mm socket and a light that my mom gave me that you wear on your head. Working with two hands and not having to handle a flashlight was a BIG plus.
    After following the directions step-by-step, putting the negative battery cable back on and starting your truck, it will rev for awhile and then go back to normal.
    My 2013 Corolla was way easier with half the connectors and length.
    I hope this helps anyone that can use the info.
  4. Mar 26, 2013 at 8:13 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    My guess is they just don't want to deal with it. My dad used to do car phone and alarm system installs at our cellphone business. He eventually stopped doing alarm system installs because they were such a pain in the ass, and that 20 years ago when cars were more simple.
  5. Mar 26, 2013 at 8:16 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    That doesn't make sense. That is a cake job for a dealer tech, one that they can make a lot of money on- especially if flat rate.
    I think they ordered the wrong part or something.
  6. Mar 26, 2013 at 10:19 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Reminds me of my Dodge Ram....
    I wanted the OEM factory alarm installed and they couldn't do it. The alarm wasn't compatible with the ECM. Something about the hardware CAN setup and it wasn't equipped with the necessary units to install an alarm.
    WTF?? Really?
    Why even bother offer selling accessories if they don't or can't work on ALL models?
