dealer cant solve rough start problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zano, Mar 6, 2012.
  1. Mar 6, 2012 at 1:46 PM
    zano
    zano [OP] Well-Known Member
    south chicago burbs
    2011 TX Bro
    2.25" lift, SPC UCA, Dobinson's C59-314 coils & 500lb leaf packs, Billy 5100's & 5125, Tom Woods 1pc ds, TRD exhaust, OEM black tube steps, Konig Countersteer (FN) wheels, Michelin LTX/AT2's
    My 11' tx pro has had an erratic hard/rough/no start issue for several months now.. This is the 3rd time I've had it at the dealer for nearly a week and they claim they cant duplicate it. To me it seems like a leaky fuel injector because while it is cranking it will sputter just before starting then will run fine after that. It happens when its cold outside and in fair weather. Sometimes I have to keep cranking for 8 or more seconds as if there is no pressure in the fuel rail at all.Other times it starts perfectly, even at cold temperatures. This cant be normal. I use good quality fuel and have no issues at all after it starts. I believe there was a TSB for the 07 having a similar issue...Has anyone here with a 2011 have this problem? Any help would be more than the dealer has done so far.:mad:
  2. Mar 6, 2012 at 1:52 PM
    rdd11
    rdd11 Well-Known Member
    Ross
    Red Deer, AB
    08 TRD Double Cab long box black
    K&N cold air, Exhaust
    Mine has always started kind of rough. Hasn't gotten better or worse but always starts. Not sure what to tell you. think its the starter? Prob not with what you mentioned
  3. Mar 6, 2012 at 1:53 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I bet it's that engine coolant temp sensor rearing it's ugly face, again. I'd try a ECM from a known good running truck and see if that solves it.
  4. Mar 6, 2012 at 2:26 PM
    zano
    south chicago burbs
    2011 TX Bro
    ....hmmm thats a new one. I havent heard about this.. time to use the search window. thanks
  5. Mar 6, 2012 at 2:36 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    They did the re-flash 2 weeks after I bought back in 07 and completely fixed the problem. It's too bad they can't at least try it on the newer trucks...sure sounds like the same issue.
  6. Mar 6, 2012 at 2:40 PM
    rwhite188
    rwhite188 Well-Known Member
    Ray
    Texarkana, Ar
    2011 PreRunner TX Pro TRD
    I have not had any issues with my 11 Tx Pro it starts right up so far..
  7. Mar 6, 2012 at 2:44 PM
    zano
    south chicago burbs
    2011 TX Bro
    I read about the 07' tsb and it sounds very similar to the issue i'm having.. mentioned it to the dealer and they told me if toyota doesnt give them the flash procedure then they cant do it..
  8. Mar 6, 2012 at 4:50 PM
    cortez_a
    cortez_a Active Member
    Andy
    Colorado
    My 2010 was doing it, and after a year I finally got an answer that makes sense to me. The computer of the truck adjusts the fuel air ratio to get ideal mix for your location. Any time you disconnect the battery, or change elevation the ecu will either reset the fuel ratio back to stock or it will be incorrect until it adjusts to the new elevation.
  9. Mar 6, 2012 at 5:00 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    You may have to let the truck sit overnight, this allows the engine coolant temp sensor...and some other sensor to be within 13 degrees F of each other. In the morning disconnect the battery for 15 sec. Upon start-up immediately drive the vehicle smoothly off idle to 40 mph for 3 minutes while not allowing the throttle to close. Then pull over and idle for 2 minutes then repeat the procedure 2 more times. Or something like that.
  10. Mar 6, 2012 at 5:04 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    holy crap!
  11. Mar 7, 2012 at 12:17 AM
    zano
    south chicago burbs
    2011 TX Bro
    x2
  12. Mar 7, 2012 at 12:43 AM
    zano
    south chicago burbs
    2011 TX Bro
    getting tired of all these issues with only 20k miles:annoyed:
  13. Mar 7, 2012 at 9:12 AM
    shaun.l
    shaun.l Member
    shaun
    pa
    2011 trd off road dbl cab
    nothing yet
    my 2011 trd offroad is doing the same thing andthe dealer can not duplicate it either. when i suggested a ect they said no, when i suggested a reflash based on the 07 they said none available. i work at a vw dealer and have had the same issue with them. truck is currently at the dealer and they have had it for a week trying to duplicate with no luck. in reguards to above i know this is not related because my truck only has about 7k on it and it will do it after i park my trunk at work in the morning and go out for lunch.... i only live about 4 miles from work unless i drive straight down the side of a mountain altitude is not related. in reguards to altitude being an issue that is a live change in the ecm called altitude correction and should not affect a car just from a start up if altitude correction is not being calibrated properly by the ecm there is a fault for that as mandated by the epa as the car will run like crap all the time
  14. Mar 7, 2012 at 9:18 AM
    Ridgerunner
    Frank
    Rocklin, Ca.
    This is where a digital camera would be handy-video every time you start truck-catch+save the time when it happens-show it to dealer:)
  15. Mar 7, 2012 at 9:38 AM
    shaun.l
    shaun.l Member
    shaun
    pa
    nothing yet
    i thought of that but have not done it yet... whats worse is what ever is causing the issue may also be responsible for my 14.5 mpg city and back roads. my wifes v8 4runner gets better then that
  16. Mar 7, 2012 at 12:42 PM
    zano
    south chicago burbs
    2011 TX Bro
    8 days at the dealer and counting... at least they gave me a 2012 4runner limited for a loaner. toyota needs to get their sh*t together and solve this problem. i love the truck..but this is rediculous. I could understand if it was a new model and they were still working out glitches, but this model has been around since 2005. :mad:
  17. Mar 8, 2012 at 1:21 AM
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    Before engine start up your ecu looks at manifold absolute pressure( a big player), intake temp, and engine temp. It uses that to calculate start up conditions. Then fuel amounts, ignition timing, throttle blade actuation and valve timing are adjusted accordingly.
  18. Mar 8, 2012 at 4:41 AM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    Did it ever throw a code? Did the dealer tell you anything came up on a scan?
  19. Mar 8, 2012 at 5:15 AM
    Honey Badger1
    Honey Badger1 Well-Known Member
    Trip
    New Hampshire
    2011 Tacoma TRD Sport
    Fuzzy Dice, Fighter pilot mod, power ports always on, GPS wired to come on as key is turned, LED Map/dome lights, all weather mats, bed liner, tool box on rail system, Tinted tail lights, repainted badges, Home made grill, Light mounting bracket with two 6 inch. PIAA Drive lights, Stealth mod DTRL on/ off, leather arm rests, door and center.
    I have a 2011 TRD Sport. and it only happens on cold cold mornings I haven't done or asked any one about it at the dealer mainly because I can never get it to do it when I'm watching. its always when I figure its not cold enough and will start fine.:confused: but if its been run and left in the cold temps its fine the rest of the day it seems to just be the over night sit.
  20. Mar 9, 2012 at 10:32 AM
    zano
    south chicago burbs
    2011 TX Bro
    no code has ever come up...and they told me they monitored the fuel pressure to see if it dropped overnight and it held pressure until they tried started it in the morning.
