dealer cant solve rough start problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zano, Mar 6, 2012.
  1. Mar 12, 2012 at 4:46 AM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    I would think it would be the Air Intake Temp sensor. Too bad it's going to be so warm for the next week. Let us know if it still happening with it being 50 degrees in the morning.
  2. Mar 14, 2012 at 12:30 AM
    zano
    zano [OP] Well-Known Member
    south chicago burbs
    2011 TX Bro
    2.25" lift, SPC UCA, Dobinson's C59-314 coils & 500lb leaf packs, Billy 5100's & 5125, Tom Woods 1pc ds, TRD exhaust, OEM black tube steps, Konig Countersteer (FN) wheels, Michelin LTX/AT2's
    I wouldnt know if it is... the dealer still has my truck. :(
  3. Mar 19, 2012 at 3:02 PM
    zano
    south chicago burbs
    2011 TX Bro
    well, after nearly 3 weeks.. the dealer gave up on my truck. No solution. :mad:
  4. Mar 19, 2012 at 6:40 PM
    MikeyLikesIt
    Well if it only happens in the extreme cold, your screwed until next winter because I don't think we're getting any more freezing temps at the moment.
    If you ever end up throwing a code, or it starts running rough, PM me and we'll hook up sometime. I have that Torque app running on an Android and connecting through the OBD II port. We'll see if anything is out of whack.
  5. Mar 19, 2012 at 9:29 PM
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Wow, sounds like a lot of BMW and Audi's I've seen where the ridiculous hundreds of pounds of wiring somewhere sometimes has a bad ground, crappy connection, corrosion somewhere, intermittent circuit board solder failure, or other weird flakey prob where it's not conducting as it should, either that or a crappy fuel pump relay (if they have fuel pump or injection relays on tacos).
  6. Mar 19, 2012 at 9:50 PM
    JTyfz450
    JTyfz450 Well-Known Member
    Jeryck
    SoCal
    2012 TRD Sport DCSB MGM
    I had an issue with my old car that my dealership apparently couldn't duplicate. I kept telling them that huge puffs of white smoke was coming out of my exhaust, but they still required proof to authorize the fix. Sucks, but that's usually how they get out of doing the service and leaving the customer frustrated. To counteract their bullshit I recorded a video as proof and showed it to my service provider. They didn't question me any further and they fixed the problem. It's annoying, but the job got done. Record a video until you get that hard crank and bring it over to your dealer. In the video I clearly recorded my VIN # and license plate and then recorded the white smoke from my exhaust. Hope that helps :D
  7. Mar 19, 2012 at 9:56 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    My 09 does this on occasion. It doesn't happen if when I get in the truck I turn the key on and let is sit there for a couple seconds before cranking the engine.
  8. Mar 20, 2012 at 8:22 AM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    Reading through the thread this is the first thing I thought of. It really sounds a lot like the fuel pressure is bleeding off. I wouldn't be satisfied that it wasn't the issue until I saw good pressure and it had the long crank still.
  9. Mar 20, 2012 at 1:16 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Update:
    Since I got myself into the habit of waiting a heartbeat or two beween Ignition and Start, I have not had any more starting issues. FYI
  10. Mar 20, 2012 at 3:01 PM
    Skycam3
    Skycam3 Waiting to see...
    Tony
    Nashville
    2012 Tacoma DCLB TRD Sport 4x4
    Flyzeye, Redline hood struts, Demello Sliders, Pelly wrap around light bar, Roll-N-Lock tonneau cover, 2 Hella 700FF, DIY LED light bar(10,000 lumes), LED bed lights.
    My 2012 sport 4x4 did this and I read somewhere on here the the transponder wasnt getting the code quick enough. So now I turn the key to the "on" position, wait 1 second, then start. Hard start has gone away. Might be worth a try for you...
  11. Mar 21, 2012 at 12:49 PM
    zano
    south chicago burbs
    2011 TX Bro
    got my truck back yesterday, when i started it at the dealership, it was fine.. I work 3rd shift and when I was leaving work, sure enough it sputtered to a start. It was 60 degrees outside. I even tried waiting with the key in the on position for 5 seconds.. I want to bring it to a different dealership to get another opinion but this dealer doesnt offer loaner cars while mine is being serviced and I dont feel I should pay for a rental car while toyota scratches their heads and tells me nothing is wrong with my truck. Thanks to all of you for the suggestions... I'm calling their corporate office..AGAIN!
  12. Mar 21, 2012 at 12:53 PM
    zano
    south chicago burbs
    2011 TX Bro
    I will try this and hopefully i can get it to duplicate the problem. Dealer said they scanned it several times and no codes came up.
  13. Mar 21, 2012 at 12:55 PM
    zano
    south chicago burbs
    2011 TX Bro
    They thought this might have been my problem so they had me bring all 3 keys the truck came with and they say the immobilizer was working correctly in all of my keys.
  14. Mar 21, 2012 at 12:58 PM
    zano
    south chicago burbs
    2011 TX Bro
    Thanks for the offer man! I'll keep that in mind... What is the app called that you are using?
  15. Mar 21, 2012 at 1:12 PM
    #35
    MikeyLikesIt
  16. Mar 22, 2012 at 9:35 PM
    #36
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    like i said....
  17. Mar 30, 2012 at 7:01 PM
    #37
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    hey zano,
    been to another dealer yet? i have the exact same problem with my 2010 and it just started 2-3 months ago. at first i thought it was the temp changes with summer/winter fuel. just seems to be happening more and more now. seems to get worse the longer it sits and occassionally its fine after its been sitting. i'm getting ready to take it to dealer and say wtf?
    ya it seems like it loses fuel pressure.
  18. Apr 3, 2012 at 12:41 PM
    #38
    zano
    south chicago burbs
    2011 TX Bro
    havent taken it to another dealership yet. they kept it for 3 weeks this last time and the other dealership close to me doesnt offer loaner cars.. I'm not paying for a rental while they try to figure this out. hopefully toyota comes up with a solution soon.
  19. Apr 3, 2012 at 1:26 PM
    #39
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    See if they'll let you take a vehicle data recorder home. It plugs into the DLC port. The second you start having an issue you hit the trigger button and the the VDR begins recording a snapshot of the vehicle data. The tech can then download the file and review it to see what is out of spec.
    Some can record multiple events while others only a single. Not sure what Toyota offers its techs.
    You might have to put a refundable deposit down but that could find your problem.
  20. May 1, 2012 at 5:58 AM
    #40
    OneMentalCase
    OneMentalCase Well-Known Member
    South Florida
    10 Pyrite LB
    My 2010 has done this since I bought it new from day 1....occasionally will turn over strong but not start.....at all. I now do the turn the key thing and wait a few seconds which seemed to help...but to this day including yest...it still does the same thing.
    It is so sporadic I haven't gone to the dealer yet....because I know they won't be able to duplicate it.
    I live in South Florida and it does this regardless of temp....50 degrees or high 80's like yest.....
