Dealer Claims Rear Brake Shoes Half Worn at 8800 miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hpiguy, Apr 27, 2021.
  1. Apr 27, 2021 at 9:09 AM
    hpiguy
    hpiguy [OP] Well-Known Member
    2020 TRD Pro
    Just had the 2020 TRD Pro in for it's 18 month service.
    Truck has 8800 miles on it. Gentle driving, zero off road.
    Averaging 20-21 hwy for mileage, so I don't think the brakes are hanging up.
    Dealer claims the front pads are at 9mm and the rear shoes are down to 3mm. He said the stock shoes are installed with 5mm thickness and that I'll need to replace the shoes by 10,000 miles. What?
    That sounds a bit insane to me. 8800 miles of gentle driving and the rear shoes are half gone?
    For comparison, my FJ had 51,000 on it when I traded it in and the stock disc pads all the way around were in mint shape, about half way worn. Same driving style.
    The vehicle before that had 69,000 when I traded it in and again, the pads were excellent because I'm not a crazy driver.
    Any explanation for Tacoma brake shoes wearing that fast?
  2. Apr 27, 2021 at 9:12 AM
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    I find that hard to believe.
    I never changed the rear on my 16 when I traded it at 45k and when I had my 1st gen 2000 I never changed them past 100k and it always passed inspection
    massac78 and Junkhead like this.
  3. Apr 27, 2021 at 9:18 AM
    hpiguy
    2020 TRD Pro
    Right, usually drums/shoes last a LONG time.
    I checked my tread depth on the tires and in the same mileage I've used 1/32nd of tread. From 11/32nd new per Goodyear to 10/32nd today. So there is no way I'm blowing through brakes by driving hard.
  4. Apr 27, 2021 at 9:19 AM
    xLOGREx
    xLOGREx Well-Known Member
    Logan
    SL,UT
    2017 White SR5
    Little of this, little of that.
    I would take a look for yourself, that sounds highly highly unlikely.
    massac78, Junkhead and Rock Lobster like this.
  5. Apr 27, 2021 at 9:20 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    not a chance
    Junkhead, Vlady and Skydvrr like this.
  6. Apr 27, 2021 at 9:22 AM
    GSDLVR123
    GSDLVR123 Well-Known Member
    Randall
    2023 TRD Pro (Solar Octane)
    man - that is hard to believe...I travel up a down small mountains DAILY, using my brakes...I have 106K miles on my truck, it gets serviced every 5K miles - at the dealership - and last check they said my brakes were fine.
    Junkhead likes this.
  7. Apr 27, 2021 at 9:23 AM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    I call horseshit! Not a chance they’re that worn at 8.8k. They will go past 100k in my experience. Had 150k on my first gen and they were still good.
    MadKatt, massac78, Junkhead and 2 others like this.
  8. Apr 27, 2021 at 9:23 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Unless you drove all 8800 miles with your foot on both pedals at the same time or have some major malfunctions with all your brakes I highly doubt that's the case. Drum shoes are built to last a long time. Get in there yourself and take a look.
  9. Apr 27, 2021 at 9:24 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Parking brakes need adjusting? Has some body has been driving with the parking brakes on? :notsure:
  10. Apr 27, 2021 at 9:33 AM
    hpiguy
    2020 TRD Pro
    I'm the only driver. :)
    I use the parking brake once a week, just to make sure it gets flexed and doesn't rust into place.
    Thanks though, a good thing to check. Or if I had a teenager trying brake stands, but I'd notice that in tire wear too.
    I'm going to wait until the next service in Oct and make them show me all this wear when the drum is off for it's inspection. Sure seems odd they'd wear that fast.
    Junkhead, MOC221_ and whatstcp like this.
  11. Apr 27, 2021 at 9:36 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Remove the rubber plug and check the shoes from behind the wheel.
    Kev250R likes this.
  12. Apr 27, 2021 at 9:39 AM
    BRBNNEAT
    BRBNNEAT Well-Known Member
    Madison, WI
    2021 TRD Offroad-6 speed
    How busy is the service area?
    Junkhead and whatstcp like this.
  13. Apr 27, 2021 at 9:43 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    They're only about 4mm new and last 200k. I'd say they measured incorrectly more than anything else.
    Kev250R, Junkhead, wrightme43 and 4 others like this.
  14. Apr 27, 2021 at 9:54 AM
    stu8319
    stu8319 Well-Known Member
    Stuart
    Oklahoma City
    2018 Tacoma TRD Off-Road in Quicksand
    So they actually pulled the drums and checked shoe wear? Did you have any brake concerns you mentioned to them?
  15. Apr 27, 2021 at 9:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I believe you can measure through the backing plate.
  16. Apr 27, 2021 at 9:56 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    100% BS. I have 187K on my original drum shoes, they look fine. And this is hard daily driving and off-roading
    whatstcp and Junkhead like this.
  17. Apr 27, 2021 at 9:58 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    See if the used car manager is in and ask for a quote.
  18. Apr 27, 2021 at 10:01 AM
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    My 2009 had 196,000 miles on it on the original drums and shoes. I would get a second opinion on that!
  19. Apr 27, 2021 at 10:02 AM
    devale
    devale Well-Known Member
    I agree with the disbelief. Just took my 2020 pro in for the 10k service, but nothing was mentioned about the brakes, and I'm in stop and go Houston traffic pretty much daily
  20. Apr 27, 2021 at 10:03 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Any time the dealership has told me something I'm skeptical of, I always ask if I can be brought into the shop and see it myself. Don't have them bring the part to you. You have no clue if that's from your vehicle or not.
    Shouldn't the front brakes wear out faster though?
    G8R_Taco, tonered and devale like this.
