Dealer Claims Rear Brake Shoes Half Worn at 8800 miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hpiguy, Apr 27, 2021.
  1. Apr 27, 2021 at 10:04 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I fear the fictional teenager would be very disappointed in the fictional brake stands :);)
    Junkhead and tonered like this.
  2. Apr 27, 2021 at 10:07 AM
    danmtchl
    danmtchl Well-Known Member
    Dan
    Bakersfield
    2019 Tacoma TRD Double Cab Sport 4x4
    Wouldn’t the dealer just change the pads under warranty? If that is the case just let them do it, it’s just a waste of their times and resources.
  3. Apr 27, 2021 at 10:08 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Brakes, clutches, wipers, tires, etc. are wear items. The warranty on those parts are much more limited and based mainly on material / workmanship defects.
    Kev250R and Junkhead like this.
  4. Apr 27, 2021 at 10:19 AM
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    I would say at 8800 miles this should be classified as a material or workmanship defect.
    MadKatt, whatstcp, stu8319 and 3 others like this.
  5. Apr 27, 2021 at 10:25 AM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    2010 Chrysler had a premature brake ware issue. On the mini van. Covered the pads and rotor turning but no labor. Depending on mileage.
  6. Apr 27, 2021 at 10:28 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    "Can you please show me the part and how you measured it?"
    If something doesn't seem right, then keep asking questions until the bullshit comes to light.
    Junkhead likes this.
  7. Apr 27, 2021 at 10:30 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
  8. Apr 27, 2021 at 11:03 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. Which is what I noted. Stuff can happen, but wear items are typically just that.
  9. Apr 27, 2021 at 11:11 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For 25% wear, it can depend. I don't know what is considered allowable wear for brakes, but I know that folks complaining about 20k replacements on past models (not Tacos) were told to go pound sand.
    Again, for the Taco, I'm betting bad / too fast measurements, versus actual wear.
  10. Apr 27, 2021 at 11:33 AM
    prefersdirt
    prefersdirt Well-Known Member
    2019 tacoma Sport
    Try another dealer. or mechanic. Brake shop will check for no cost to you.
  11. Apr 27, 2021 at 11:41 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    I would ask for a second opinion.
  12. Apr 27, 2021 at 11:45 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    Have them show you the wear with the shoes still on the truck. If true, then it's a warranty issue due to a failure of some kind. If not, find yourself a new dealership.
    I ran the shoes on my 2nd gen for over 100,000 miles and they still had a small amount of meat left. The drums were still original at 167,000.
  13. Apr 27, 2021 at 11:48 AM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    There must be something very wrong or the dealer is trying to take your money.
    my 2018 with 48,000 miles is still on the first set of pads . 99% of the time your rear drums on pickup trucks will go past 100k easy (less braking back there) .
    Another advantage of EV truck ... regenerative breaking , so much less use of pads . Also if buying Tesla no need to worry about dealer scammer scum .... cuz there are none. “But parts are hard to find and meh mehhhh mehhh “. Ok fine , keep going to the dealer , that’s probably better .
  14. Apr 27, 2021 at 11:55 AM
    CRSTRD
    CRSTRD Well-Known Member
    2020 Tacoma TRD Off Road
    Like others here, I'd check the measurements myself. Had similar issue with my wife's '18 when I took in for fuel pump recall. Was close to 30K so figured I'd let them do the service while it was there. Called to say front pads were at 3MM and recommended replacement. I declined but went ahead and bought the parts online. When I pick the truck up, their own paperwork said pads at 5MM...:annoyed:. This dealership is notorious but only 5-10 minutes from my house, I should have known better. At least I have the parts on hand when it actually does need brakes done.
    tonered likes this.
  15. Apr 27, 2021 at 12:16 PM
    #35
    JeepinDoug
    JeepinDoug Active Member
    Doug
    2019 TRD Pro Tacoma
    none
    They're trying to upsell you. All the dealers in my area do it.
  16. Apr 27, 2021 at 1:39 PM
    #36
    woods_24
    woods_24 Well-Known Member
    2009 Black TRD Sport DCLB
    As others have stated, stock drums last forever. My 2009 has 240,000kms and is on original rears.
    tonered likes this.
  17. Apr 27, 2021 at 1:41 PM
    #37
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's awesome.
  18. Apr 27, 2021 at 1:48 PM
    #38
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
    CrazyAirborne and devale like this.
  19. Apr 27, 2021 at 2:18 PM
    #39
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    Like everyone else has said, I call BS.
    If you’re worried that something is wrong which could be causing excess wear (say a sticking Wheel Cylinder) go for whatever is a normal drive for you, then measure the temperature of the outside of the drum with an IR Thermometer. If both sides are the same then everything is probably fine.
    tonered likes this.
  20. Apr 27, 2021 at 3:19 PM
    #40
    Burqueboy505
    Burqueboy505 Well-Known Member
    Albuquerque, NM
    2019 Cement OR DCSB
    Sort of off topic, but some advice: It's good practice to engage the parking brake before releasing the brake pedal when you park to avoid stress of the gears binding and other mishaps.
    Short story: my gf (who lives with me) parks her m/t Jetta in the garage. I came home from work one day, opened the garage door and out rolls her car, down my steep driveway and slammed into my neighbor's home across the street. It was a total disaster.
    ktbell444 likes this.
