Dealer claims spark plugs "stuck", need advice/opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ashjwilliams, Jul 5, 2015.
  1. Jul 5, 2015 at 2:01 PM
    ashjwilliams
    ashjwilliams [OP] Well-Known Member
    So I took my 2010 Tacoma (Dbl Cab 4x4 Sport, V6) in for front brakes and spark plug change over the weekend. The service technician could not get my spark plugs removed after multiple attempts. I got a call from the dealer explaining the situation and that they were going to have a master technician attempt to remove them Monday so I did not make a big deal of it, these things happen. However the service rep made the implication that I will be on the hook for additional costs of possibly removing broken spark plugs, removal of air intake manifold, heads, etc. At that point I immediately reminded this person that their service technicians were actually the last to change the spark plugs so if they over torqued them, or didn't use an anti-seize, cross threaded them, installed them in a hot engine, etc I would think that would be there problem, not mine. The service rep then made the comment that the service technician who previously worked on my vehicle no longer works there (ok, lol).
    1. The spark plugs were last changed at 29k miles by this dealer, and the vehicle now has 89k miles, so I suppose my missing the 60k change is a contributing factor.
    2. However my expectation is that if the plugs were torqued appropriately, anti seize was used, installed in cold engine, etc this would not be a problem correct? Otherwise how do people get away with the 100k intervals regarding the iridium plugs?
    3. Or is this just the type of thing that occasionally happens and thus my bad luck?
    I'm just trying to have an appropriate response for the scenario where even the master tech can't get them removed and they are then wanting to charge me hundred's of additional dollars in labor. My feeling is that if they had done this right at the 29k change this would be a non-issue, and thus I don't see why I should be paying for their mistake. Any advice/opinions appreciated.
  2. Jul 5, 2015 at 2:15 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    That does not happen if previous guy did his job correctly. So pay them nothing extra. They own it
  3. Jul 5, 2015 at 2:40 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    hmm...
    have they fucked ANYTHING up.... ie stripped plugs broken them etc?
    If not and the truck still runs.... take the truck dont let them ever touch it again. Dealers are incompetent. For something like this, id bet some aerokroil would loosen those bitches right up.
    billybobthornton and 12TRDTacoma like this.
  4. Jul 5, 2015 at 2:59 PM
    Pigpen
    Dan
    Northwest Montana
    I had a similar experience, but with my transmission fill plug. I paid for the first fluid change, but was going to do the second myself. After wrecking the plug trying to remove it, I took it in. I told them what happened and got the same "that tech no longer works here" story. I told them I'd pay for the regular service again if they deal with the plug. "No problem" was the reply. When it came time to pay, the service manager brought the bill with an extra $100 tacked on because they had to remove the front drive shaft to remove the plug. I reminded him that it was their guy who got the plug stuck, not me. He wouldn't budge, but offered me a free oil change. I laughed and told him that I don't trust his guys to do an oil change after this experience.
  5. Jul 5, 2015 at 5:20 PM
    ashjwilliams
    Thanks for the replies guys. I'd like to cut them loose but now that they have screwed it up I'm sort of hoping they will resolve it. I will give the master tech a chance tomorrow, and remain optimistic. It is generally sort of ridiculous, I opt to pay them $100 in labor so that I can avoid such issues and concerns and they themselves mess up such a simple task (I suspect the guy hand torque'ed them). If I had garage space, etc I would do this work myself but I don't (live in apartment).
    Regarding have they f'ed them up, well yeah it sounds like they have them in there so tight that a mechanic can't remove them after 3 or 4 tries. I guess that is sort of f'ed up.
    Reminds me of the time I took my Acura to a Valvoline for an oil change and after the "tech" had removed 3 to 4 bolts from my transmission (I was literally watching bolts pile up as I was somewhat observing) I had to point him at the oil drain plug.
  6. Jul 5, 2015 at 6:51 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Are you sure you're not driving a Ford with a Triton 5.4L V8?
  7. Jul 5, 2015 at 8:19 PM
    ashjwilliams
    Makes you feel like it lol. When I was doing some reading about this issue I came across the ford 5.4 problems...what a nightmare.
  8. Jul 5, 2015 at 8:28 PM
    kpla51
    kpla51 Well-Known Member
    Fort Campbell
    I worry so much about this crap. Just changed my plugs and torqued to 14ft lbs. But I did a double click on every plug is this bad? IE I torqued until click then backed off and torqued till clicked again. Seemed like the plug got a little snugger on the second click might of been the crush washer? I have a 2.7l don't know if the torque specs matter between the 4.0 and 2.7
    Don't get me started on the anti size no anti size thing the internet will drive you crazy sometimes.
    Best of luck to you hope there able or your able to get them out with out damage. I know the terrible feeling.
  9. Jul 5, 2015 at 9:10 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Let us know how it works out. Too many here have gone way more than 60K w/o changing plugs and got thru it.
    As mentioned above, the plug change at 29K was botched or they botched something while doing the current plug change.
    No one will ever change plugs on my truck but me.
  10. Jul 5, 2015 at 9:20 PM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Just something to read about spark plug installation from NGK. They don't recommend anti seize for their plugs and I'm pretty sure Denso doesn't either. It sounds counterintuitive but their is some science behind it.
    http://www.ngksparkplugs.com/pdf/dyk_5points.pdf
  11. Jul 5, 2015 at 9:24 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^This question has been thoroughly discussed in other threads. NGK's instructions are to appeal to the lowest common denominator. You will actually get more consistent preload by using antiseize, running down the plugs by hand, then giving it 1/4 turn with a ratchet handle.
    The method with the greatest chance of success on the Ford 5.4 is to soak the plugs in penetrating oil, then use an impact wrench to get them out. The Toyota dealer tech could try somthing similar.
  12. Jul 5, 2015 at 9:48 PM
    bigd9247
    bigd9247 Well-Known Member
    WA
    2024 TRD ORP, 2018 F150
    You should be fine. I just changed mine for the second time (60k miles) this morning and they were easy to remove. The key is to use anitseize on the plugs. I did that when I changed them at 30k and it was so much easier to get them out this time. The factory plugs had no antiseize on them and they were a lot harder to break loose. For what it's worth, I do the double-click method as well...
  13. Jul 5, 2015 at 10:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Marked for info.
  14. Jul 6, 2015 at 4:51 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The fact that you went 60k miles without having the plugs changed isn't the dealerships fault. Anti-seize doesn't last forever especially being exposed to engine heat & other conditions for that many miles.
    I change mine every 30k miles and sometimes I get one or two plugs that require extra effort to get them out ( which is surprising). I use anti-seize and proper torque. I wouldn't want to go 10k miles past due knowing what a headache it could be.
  15. Jul 6, 2015 at 6:03 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    The dealer can always claim is that someone else did the 60k change and they are responsible for the stuck plugs...penetrating oil, impact gun, best of luck.
    Howard
  16. Jul 6, 2015 at 6:06 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Although, to be fair some manufacturers use platinum plugs and don't require such short intervals. My Subaru H6 engines were 60k intervals and many folks would get iridium plugs and go 90k the second time with no issues because they were so frustrating to change.
  17. Jul 6, 2015 at 6:09 AM
    JBecker
    Virginia
    Most manufacturers don't call for anti seize there, so...
  18. Jul 6, 2015 at 6:13 AM
    marshall765
    marshall765 Well-Known Member
    Shreveport Louisiana
    13 DCSB TRD Offroad 4x4
    PB Blaster is from heaven.
  19. Jul 6, 2015 at 6:31 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I installed NGK plugs with no anti-seize. Came out 65k later with no trouble.
    Dealer's problem. A tech is faceless. The work was done by the dealer. Them firing a tech doesn't suddenly make them not liable.
    Large, devkurf and BudMan like this.
  20. Jul 6, 2015 at 6:47 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Yikes, hope it turns out OK.
    This is exactly why I do most of my maintenance. Plugs are easy and much cheaper to do yourself.
