Dealer claims spark plugs "stuck", need advice/opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ashjwilliams, Jul 5, 2015.
  1. Jul 6, 2015 at 3:07 PM
    #41
    kpla51
    kpla51 Well-Known Member
    Fort Campbell
    Learn to do your own simple maintenance. I always did my own oil changes and the one time I took it in for a free one because I was a little tight on cash that month they didn't tighten the oil filter down all the way. When I got home I noticed oil dripping from under my truck. Don't trust them they probably know as much as you and are back in the bay looking up youtube videos on how to fix your truck.
    Lester Lugnut likes this.
  2. Jul 6, 2015 at 3:18 PM
    #42
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I asked the same question 3 years ago in Chris4x4's write-up thread. Answer:
    TacomaMike37[QUOTED] likes this.
  3. Jul 6, 2015 at 3:35 PM
    #43
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Heh. Chris's answer doesn't account for engine idle wear. Engine is wearing but wheels aren't a-turning. In a perfect world, our trucks would have a run-time clock in addition to the odometer. :D
  4. Jul 6, 2015 at 6:51 PM
    #44
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The weekend lube "tech" probably couldn't find the spark plugs, since there are no plug wires to follow to the plugs. Glad it was a false alarm.
  5. Jul 6, 2015 at 6:58 PM
    #45
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    If you can, change plugs when engine is still warm. Block will be "expanded", plugs won't and should thread out. If not, use a little PB blaster, let it sit for a day, try again. No luck, do it again. Had to do this before, worked like a charm.
  6. Jul 6, 2015 at 7:00 PM
    #46
    scocar
    scocar hypotenoper
    WTF. Do you have Bluetooth plugs?
  7. Jul 6, 2015 at 7:04 PM
    #47
    kpla51
    Fort Campbell
    Mine does, the dealer also changed my blinker fluid for free because I bought the premium wifi+bluetooth plugs.
    Mobtown Offroad likes this.
  8. Jul 6, 2015 at 7:07 PM
    #48
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    I have the upgraded premium WiFi+Bluetooth headlights.
  9. Jul 6, 2015 at 7:09 PM
    #49
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Always get the flowbehead extender valve cleaned when having the tires rotated.
  10. Jul 6, 2015 at 7:14 PM
    #50
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You got bent over. Bent... the... f... over.
  11. Jul 6, 2015 at 7:17 PM
    #51
    landphil
    BC, Canada
    Tundra 5.7 mod
    No, coil packs with no plug wires. Just like you would if you were cool enough to have a 2nd gen.
  12. Jul 6, 2015 at 7:19 PM
    #52
    Pigpen
    Dan
    Northwest Montana
    They probably didn't change them - just said get this guy outta here and take his money.
  13. Jul 6, 2015 at 7:31 PM
    #53
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I use anti-seize on aluminum heads.
    I would go the PB blaster or Kroil as mentioned before. I am not sure I have the balls to use and impact on the spark plugs.
    However, I might attempt to pull the plugs on a hot engine. Aluminum expands more than steel. it might give you an edge.
    If all goes to crap, you can helicoil.
    For the record, I just swapped the plugs and had about 50K between the last interval. They came out easy. ( I had previously used anti-sieze).
    Torspd likes this.
  14. Jul 6, 2015 at 8:10 PM
    #54
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    buddies moms 5.4 on her 99 ford just spit a plug... took allllll of the threads with it. Just be glad you dont have to deal with that.
    12TRDTacoma likes this.
  15. Jul 7, 2015 at 6:58 AM
    #55
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Don't be surprised if next time you go in there to change them they are still stuck. They didn't change a thing
  16. Jul 7, 2015 at 7:28 AM
    #56
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This one sounds like a shitshow. Exactly why I don't deal woth the dealer for larger services like that. They are incompetent and will attempt to use firing someone as a scapegoat for not absorbing something that fell under their umbrella of services.
    Being that these are aluminum blocks the plugs should actually come out easier when hot due to aluminum vs. Metal thermal expansion properties. In my years of wrenching, all of the plugs I have pulled never had anti seize going out nor in and was never a factor honestly. If plugs were on the difficult side coming out I would spray some sort of lubricating oil, WD40, PB Blaster etc. And I would make sure to slowly turn out a few turns then back in those same amount of turns to work the threads and make sure that I wouldn't pull them with the plug. Never had an issue whatsoever.
    Matter of fact, at my 60K supercharger install the spark plugs came right out of my truck no problem, same deal, no anti seize coming out, and I put none going in. I sleep the same way at night after the install. Lol
  17. Jul 7, 2015 at 7:32 AM
    #57
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Spark plugs must be changed at specified interval in order to keep emissions warranty intact. Same applies to Toyota. Read your warranty info that came with owners manual.
  18. Jul 7, 2015 at 7:33 AM
    #58
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I never understood how is that even possible. Did they made those heads with playdoo ? Spark plugs are not long enough ?
  19. Jul 7, 2015 at 7:37 AM
    #59
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I had one of these come into the shop I worked at once. Weirdest thing ever. Makes you wonder if they used inferior metal to build those engines. Which the answer to that is probably a yes. There is simply no reason as to why a plug should ever be spit out like that. Ever.
  20. Jul 7, 2015 at 8:23 AM
    #60
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    The exposed ends of the plugs tend to "carbon up" and tend to damage the soft threads, leading to later failure. The reason the use of anti-seize is discouraged is that it LOWERS the torque needed for proper fastening, leading to over torqueing and damage. A heavy dose of techron, with a flush of a clean tank of gas might help. But soaking with penetrating oil, repeat, soak, repeat MIGHT also help.
    My buddy had a V10 Excursion he got cheap, at 100k plugs had never been changed, then when trying to solve a miss, two holes stripped out, with an eventual diagnosis of a burnt valve. To grind a valve, heads had to come out, to get the heads off, motor had to come out, to get the motor out, body had to come off the frame. Vehicle got junked...
