Dealer claims spark plugs "stuck", need advice/opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ashjwilliams, Jul 5, 2015.
  1. Jul 7, 2015 at 8:29 AM
    #61
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    ^ Original owner should have just used antiseize. Lol.
  2. Jul 7, 2015 at 8:32 AM
    #62
    12TRDTacoma
    Rob
    Concordia
    Boosted
    LOL. Sounds like 10 cylinders of pure american junk.
    Torspd[QUOTED] likes this.
  3. Jul 7, 2015 at 8:41 AM
    #63
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Original owner never touched the engine, just turned it in at the end of the lease, however, my buddy should have wondered why a 4 year old massive SUV, with original cost of 60k plus, was only going for 6k at 90k miles...a loss of value of depreciation of $1,125 PER MONTH.
    The same numbers for my Tacoma would be 28k new/21k at four years or 7k/48 = $145/month, almost 1/10 the depreciation loss of the exploder, give or take $20/month. My 07 Dodge Ram 1500ST had REAL depreciation loss of $156/month over the same four years.
    Howard
  4. Jul 7, 2015 at 8:47 AM
    #64
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I've changed mine at 30k intervals myself at home, never used anti-seize and never once had a problem. Technician definitely screwed up.
    12TRDTacoma likes this.
  5. Jul 7, 2015 at 9:28 AM
    #65
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Heads are OK. Ford trying to reinvent the spark plug by making the body 2-piece was the problem... http://www.consumerreports.org/cro/news/2014/04/ford-triton-v8-engine-spark-plug-tsb/index.htm
    There are relatively inexpensive extractor tools available now specifically for this problem in Fords: http://www.amazon.com/Lisle-LIS65600-Broken-Remover-Engines/dp/B00267PZUK
    Can't remember if the Ford Excursion was heavy enough to qualify for capital equipment subsidies like the Hummer H2 lol.
  6. Jul 7, 2015 at 12:26 PM
    #66
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i'm glad this is resolved.
    i would have at least looked at the old sparkplugs..not that they couldnt go and get any sparkplugs. at some point there needs to be some faith.
    there is no way to get an impact gun into that tight space..right?
  7. Jul 7, 2015 at 12:28 PM
    #67
    Old School
    Old School You are ignoring covfefe by this member.
    Impact gun spark plugs!
    Hell no!
  8. Jul 7, 2015 at 12:43 PM
    #68
    aficianado
    back to bone stock.
    Not me. It was mentioned above.
  9. Jul 7, 2015 at 12:48 PM
    #69
    Diamond-X
    Diamond-X New Member
    2015 Tacoma
    I have removed all the stickers
    My V-10 6.8L Excursion went 241,200 miles before I traded it in. I replaced the spark plugs three times in that time.
    Hardly junk.
  10. Jul 7, 2015 at 12:53 PM
    #70
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    My 1st gen has coil packs, no wires.
  11. Jul 7, 2015 at 12:57 PM
    #71
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    To each there own I change my plugs and fuel filter every spring Could be 10 to 15 thousand miles could just as easy be 5000.
    I use a copper based never seize put them in by hand 1/4 turn with a 3/8 ratchet.
    Knock on wood in 40 years never broke a plug or failed to get one out.
    The problem with the OP there is no way it could proved who worked on it last in that many miles.
  12. Jul 7, 2015 at 1:06 PM
    #72
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    If it's the 3.4 it's coil on plug on one side and a coil pack with 3 plug wires on the other.
  13. Jul 7, 2015 at 1:07 PM
    #73
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    2.7.
    No wires
  14. Jul 7, 2015 at 1:08 PM
    #74
    JBecker
    Virginia
    Ah. When I worked in parts and someone needed a tune up for their 3.4 they always thought I was trying to rip them off when I handed them a box with only 3 wires lol.
  15. Jul 7, 2015 at 1:10 PM
    #75
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Honestly i have seen plugs back out before (pops had an old 89 yota pickup with the 22RE.... driving to work had one spin out.... kept driving on 3 cylinders to get to work.... threaded it back in, tightened them all... zero issues)
    But this one in my buddies ford was WEIRD. the ceramic / center electrode spun inside the metal threads and ground. So the threads were able to spin and back out and go to the point where it just ripped the rest of the threads out.
    Oh and... that 5.4 in that year f150 is HORRIBLY placed.... the very front spark plugs are all of 6in from the firewall... the other 3 on each side are burried BEHIND the firewall in the tunnel. So glad im not working on that truck.
  16. Jul 7, 2015 at 3:33 PM
    #76
    KenLyns
    Belly of the Beast
    To loosen, sure. It's actually the method with the highest success rate on the Ford 5.4s.
  17. Jul 7, 2015 at 3:57 PM
    #77
    Old School
    Maybe on your Fords, but in some cases that could rip the threads out of the head!
    I prefer penetrating oil, some heat, like has already been suggested.
  18. Jul 7, 2015 at 4:18 PM
    #78
    ashjwilliams
    ashjwilliams [OP] Well-Known Member
    I didn't put too much thought to them having not actually performed the service. You really think that's a possibility at a certified Toyota? As much time as they invested I wouldn't think they'd just bail lol.
    I do most of my maintenance excluding brakes and spark plugs. By the time the next service interval comes around I should be done with apt living, have a garage, more room for tools, etc.
    So install cold but remove hot, 15 ftlbs? Anti seize or no anti seize? Sounds like conflicting opinions exist on this.
    I read one of the other problems with the 5.4 is it doesn't have much thread engagement.
  19. Jul 7, 2015 at 4:34 PM
    #79
    KenLyns
    Belly of the Beast
    Plugs are cheap and the $250-$300 the dealer charges is mostly labor, so spark plug replacement is one of the more worthwhile jobs to do yourself.
    Anti-seize is preferred. However, don't torque it to the service manual spec. Just run the plug down by hand with the socket extension (the anti-seize makes it easy to feel when the plug has bottomed), then snap on the ratchet handle and give it an extra quarter turn.
    I don't own Fords. :p The info comes from Ford dealer mechanics at /r/Justrolledintotheshop/. You are more likely to rip the threads out with a manual ratchet than an impact, actually. An impact wrench gives a series of taps rather than continuous torsion. Of course you can use oil and heat in conjunction with an impact.
    File IFR likes this.
  20. Jul 7, 2015 at 4:45 PM
    #80
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Truth
