Dealer coolant change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cosmo24, Jan 7, 2022.
  1. Jan 9, 2022 at 1:02 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Ditto TnShooter. The radiator petcock drain has an o-ring so you just close it until it stops.. no need to go any further. It's very unlikely to back out on its own as well.
  2. Jan 9, 2022 at 2:06 PM
    Waasheem
    Waasheem
    2007 xrunner
    I've had many of those stupid plastic petcock snap off as soon as you try to twist it. I found this tool that helps getting at the ones buried deep down where there's not a chance you'll get your hand on it. It doesn’t lock on like a normal socket so I usually tape it to an extension.
    Thexton THE485
    Jimmyh likes this.
  3. Jan 9, 2022 at 2:11 PM
    TacoTuesday1
    SD CA
    I'll give it a try next time but does that really work?
    I thought it was simply a flat blade to grip pliers onto
    wow had no idea such a tool existed
    I need that...
  4. Jan 9, 2022 at 3:22 PM
    2015WhiteOR
    Gainesville TX
    Curious if the petcock drain plug can be fully removed and then coated with a light amount of silicone so that it doesn't "stick" and break later.. probably would contaminate the cooling system so not worth it.
  5. Jan 9, 2022 at 3:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It does have wings.
    But the socket fits right over them.
    FWIW, I didn’t figure this out myself.
    A Toyota Tech gave me that little tip:thumbsup:
  6. Jan 9, 2022 at 5:22 PM
    Waasheem
    Waasheem
    2007 xrunner
  7. Jan 9, 2022 at 5:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Nothing wrong with a small dab of dielectric or caliper grease on a o-ring. Sometimes they'll be flat after sitting in the bore for so long, I keep a small o-ring selection close by so i can replace them as needed.
    The only way those plastic petcocks will break is if somebody overtightened it
  8. Jan 9, 2022 at 5:52 PM
    TacoTuesday1
    SD CA
    I'm guessing all radiators are 1/4" NPT petcock then
    or whatever they are
    the uniformity would make sense given they're all typically plastic flatblade valve and supplied to automakers by the same manufacturers (Nissens, etc.)
  9. Jan 9, 2022 at 6:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'd expect more trouble with metal petcock than plastic. Metal will get corroded, especially mounted at the bottom of a radiator near the ground
  10. Jan 9, 2022 at 6:19 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    yup! I use the socket to loosen it every time. Works perfectly
  11. Jan 9, 2022 at 7:57 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’ve only ever seen 2 sizes. Small ones and big ones. I’m guessing there’s other sizes, I think the small ones I’ve seen aren’t pipe thread, and are metric, maybe m8 1.25. The majority of issues I’ve had with them is on water pump bleeders that use a plastic petcock.
