Dealer cost to register new TPMS sensors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by corona56, Dec 13, 2011.
  1. Dec 13, 2011 at 2:48 PM
    corona56
    corona56 [OP] Well-Known Member
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    Added fog light mod Added delay wiper mod Alloy rims with BF Goodrich tires
    Does anyone know what the dealer will typically charge to register four new TPMS sensors? I am just trying to determine the cost of just getting a wheel and tire package with new sensors vs. having a local installer remove my existing sensors. Thanks all.
  2. Dec 13, 2011 at 3:17 PM
    Silver06Taco
    Silver06Taco Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    You would probably get a better answer by calling your local dealer. A tire shop would also have after market sensors that they could program.
  3. Dec 14, 2011 at 3:31 AM
    tonto340
    tonto340 Well-Known Member
    Gambrills, MD
    You can buy the ATEQ TPMS Quickset tool and program the sensor IDs yourself.
  4. Dec 14, 2011 at 3:32 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    My dealer charges 116 per sensor
    It's bs
    specter208 likes this.
  5. Dec 14, 2011 at 3:41 AM
    darcivic00si
    darcivic00si Love this forum!
    Darci
    Tucson, AZ
    '20 Super White TRD PRO Manual!!!
    I think it was around $100 total for all 4 at my dealer. Your best bet is to call your local dealer. The prices for things like that vary way too much...
  6. Dec 14, 2011 at 5:04 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Sensors are about $120/pc. If you have Toyota sensors from another Tacoma, they will charge about $100 to program them to your truck. If you don't mind not having TPMS, you can build a pressure chamber for $15 or so that will hold your TPMS at 30 psi and trick your light to stay off. They are non-functional at that point though.
  7. Dec 14, 2011 at 5:36 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
  8. Dec 14, 2011 at 8:26 AM
    corona56
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    You guys are awesome. Thanks so much for the help. I can get sensors from tirerack and other sources for about $75 each. I am just trying to figure the entire cost if I order a wheel/tire set with TPMS installed and I have to go battle the stealership to preprogram the TPMS computer to recognize the new sensors. You guys gave me a ton of information.
  9. Dec 14, 2011 at 8:31 AM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    :eek: damn mine has done it twice for free
  10. Dec 14, 2011 at 8:33 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    maybe a little late, but i just had mine reprogrammed by the dealer... cost $109.
  11. Dec 14, 2011 at 8:41 AM
    corona56
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    At these prices, the tool might be the best option. It also saves the time sitting at the dealer waiting for the work.
  12. Dec 14, 2011 at 8:44 AM
    corona56
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    I think TPMS is a useless feature; but I hate mickey mousing an almost new truck.
  13. Dec 14, 2011 at 9:51 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    x2! i don't need a warning light to tell me i have a flat tire.
  14. Dec 14, 2011 at 9:56 AM
    corona56
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    Right!. Stupid feature.
  15. Dec 14, 2011 at 10:04 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    Dealer charged me $50, I had the id codes written down. I heard later the device the dealer uses can read the codes from each wheel, while mounted and reprogram the ECM. I thought I was saving time, and a possible wheel disassembly, but evidently not. @ $50, The tirerack tool would take about 3 swaps to pay for itself, but I don't plan to swap again.
  16. Jun 12, 2016 at 11:06 PM
    000doodie000
    000doodie000 Well-Known Member
    J
    2015 Taco TRD Off-Road
    Many and always modding Wheels Suspension lift Armor Electrical gadgets etc...
    So if I pick up a set of winter tires/wheels with the TPMS in them, I have to reprogram once and then I can swap them myself back and forth for winter and summer driving correct?
    I have a 2015 TRD off-road.
  17. Jun 13, 2016 at 1:34 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm pretty sure you will have to have them reprogrammed each swap. Unless they changed the ECU after the 2012 model year there is only room for a maximum of 5 sensors to be registered in the software.
  18. Jun 13, 2016 at 3:17 AM
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    TPMS sensor you can buy new on ebay for about $100 the set if you look. America's tire did it for free when I had them install tires on my wheels... Cost me a bit over $100 for labor of installing the tire and life time balance/rotation... they programmed and gave me a print out of the ID because I asked for it...in case I need it for the future.
  19. Jun 13, 2016 at 11:03 AM
    ZRXDean
    ZRXDean Well-Known Member
    Langhorne PA
    DCLB - Pabst Metallic
    OME 885, Billstein 5100, Deaver 2" AAL, ARE CX Cap, Go Rhino Dominator steps
    $120 at my dealer. Their "programmer" couldn't "see" my sensors to reset them so I said bag it for now and have been riding around with the light on...
    It's due back for my Toyotacare oil change in a couple hundred miles and I grabbed the numbers from Discount Tire (where I got my wheels and tires), wrote them down and will have them done during my oil change.
