Dealer Damaged my truck and won't repair
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dennis69, Dec 6, 2012.
  1. Dec 6, 2012 at 9:19 AM
    Dennis69
    Dennis69 [OP] Active Member
    Cape Breton,Nova Scotia
    2010 tacoma 4x4 access SR5
    Took my 2010 tacoma into the dealer to have my stereo replaced under warranty.when I picked up my truck later in the day there was a chuck taken out of the dash pad just above the stereo.I then notice the Bezel all around the stereo head had deep chunks and scratches.It appeared that someone tryied to pry the stereo head out of its mounting area.The service manager came out and took a ton of pics and said he would contact me when the parts arrive and appoligized for the damage.well 6 weeks later no world from the dealer, so when I called the service manager he replied with the parts are on "back order". I then called Toyota Canada to hopefully expidite the process.Well 3.5 weeks later I finally get my truck in and the dealer replaced the bezel which now looks new again.The chunk that was taken out of the dash pad was filled with paint.The service manager said it will be fine and that there was many layers of paint applied to fill the hole.I told the service manager that the repair wasn't exceptable which he replied...its too expensive to replace it! and offered some free oil changes in Lieu which I declined.so to make a long story short..Called Toyota canada back and they had their managment team member that was dealing with the file return my call.Max the rep from toyota canada informed me that although your truck was in getting warranty that they have no authority over the dealership to repair any damage that is done and that I will need to deal with the service manager on this matter.He suggested I email the president of Toyota Canada if that wasn't to my liking. any thoughts would be appriciated....all I want is my truck back to what it was before I took it in for warranty!
  2. Dec 6, 2012 at 9:22 AM
    Cbass38
    Cbass38 Well-Known Member
    sebastian
    scottsdale
    07 pre runner
    projector hids,wheels,small lift,flowmaster
    go to his boss,either the service director or general manager. if they fucked up your dash they need to replace it.
    when people come into my dealership,if they complain enough anything is free. it sucks because alot of people take advantage of it,but in your case its needed.
  3. Dec 6, 2012 at 9:31 AM
    Hurtin Albertan
    Hurtin Albertan Free Man
    Duck
    on the road less traveled
    The mud hides the tree scrapes in the paint
    Huskyliner floor mats
    It is frustrating. A tech at my local dealer broke my dipstick while doing a service. They refused to cover replacement because it was my fault for choosing their shop for servicing. $27 and one week later I got my new dipstick. 6 months after that I spent $40000 at a different dealership, buying a new vehicle. I hope they didn't spend my $27 bucks all in one place. :p
  4. Dec 6, 2012 at 12:16 PM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    (1) 4'x8' sheet of plywood
    Misc paint colors to your liking
    Lawn chair, cooler w/ food and beverages
    Paint basic message on plywood "damaged under warranty, will not repair" or whatever you see fit.
    Park yourself, truck, and plywood in front of/near the dealership before they open. Make sure you are on PUBLIC property, or obtain permission from the property owner to park there.
    Dealership manager sees you, sends some "pee-on" out to go get you. Hash it out politely. If they won't budge, thank them for their time, return to your spot and put the sign back up.
  5. Dec 6, 2012 at 12:18 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    ^ This
    Don't forget someone to take pictures and post them on here.
  6. Dec 6, 2012 at 12:29 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    First go to the general manager or the top guy you can talk to. Work your way through them, being courteous and explaining what you expect. When those fail, I've found that it's not hard to get the owner's phone number. I guarantee when you call the owner and tell him none of his workers wanted to fix this, shit will get done pretty quickly.
  7. Dec 6, 2012 at 12:57 PM
    RedTacoDriver
    RedTacoDriver Out of my mind....be back later.
    Dale
    Portland, OR
    2012 Tacoma Regular Cab 2.7L
    BakFlipG2, Westin Nerf Bars, Harbor Freight Bed Jacks, Flame Devil Horns, vinyl raven emblems, intermittent wiper switch swapout More to come.
    The alternative is to take it to the local news outlet. They love that kind of "investigative" reporting and "human interest" type of story. David versus Goliath and all that.
  8. Dec 6, 2012 at 12:57 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If it's so expensive they shouldn't have damaged it then... they need to fix their mistake.
    edit: Op... could you post a picture of said damage?
  9. Dec 6, 2012 at 1:01 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    no you wouldn't :rolleyes:
  10. Dec 6, 2012 at 1:51 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Let's see pics of said damage
  11. Dec 6, 2012 at 4:36 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
  12. Dec 6, 2012 at 4:40 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Small claims court. :evil:
  13. Dec 6, 2012 at 4:46 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    tl;dr. Call Michael Automotive in Fresno, they'll give you a new truck.
  14. Dec 6, 2012 at 8:47 PM
    CLynch
    CLynch Well-Known Member
    Charlie
    Upstate New York
    None
    LOL'z
  15. Dec 6, 2012 at 10:43 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    One well written letter from a lawyer (or Paralegal on company letterhead) will usually get the job done.
  16. Dec 6, 2012 at 10:51 PM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    Sub'd. This is getting good...:popcorn:
