Dealer drive line fluid change
Discussion in '1st Gen. Tacomas (1995-2004)' started by RockyTacoma, Jul 22, 2010.
  1. Jul 22, 2010 at 6:59 AM
    RockyTacoma
    RockyTacoma [OP] Well-Known Member
    Dojo
    colorado
    2002 tacoma trd
    stock
    I WAS QUOTED $169 FOR 02 trd FRONT , REAR, AND TRANSFER CASE FLUID CHANGE FROM LOCAL TOYOTA DEALER. SOUND LIKE GOOD DEAL TO ME. WHAT DO YOU GUYS THINK
  2. Jul 22, 2010 at 7:11 AM
    S-Runner '01
    S-Runner '01 Elderly Gentleman - Junior Member
    Jerry
    Yakima "the Palm Springs of Central Washington"
    BSP '01 S-Runner
    Garmin 260W - GPS Scanguage II K&N FIPK Kit Delta Low Profile Toolbox Fumoto Oil Drain Valve New Toyota Front Mats B&M Short Throw shifter New Tokico Gas Shocks Compustar Anti Theft Alarm System Redline Elite Hood Struts Phase Linear DVD/MP3/CD Player Professionally Detailed
    I think you could do it yourself for less than $40 and it ain't a real tough job.
    jj
  3. Jul 22, 2010 at 7:12 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    That seems about right from the dealer,the gaskets for the diffs need to be replaced also and only the dealer has these gaskets that I know of they are once used and replaced like a crush grommet unless you can buy them at an Auto parts store Ive never seen them I change the Oils myself and get the gaskets at the stealer. Id say yes that seems like a good price for the dealer,Jiffy Lube does this service too but they might use the old gaskets and maybe a leak could start knowing how they operate.
  4. Jul 22, 2010 at 7:14 AM
    Mush Mouse
    mush
    2013 SR5
    The toughest part is dropping the skid plate for the front diff youll need a 10mm Hex head to remove the front filler plug,and a 24mm socket for the rest not too hard.
  5. Jul 22, 2010 at 7:48 AM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    +1
  6. Jul 22, 2010 at 8:03 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah man do it yourself save 120 bucks and jump under your truck.
  7. Jul 22, 2010 at 9:06 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    x2
    I am guessing you have not done this before, so here's more detail to fire you up.
    It is a good job to do yourself because it familarizes you with your truck, and you can inspect a lot of other stuff while you are down there.
    It is one of the simplest jobs on the truck, as long as you know how to get the fill and drain plugs off. Sometimes they can be a little tricky (like, freaking stuck hard if they have not been off in a long time, or were overtorqued, or someone used the wrong crush washers before you), and you have to be careful, hit them with a wire brush first, then some PB blaster, then definitely use a breaker bar using a six point 24mm socket, and you may need a cheater pipe on that, too. This is usally an issue with the very exposed rear diff plugs. Entire threads have been dedicated to this issue alone...
    Make sure you get the correct crush washers. The front diff takes a large, thin copper one on the drain (I can't remember the fill, I think just a steel one like the r. diff 24mm), the transfer takes two aluminum ones, and the r. diff takes steel ones. Just get them from the dealer. Steel to steel, alum. to alum.
    Also get a cheap fluid pump that fits in the oil bottles. it is impossible to fill the front diff without one, and it just makes everything easier. So does a creeper.
    And always take of the fill plugs first. If you take of the drain plugs and empty it first, then can't get the fill plug off (or worse, strip it), you are, like, screwed.
    The skid plate is a little annoying because a little sheetmetal clip that is hard to see that holds the two plates together. Also, hooks help hold up the front of the front plate. Just loosen all seven bolts, then focus on getting the front plate off first.
    EDIT: And for the love of god, never take anything to Jiffy Lube for any reason.
