Dealer "forgot" oil change at 5k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sicnic, Oct 8, 2013.
  1. Oct 8, 2013 at 5:28 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    What was the part number? Of course it was from the manufacturer, dealers use OEM parts when they do service. Most of us also use the genuine toyota filters because they're quality and cheap. The one from the factory has a specific number on it though.
  2. Oct 8, 2013 at 10:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No, No and No.
    Link: http://toyota.custhelp.com/app/answe...nthetic-oil%3F
    What are the oil change intervals using synthetic oil?
    Only Toyota vehicles in which 0w-20 synthetic oil is required (except for the 2TR-FE & 3UR-FBE Engines*) have been approved for extended oil change intervals of 10,000-miles/12-months. (However, you should continue to check the oil level regularly and top off if needed. That will help your engine get the full benefit of synthetic oil.)
    • Vehicles in which 0w-20 is an option to 5w-20 mineral oil, (or 5w-30), will continue to require 5,000-mile/6-month oil change intervals, even if 0w-20 oil is used.
    • In the case of vehicles with 10,000 mile oil change intervals, the 5,000 mile service interval has not been eliminated. The traditional 5,000 mile maintenance procedures (such as tire rotation) will continue to be required, and the fluid levels (such as brake fluid) will need to be checked and adjusted at this time.
    • If the vehicle operation meets the standard criteria for "Special Operating Conditions" such as: driving off-road, on dirt roads, towing a trailer, making repeated short trips under 32˚ F, or extensive idling; the engine oil must be replaced at 5,000 mile intervals, regardless of what type of oil is used.
    *The 2TR-FE (4Runner / Tacoma) and the 3UR-FBE (Flex Fuel Tundra / Sequoia) are the exceptions to this new change interval program; these engines have not been approved for the 10,000 mile interval at this time. A 5,000-mile/6-month oil change interval is still required for these vehicles. Also, the Flex Fuel 3UR-FBE requires a 2,500 mile interval when operated on E85.
    This is what is listed as the 5,000 mile 6 month service for the 2014 Tacoma with the 2.7 liter engine:
    5,000 miles or 6 months
    Check installation of driver’s floor mat
    Inspect and adjust all fluid levels
    Inspect wiper blades
    Replace engine oil and oil filter
    Rotate tires
    Visually inspect brake linings/drums and
    brake pads/discs
  3. Oct 9, 2013 at 4:00 AM
    sicnic
    sicnic [OP] Member
    90915-20004 comes from the factory. this is the one I removed from my truck yesterday
