Dealer installed temporary security system?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tstack22, Feb 18, 2022.
  1. Feb 22, 2022 at 11:56 AM
    #41
    tstack22
    tstack22 [OP] Well-Known Member
    Arizona
    '22 TRD-OR 6MT
    UPDATE:
    The Dealer responded to my email with an agreement to remove the alarm and restore the wiring to its original condition. They'll even give me a loaner car while it's being done.
    While I'm not happy about the screw holes drilled into the dash, realistically it's something I'm not likely to regularly notice. Assuming they do restore everything else (I'll be sure to take plenty of photos to compare a before and after and ask for a record describing what was done), I'll be satisfied with the outcome. I was expecting them to tell me to pound sand, so a quick agreement with a loaner to boot is a pleasant surprise.
    Montana_Actual and Gen3TacomaOBX like this.
  2. Feb 22, 2022 at 12:00 PM
    #42
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Glad they agreed so quickly. I have to wonder what they are going to do about the wiring. Kinda hard to un-splice a wire unless they are replacing a harness.
  3. Feb 22, 2022 at 12:02 PM
    #43
    Sierrahunter
    Sierrahunter Well-Known Member
    2022 SR5 Double Cab Long Bed 4x4
    Seems like the best possible outcome.
  4. Feb 22, 2022 at 12:02 PM
    #44
    tcjacado
    tcjacado Well-Known Member
    Soldering and shrink wrap:fistbump:
    Montana_Actual and Lt. Dangle like this.
  5. Feb 22, 2022 at 12:06 PM
    #45
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    Is the piece that has been drilled an easily replaceable kick panel?
  6. Feb 22, 2022 at 12:09 PM
    #46
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
  7. Feb 22, 2022 at 12:11 PM
    #47
    tcjacado
    Only if they let the guy who does oil changes do it.:crapstorm:
  8. Feb 22, 2022 at 12:19 PM
    #48
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I'd have included a new dash as part of the restoration, then negotiated down from there. The holes aren't easily visible, but you could probably have wrung something out of them.
  9. Feb 22, 2022 at 8:00 PM
    #49
    taco92014
    taco92014 Well-Known Member
    San Diego, CA
    2021 Army Green TRDOR DCSB [Tacoma #2]
    KDmax-Pro, Bakflip F1, Pro Lights, SS3 Pro Fogs, MESO
    I walked around the CarMax lot in San Diego while I was Tacoma shopping and saw about half of the tacos on their lot had these little LEDs poking up from under the dash (or actually drilled into a switch blank). At first I thought they were old rental cars or something, I was honestly shocked at how many had the same kind of hack-job alarm wiring. It's ridiculous that dealers get away with mutilating the cars they sell - the shit-adhesive stickers are bad enough...
  10. Feb 22, 2022 at 8:12 PM
    #50
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Make sure to get the reason for the repair and their gaurantee in writing.
    whatstcp likes this.
  11. Feb 22, 2022 at 8:23 PM
    #51
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Service guys are on it!
  12. Feb 22, 2022 at 8:45 PM
    #52
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    @tstack22 don't be surprised if/when you see the "check electrical system" warning even when the dealer removes the alarm system.
    My truck displays that message almost ever time I have the ignition on for more than 30 seconds without starting the truck. I think if there's a certain draw on the battery without the truck running it'll display. I have dash cameras and other accessories that're wired directly to the battery so I imagine my voltage drops quicker than most.
  13. Feb 22, 2022 at 9:00 PM
    #53
    Couesfanatic
    Couesfanatic Well-Known Member
    I purposely avoided a local dealer that does this. They do this to every vehicle they have.
    Chew, Montana_Actual and whatstcp like this.
  14. Feb 22, 2022 at 9:09 PM
    #54
    Vikter
    Vikter Member
    2021 DCSB TRD Sport 4WD Silver Sky Metallic
  15. Feb 23, 2022 at 1:36 PM
    #55
    HisDad
    Texas at last
    I learned a long time ago, during a short stint working for a stereo shop, that dealers subbed alarm installation out. They paid $.X.X and pretty much doubled whatever that was. The installations weren't as good as the ones that the shops did for their own customers either.
    One of the first things I did when I bought my 2019 was take it to a shop I've done business with since they opened in the early 1990s. I got a much better system for a lot less money than if I had bought it through the dealer.
  16. Feb 23, 2022 at 9:22 PM
    #56
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Thats normal because the truck thinks the engine is running and the volts are low. i have a 16 and always see that when its not on(running) I have push to start....
    tstack22[OP] likes this.
  17. Feb 23, 2022 at 10:24 PM
    #57
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    This is fucking insane dude. Infuriates me. I’m a dealer employee and I’d never pull this shit. Wow I’m fucking mad holy shit this pissed me off. Unacceptable shit. I’d be driving it right back and demanding it to be fixed to my satisfaction
    edit: just read threw and saw they fixed it for the most part. Still really ticked me off.
  18. Feb 23, 2022 at 10:54 PM
    #58
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Most dealers outsource any non-OEM work. See that truck with big tires and $3000 spacer lift in the showroom? Usually outsourced to a 4WheelParts. As you expect, dealers make more from these add-ons (and the extended warranty) than from the vehicle sale itself.
    tcjacado likes this.
  19. Feb 23, 2022 at 11:28 PM
    #59
    bursthead
    bursthead Well-Known Member
    2019 Tacoma TRD Pro
    When I was shopping for my tacoma. The dealerships like to install it them to increase their markup. I've seen them ask 500-1k for having stuff like that added. Its ridiculous that someone would pay for a dealership to screw up their wiring by installing a crappy alarm like that.
