Dealer mechanic may be wrong
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Yota, Mar 16, 2011.
  1. Mar 16, 2011 at 5:13 PM
    The Yota
    The Yota [OP] Gold Member
    Ben
    Nashville,TN
    2011 PreRunner TRD Sport
    Bilstien 5100 all 4 (front set .85),Bull Bar with Warn fog lights,DeeZee step bars,extang tonneau cover,bed divider/extender,hose clamp mod,foglight mod,K&N air filter,Graco baby seat
    I have a 2011 PreRunner Sport. Not doing any serious off-road and wanting alittle lift for bigger tires in the future. Went to dealership for ordering of the tsb. Ask mechanic about bilstein 5100 for front and he said that would make my truck ride like shit on the road and would not like it. He said to go with a 1 inch spacer and it wouldn't affect the ride. Don't want to F-UP my ride whats best for what I need.
  2. Mar 16, 2011 at 5:16 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Mine's stock, but it makes sense that a spacer will keep the same exact ride quality you have now. Other's will chime in on ride quality with the 5100s but most likely stiffer than stock for sure. Spacer may be a good option if you really just want the look of bigger tires.
  3. Mar 16, 2011 at 5:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Your dealer isnt that bright. Odds are, he's trying to push you to what they sell. Look around the site, and see what others are running.
  4. Mar 16, 2011 at 5:17 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Depends on what lift height you set the 5100's at. I would skip lift spacer at all cost. I bet he told you that because they sell spacers at the dealer, not 5100's.
  5. Mar 16, 2011 at 5:18 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Spacer = Shitty ride
  6. Mar 16, 2011 at 5:25 PM
    Firsttaco
    Firsttaco Well-Known Member
    alberta
    2009 Tacoma TRD Sport
    Bilstein 5100 all around, front set at 0 with OME 887. Light racing UCA. Dakar full pack in back. aluminum running boards. Scangauge II. Painted flat black rims. Raider canopy.
    I have spacers on my truck, if i could go back knowing what I know now I would stay far away from the spacers and get the 5100s
  7. Mar 16, 2011 at 5:26 PM
    The Yota
    Ben
    Nashville,TN
    He actually told me I could do the spacers myself and doing the bilstein myself would be a pain. If I went with bilsteins I'd set them at .85 I guess.
