Dealer Messed up Spring TSB. Put the wrong spring on passenger side.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, May 26, 2012.
  1. May 26, 2012 at 6:15 PM
    JUJtacoma2010
    JUJtacoma2010 [OP] Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    I just returned from the dealer and was excited to have the tsb done. but when I went under the truck to check it out, both springs look different. On the drivers side, they put 48220-35020 Spring Assy, FR LH (this has 6 square brackets/clips holding all the springs together)
    and on the passenger side 48210-04570 (this has 3 square brackets)
    The both look different.
    The forum says they should have put 48210-35A20 Spring Assy on the passengers side.
    I will call them on Monday. But the problem is that the spring tsb (page 3) says "Current Part Number" 48210-04570. Is there a document somewhere that gives the correct spring numbers? I want to have that when I talk to the dealer. People here say that that 48210-04570 has been upgraded but it would be nice if I had some document with me.
    What else should I say when I call them on monday?
    Please help guys.
  2. May 26, 2012 at 8:03 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    tell them to make it right
  3. May 26, 2012 at 8:36 PM
    JUJtacoma2010
    Fresno
    Isnt there a document somewhere that shows the correct part number?
  4. May 26, 2012 at 8:40 PM
    JUJtacoma2010
    Fresno
    How do we know that 48210-35A20 is the correct part #
  5. May 26, 2012 at 8:48 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
  6. May 26, 2012 at 10:15 PM
    JUJtacoma2010
    Fresno
    I have the tsb and basically I have memorized it. on page 3 it gives the part # but thats the old part #. thats the one they put in on the passengers side. Which is wrong.
    And many guys here say that that part is updated.
  7. May 27, 2012 at 5:03 AM
    tim allan
    tim allan Well-Known Member
    apex, nc
    2017 double cab trd offroad
    they may be doing a new pn for the springs as they are figuring out how to quite them down more, but def call the dealer
