Dealer "No Lifts on 2018"
Discussion in '3rd Gen. Tacomas (2016+)' started by yellowdogpaddler, Dec 6, 2017.
  1. Dec 6, 2017 at 4:37 AM
    yellowdogpaddler
    yellowdogpaddler [OP] Well-Known Member
    doug
    WhiteBear DCLBORP
    Husky Mats
    The dealer I am working with to order a 2018 Tacoma told me that all Toyotas across the board will have TSS and with that lifts will affect the TSS features. He told me that his dealership will not be doing lifts any more, and they do a lot, and his thought was that shops would not be doing them either. So lifting is still of course doable, but it will lose the sensor functions and void warranty. We discussed if aftermarket shops would do it and he cautioned me that some might but it becomes a huge legal/financial liability if an accident were to happen and they were to be potentially found at fault. This is the GM of the dealership and is being helpful not trying to blow me off. Thoughts?
  2. Dec 6, 2017 at 4:44 AM
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Go get a 17 now?
    DieselTech1, Roland79, Argo98 and 5 others like this.
  3. Dec 6, 2017 at 4:46 AM
    Coot83
    Coot83 BRO-UNIT
    Gringo Gordita
    Scottsdale, Az
    2012 TX 3.5"B" edition
    Stay dope breh
    Or snag a second gen that doesn't have any of this madness!
  4. Dec 6, 2017 at 4:48 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Would make sense this would apply to any vehicle any make ? :notsure:
    Wow if true.
    markelhof likes this.
  5. Dec 6, 2017 at 4:52 AM
    Wakecoach
    Wakecoach Kiwi in FL
    Kurt
    2015 White TRD Sport 4x4 2001 Subaru Legacy Wagon Bilstein Touring Edition
    King ext, res/adj...3leaf Aal. ECGS bushing. Bullaculla relocate bracket. Pelfrey bilt skids. TC UCA. K+N, Weathertech Mats, TRD side steps, BROV Tacoma Attic, Prinsu Cabrac, TRD OR Tow Hook
    Taco bandit did a good YouTube release on this yesterday if you search it. They say it's gonna throw all the sensors out of wack ..
    adrwshry, stealthmode, Saeros and 2 others like this.
  6. Dec 6, 2017 at 4:53 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    GJ,CO,USA
    Super White 2008 TRD OR AC M/T
    Unexceptional
    The Land Cruiser got some of this TSS junk starting in 2016 and they still do lifts on them AFAIK.
  7. Dec 6, 2017 at 4:53 AM
    Coot83
    Coot83 BRO-UNIT
    Gringo Gordita
    Scottsdale, Az
    Stay dope breh
    What functions are affected by the TSS sensors? Makes you wonder if Toyota is implementing this to try to deter folks from modifying their rides?
    Heepspo and AdventureKid like this.
  8. Dec 6, 2017 at 4:54 AM
    yellowdogpaddler
    doug
    WhiteBear DCLBORP
    Husky Mats
    I tried but they don't have what I want anywhere in the region and cannot allocate it from Toyota (too late in the year- already switched over to 2018 he told me)... That is the one thing that really frustrates me about Toyota is their pushing everyone down the same rabbit hole when wanting to order a vehicle specifically with what I want that matters to me, but cannot b/c it is not in one of their pre-designed setups. I understand profit and economies of scale... but com'on guys give us a little individuality.
    NickleCityTaco likes this.
  9. Dec 6, 2017 at 4:58 AM
    yellowdogpaddler
    doug
    WhiteBear DCLBORP
    Husky Mats
    Silver DCLB OR with technology
    Prairie Hawk likes this.
  10. Dec 6, 2017 at 5:01 AM
    funrobby
    funrobby Active Member
    Rob
    Austin, TX
    I wonder what the tolerance on the TSS-P is. For instance would no lift and a +1 tire add (like a 265/70r17) be ok?
  11. Dec 6, 2017 at 5:04 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    You will be fine lifting an 18. That’s just Toyota corporate covering their butt. What does TSS do when you load down the bed and the grill is pointed up? It might be a little less precise but how would that be different from a 17 without it?
  12. Dec 6, 2017 at 5:05 AM
    yellowdogpaddler
    doug
    WhiteBear DCLBORP
    Husky Mats
    OR
  13. Dec 6, 2017 at 5:06 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Or just turn it off.
    markelhof, hellppy, bski22 and 14 others like this.
  14. Dec 6, 2017 at 5:15 AM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    '17 OR DCSB 6MT *Inferno*
    Any change in the elevation of the sensor will effect the sensor. The system is expecting to see the ground a fixed distance away on level terrain. That said, lifting the truck won't cause it to spontaneously catch fire or turn into a Chevy, or some other horrible event.
    But it may cause unexpected behaviors unless you disable it.
    At some point in the next couple of months we will see aftermarket support of some sort with a bypass unit.
    JSmith501, 0uTkAsT, Roland79 and 6 others like this.
  15. Dec 6, 2017 at 5:23 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Red Stick, Louisiana
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    If it really is a problem, someone will likely come up with some type of recalibration kit for the sensor and charge 100 bucks for it.
    0uTkAsT, dtopgun515, musher and 8 others like this.
  16. Dec 6, 2017 at 5:38 AM
    2016Tacoman
    J
    Calibration for engines and trannys I can see but for accident prevention devices I believe it's another area of risk and responsibility here which is the issue. Who wants that risk for a $100 product ?
  17. Dec 6, 2017 at 5:40 AM
    DaveInDenver
    David
    GJ,CO,USA
    Unexceptional
    Depends on if it's a stock OR wheel.
  18. Dec 6, 2017 at 5:53 AM
    Haikin
    Haikin Well-Known Member
    The 2018 Pros come lifted. Not sure what Toyota’s logic is here...
    Sand Shark likes this.
  19. Dec 6, 2017 at 5:54 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    2018 4Runner
    Thinking about it.
    Disabling something you've gone your whole life without already doesn't increase your physical risk. Physical risk stays same as where you were before.
    Financial risk may be a question though if insurance decides not to cover an incident due to the disabled feature.
  20. Dec 6, 2017 at 6:01 AM
    prohunter4
    prohunter4 Well-Known Member
    South Ga
    2017 BBP TRD Off Road
    I can see someone dicking around with this safety shit, being involved in an accident, ambulance chasers get involved, insurance company says sorry, said person spends the rest of their life working for someone else.
    2016Tacoman likes this.
