Dealer Oil Change and Low Oil Pressure Warning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AZ_Tumbleweed, Jun 20, 2021.
  1. Jun 20, 2021 at 9:15 AM
    AZ_Tumbleweed
    AZ_Tumbleweed [OP] Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    Just got my truck back from the dealer for an oil change and now the truck keeps shutting off while driving and displays a Low Engine Oil and A/T Oil Temp error. Im having it towed to the dealer now which is unfortunately closed today. I see fresh oil in the dipstick. Anyone have any ideas what else it could be? if the engine was starved for oil for whatever reason what are my chances of getting an extended warranty for their mess up?
    16k miles on truck
  2. Jun 20, 2021 at 9:20 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    They're gonna say "no damage was done". Then you say, cool so you wont mind standing behind your statement / belief and giving me an extended powertrain warranty then, cool.
  3. Jun 20, 2021 at 12:28 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    This is why I spent 1 hour last Saturday changing my oil while listening to some good music……..
  4. Jun 20, 2021 at 12:35 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    knuckle draggers probably forgot to tighten the oil filter housing. Usually they over tighten that.
    I change my own. I hate it, but at least I know it has been done right.
    Millhouse516, Pro-Taco and kahanabob like this.
  5. Jun 20, 2021 at 12:40 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Could be a sensor or something, no oil starvation, just a bad reading?
  6. Jun 20, 2021 at 12:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Was the oil on the dip stick uto/close to the correct level?
    You wouldn’t be the first person to have those lights come on.
    It can be a myriad of things that can cause it.
    From stuff stuck in the Throttle Body, dented Trans pan, low oil, crank sensor, to pieces left out of the filter cartridge. It seems those are like “universal” warning lights?
    Here is just one example
    https://www.tacomaworld.com/threads/low-oil-pressure-high-atf-temp.524912/
    eurowner likes this.
  7. Jun 20, 2021 at 1:00 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Look underneath for any oil blowback on undercarriage? See if maybe the left a double gasket on the filter or plug backed out? Any leaking?
  8. Jun 21, 2021 at 12:02 PM
    AZ_Tumbleweed
    Wilmington, NC
    Thanks for the suggestions everyone. The dealer said theres oil in there and that message will appear if the vehicle dies while driving so its not related to the oil change.
    They are saying the issue is caused by the fuse tap i have to power my raptor lights and are going to further test to verify. I have it tapped into the INJ spot.
  9. Jun 21, 2021 at 12:11 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    This is why i never change my oil or have it changed, too many things can go wrong.
  10. Jun 21, 2021 at 12:13 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Yep. This is why I never eat or drink. Too big of a chance you can choke on that stuff.
    Doc62, Junkhead, eurowner and 4 others like this.
  11. Jun 21, 2021 at 12:29 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    This is why I never read anything on the internet especially on TW .
  12. Jun 21, 2021 at 12:34 PM
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    +1
    This is why I flat out refuse to use computers. I snail mail my posts into a 3rd party service that transcribes them on TW. Just too big of a risk of getting hacked by using a computer yourself.
    Doc62, whatstcp, Junkhead and 4 others like this.
  13. Jun 21, 2021 at 12:35 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    This is why I never install Raptor lights.
  14. Jun 21, 2021 at 12:38 PM
    eon_blue
    Azusa, CA
    Dealer changes oil, low oil pressure light comes on afterward, dealer blames raptor lights.
    I'm surprised they didn't try to say that your floor mats caused it
  15. Jun 21, 2021 at 12:40 PM
    AZ_Tumbleweed
    Wilmington, NC
    I agree, i've always changed the oil myself on my previous vehicles (jeep wranglers) as ive had nothing but bad experience and poor workmanship from FCA techs. I thought i had a free oil change left at the dealer and needed an alignment done too so figured i have them do it as i heard toyota techs are more capable, plus its 115 degree here already. Come to find out i didnt have a free oil change and that they charge $80 freaking dollars for one these days.
  16. Jun 21, 2021 at 12:42 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Exactly. How does these fucks become so slimy.
    DAS Taco, whatstcp and TRD-Troll like this.
  17. Jun 21, 2021 at 12:50 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    That seems reasonable - I'm not sure why, but for some reason, a lot of after-market accessories recommend using INJ as a power source for an 'Add-A-Fuse' which, IMO, is NOT a good idea. Are your Raptor lights LED or incandescent?
  18. Jun 21, 2021 at 12:52 PM
    AZ_Tumbleweed
    Wilmington, NC
    They are LED
  19. Jun 21, 2021 at 12:53 PM
    TnShooter
    Deogee
    STOCK
    I don’t know if that will cause the issue.
    But I’d find a different fuse to tap.
    That fuse goes to the ECM and Fuel injectors and Ignition Coils.
    If you ever have a problem with the lights, it’s very likely to affect the Coils or Injectors.
    Which will probably render the truck “dead where it sits” until you fix the problem
    I don’t like dyeing stranded on the roadside. I’d rather have the tap to a less critical competition.
    Like the tail lights or headlights or something?
    texbaz and GSRON like this.
  20. Jun 21, 2021 at 12:53 PM
    tirediron
    Hmmm... would have thought you'd get away with that, but possibly not. The ECU is apparently VERY sensitive to power issues on this cct.
