Dealer Oil Change and Low Oil Pressure Warning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AZ_Tumbleweed, Jun 20, 2021.
  1. Jun 21, 2021 at 1:17 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Which dealership is it?
  2. Jun 21, 2021 at 1:28 PM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    They recommend it because 99% of the Aftermarket Suppliers wouldn't know which end of the screwdriver to hold onto if they were told to install their product......
    Doc62 likes this.
  3. Jun 21, 2021 at 2:34 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    This makes me want to park my truck before its first oil change comes due and never drive it again.
    Junkhead and TRD-Troll like this.
  4. Jun 21, 2021 at 2:39 PM
    AZ_Tumbleweed
    AZ_Tumbleweed [OP] Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    Dealer said they pulled the fuse tap to the lights and put a factory fuse back in. Test drove it several times and hasnt shut off once whereas it did several times before when they tested. Only thing i can think is somehow that wire got damaged during the oil change as its very coincidental the issue started within an hour of picking it up from the dealer. ill keep yall posted
  5. Jun 21, 2021 at 3:27 PM
    texbaz
    texbaz Well-Known Member
    "Buffalo Creek" TX
    2018 Tacoma Silver Sky Metalic 4WD DCSB TRD OR
    Like others have said: Never power tap off of primary power circuits. like ECM,lights,fuel inj,ign coils etc,
    even if it is a coincidence, their are plenty of other circuits to tap off off.
  6. Jun 21, 2021 at 3:30 PM
    AZ_Tumbleweed
    Wilmington, NC
    Thanks, the threads i read that stated to use that fuse didnt mention what it was for. Care to share another spot i can safely use where the lights will turn on when the vehicles on
  7. Jun 21, 2021 at 3:33 PM
    texbaz
    "Buffalo Creek" TX
    So, you sayin you don't have a dedicated switch for the raptors?
  8. Jun 21, 2021 at 4:56 PM
    GSRON
    Ron
    Northern CA
    2019 TRD OR Cement
    Power Outlet fuse under the dash.... Hot with Acc and On.
  9. Jun 21, 2021 at 5:06 PM
    AZ_Tumbleweed
    Wilmington, NC
    Got it back from the dealer. Said they pulled the fuse tap and put a stock fuse back in. Drove it home with no issues. Dealer didn’t charge me either which is surprising
  10. Jun 21, 2021 at 5:16 PM
    texbaz
    "Buffalo Creek" TX
    Definetly a much better source. But why not run those raptor lights on a dedicated switch, you really want those lights on whenever truck is powered up.
  11. Jun 21, 2021 at 11:44 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Watch them mail a bill a week later lol
    Probably a line item for the bottle of water in the waiting room too!
  12. Jun 22, 2021 at 4:30 AM
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    I'm not impressed with any of the 3 VERY LARGE dealers in northern Utah
    I've learned where the lube tech's are hatched after a few weeks of delivering parts
    #1 lot technition
    #2 learn how to drive a manual trans
    #3 get the honor of washing the sales managers demo
    #4 start checking in New cars upon arrival
    #5 allowed to PDI the new ones....you know installing floor mats & removing interior plastic covers
    #6 customer shuttle driver
    #7 Saturday & evening lube tech
    #8 full time lube tech
    #9 garbage bitch
    #10 sevice writer
    #11 shop foreman
    #12 service manager
    #13 journeyman alcoholic/meth head
    TRD-Troll likes this.
  13. Jun 22, 2021 at 4:51 AM
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    OK. I might be wrong here but the initial consensus was that the dealer was at fault. However, even though one action usually causes the other, there are many instances like here that we don't know the whole story and immediately blame the dealership. If you've added anything above factory, you take the responsibility of knowing what you are doing and things can go wrong.
    The dealer in this case, spent time, diagnosed, fixed and didn't charge. I would say the dealer went above and beyond in this case.
    I'm the first to complain when things go wrong. But also give credit on the other side if warranted.
    JMO
    Phlogiston, Lt. Dangle and Kev250R like this.
  14. Jun 22, 2021 at 6:26 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    I never ever had anyone change my engine oil, I'm picky about type, brand and quality of work. Simple job that takes a bit of time but only you can do it right...providing you don't mind a bit of work :thumbsup:!
  15. Jun 22, 2021 at 6:35 AM
    #35
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    That blows me away, as it probably took them an hour to figure it out. Typically you get billed $150 for an hour diagnostic. It could have been much worse!
    If you live in an apartment complex, doing your own work is a challenge.
    I'm old, but still, I like doing my own maintenance. It gives me a chance to spend time looking for little issues before they become big issues.
  16. Jun 22, 2021 at 7:47 AM
    #36
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Just why I change oil in my vehicles
    You wouldn't believe the issues/mistakes some Chevy dealers' have caused changing C7 'dry-sump' oil systems, including putting new oil in the coolant reservoir as opposed to the oil tank.
    roundrocktom and Kev250R like this.
